Key fob has to be in the slot to start car.
Discussion in 'Gen 2 Prius Main Forum' started by ToyotaGal, Oct 28, 2025.
  1. bisco
    52,538
    no idea
    52,538
    center console?
  3. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    I believe in the door.
  4. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    Nope
  5. xw20_driver
    xw20_driver Member
    115
    58
    PNW
    You can find more details about the antenna/SKS oscillator locations in this thread. There are sensors in each front door, the center console, and the rear hatch. The likelyhood of all sensors/antennae failing at the same time seems low. Either the fob transmitter is dead or a central SKS component in the car failed. Techstream or an advanced OBD2 scan tool should have diagnostics to test the SKS system.
  6. Tombukt2
    Tombukt2 Senior Member
    13,597
    2,457
    Durham NC
    The Black box you want to deal with I believe is behind you're heater box it's like changing the EVAP core essentially good luck .
  7. Tombukt2
    13,597
    2,457
    Durham NC
    The locksmith needs a modern tool like vvdi it can call up individual boxes of security system report back to key tool their respective ID's and that their numbers are capable of communicating with rest of systems ie signals can move around the security system and so on and point to dead spot or areas of that proximity that system should cover and why not . Getting ready to play with one for about a week . Apparently a lot of smiths stay very clear of these activities on purpose they do not want to buy in on snap on toolboxes etc . I feel their pain.
  8. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    yes I ran into that a lot. The locksmith the mechanics recommended said they did want to warrantee an electrical issue and wanted to replace the whole system . Not sure if I had gone that way they would have been successful.
    Yes the mechanic used a high tech scanner and got codes. i don't know if it was Tec stream or not.. I will ask when I call.
    I'll ask about the black box as well.
  9. Kristenbluefin
    Kristenbluefin Junior Member
    29
    22
    Indiana
    Sorry I don't have a solution for you, but I have a fob that did the same thing. Stopped working except if I insert it. My other fob still works fine. Tried a few new batteries and could never figure it out.
  10. Tombukt2
    13,597
    2,457
    Durham NC
    It is possible that the literal remote or fob that you have is bad a tech w vvdi should take longer to boot the key tool to tell ya fob issue . Uhs supply has factory copies of the two black and silver SKS 57 bux . It's not the sex with the stupid looking green board that you see on eBay that tell you they're compatible .
  11. Tombukt2
    13,597
    2,457
    Durham NC
    I'd be interested in just hearing about their electrical repair that they can't guarantee but they can do just out of curiosity. What do you have one fob that works correctly as SKS and one that do not like others above or just one half working ? I mean if zi take the three computers needed from another car with their working remotes place that in said vehicle and should be good to go if it was all working in the donor car it should work Installed else where. Course you're looking at labor of changing evap I believe .
  12. bisco
    52,538
    i'd be interested to know more about the sex with the green board, tom
    ToyotaGal likes this.
  13. Tombukt2
    13,597
    2,457
    Durham NC
    Iits not the sucky fake green board fob remotes on e bay and the like for like 12 to 28 bux or so with pictures of the offending board that looks nothing like any board on a Toyoda remote . I'm sure ya know the fob remotes I'm speaking of.. God help you if you don't.
  14. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    I originally had 2 working fobs. Last March , there ws a fire and I lost all my cloths and spare keys to both my cars. The master keys were in their perspective cars. Since key prices went up and I had a lot to replace, I put thee keys on the back burner. I only have the 1 master key.
  15. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    It's going back to the hybrid mechanic on Tuesday.
  16. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    Oh boy what did I start???lol
  17. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    Test the fob at oreillys and the mechanism. It's working correctly.
  18. Tombukt2
    13,597
    2,457
    Durham NC
    Worked with a launch I think it's 435 pro x immo it's 3 pieces . In all scenarios you need to have working key .. apparently with these scanners you need a 45 subscription and account with I believe nasf and they require a big insurance policy. Do the scanner mfg have instituted to help w stolen or some BS. So now I will query UHS supply about limitations on vvdi key tool which is a pro locksmith tool . Should be an interesting conversation try do it tommorow
  19. Tombukt2
    13,597
    2,457
    Durham NC
    Tell me what happens when you call the dealer give the parts person your VIN number and ask them what it will cost them to order a new SKS key and fob ready for your VIN number and vehicle what do they tell you that's going to call cost I'm just curious I'm imagining 235 bux . I haven't called in years but I getting ready to . I'd pay the 235 easily . With the launch xp 436 8 was playing with yesterday . If 8 had a working fob slash key I could clone in 6 minutes I had a fob and chip and uncut key on hand . My cost would have been about 25 buc . But in all keys lost . The changes made by some governing body has cancelled out these immo scan tools for now . You have to have big insurance policy and subscriptions . Just learned this yesterday from two different mfgrs I had to pry that info from autel who are not honest folks at all Launch is about same .
  20. Tombukt2
    13,597
    2,457
    Durham NC
    Mark Jacobson Toyota here in Durham North Carolina just told me on the telephone and the parts department or rather the service department they will. Program fob 173 bux .
