LED Headlights on Gen 4 Prius
Discussion in 'Gen 4 Prius Technical Discussion' started by padroo, Feb 14, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    Does anyone know the part number of the LED headlight bulbs on the Gen 4 Prius and how much they cost.
    I am trying to brace myself after having HID headlights in my old Prius. lol
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I vaguely remember reading that they should last the "life of the car". LED is very different technology from HID, which have a reputation for not being long-life.
    Should you smash one, there was mention last year of 1200-1500 each, but can't remember if it was $AU, $US or €?
    RCO likes this.
  3. Tideland Prius
    16,673
    Not a Gen 4 but a Prime but at least it gives you an idea
    Radar emblem | PriusChat
    LED headlamps = US$1,635.90 each (They used to be US$5,000 each on the LS600h L, 10 years ago)
    That's for the complete assembly. I don't know about the individual bulbs (or whether they can even be replaced individually as they may be a cluster).
    RCO and padroo like this.
  4. padroo
    2,763
    2,253
    I have found lens assemblies in the $700 - $800 range but haven't found any reference to the actual LED light bulb.
    Maybe they will last the mostly advertised 50,000 hours. lol
  5. alanclarkeau
    7,045
    7,593
    Yes, don't worry - I don't plan to keep mine the 2 - 2½ million kilometers.
    RCO, KilgoreTrout and padroo like this.
  6. Tideland Prius
    16,673
    Keep in mind that the LED headlights are used as DRLs in Canada so if there's anything wrong, you'll hear from us first.
    This applies to the Corolla, Gen 4 and Prime that use the low beam (where applicable) at reduced power as the DRL.
  7. Elektroingenieur
    2,515
    3,288
    Three Touring
    In the U.S. market, Toyota sells only the complete headlamp unit assemblies as service parts, and there are no LED headlight lamps (bulbs), as such. I assume the LEDs are part of an assembly designed by Koito for this application. See my previous postings and Toyota’s parts catalog:
    Head and fog light modding | PriusChat
    4th Gen LED headlight durability | Page 2 | PriusChat
    HEADLAMP. For 2016 Toyota Prius Four HYBRID | Toyota
    RCO likes this.
  8. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Also, be aware the part number (and cost, presumably) differs if you have auto-highbeams.
    Hybrid4Life and RCO like this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    As long as you remember that the 50,000 hours figure was never measured in the first place. It's just a big number used by the manufacturers to emphasize they last a lot longer than incandescent etc, to justify a higher cost.
    Hybrid4Life, kithmo and alanclarkeau like this.
  10. alanclarkeau
    7,045
    7,593
    Well maybe - but I have no intention of hanging around long enough to check!!!!! I've an appointment in Heaven within the next 30 yrs, I'm guessing.
  11. bbald123
    386
    275
    Harrisburg, PA
    Actually, the LED headlight manufacturer did test them. But you should remember that the test does not come close to actual use patterns, which is why the actual life is often so different from tested life.
    https://www.edn.com/electronics-blogs/led-zone/4441442/How-long-do-LEDs-really-last-
  12. alanclarkeau
    7,045
    7,593
    I'm not sure if it's translatable, but I have a clock radio which I bought in the mid '70s with a LED display - it's still working fine. They do change every minute, some staying on, others swapping around.
    There are also a few LED lights in various appliances, phone bases, wall outlets etc which are a decade or more old, and which are on constantly.
    RCO likes this.
  13. Prodigyplace
    12,710
    11,848
    Central Virginia
    All US Gen 4 have auto high beams I believe.
  14. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    That was an option in 2016. They came on the Three with ATP.
    Prodigyplace likes this.
  15. Prodigyplace
    12,710
    11,848
    Central Virginia
    Other countries have auto leveling headlights that would be different too.
    I suspect LHD vs RHD are different due to aiming.
    pilotgrrl and alanclarkeau like this.
  16. bbald123
    386
    275
    Harrisburg, PA
    I hadn't even thought about that!
  17. bbald123
    386
    275
    Harrisburg, PA
    The testing method is to turn the test population on and leave them on until more than 50% burn out. Leaving lights on gives maximum hours of life because you don't have inrush current surges when turning them on from cold. LEDs also suffer inrush current when first turned on. Whether they suffer to a greater or lesser degree than incandescent bulbs, I don't know. But, I suspect the driver electronics make them much less susceptible to damage.
    RCO and alanclarkeau like this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Fair point, I suspect it's the surge experienced when switching on that would be the most demanding strain on an LED, not continuous running!
    LED
