LED interior swap
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Fobbers, Jun 27, 2017.
  1. Fobbers
    Fobbers Member
    30
    28
    Hey everyone. I was wondering if anyone in the California area has changed their interior lighting to LED's. If anyone could send me the links to purchase the LED's. I also might need some help installing them. I would like to do all 4 door lights, rear dome light and front dome lights. Any assistance would be great as well. Will compensate in food and Beer. Lol thank you
    SM-G935P ?
    jamiec123 likes this.
  2. bobthejedi
    bobthejedi Active Member
    137
    154
    SF Bay Area
    Its pretty easy, you need two different LED's
    for most of the lights, I think you need this one for the dome lights
    I recommend getting some plastic prytools and be gentle. Its pretty easy, I think the most trouble will be the map dome
    How to Change Front Map Lights. | Page 5 | PriusChat
    RCO and Fobbers like this.
  3. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    As bobthejedi says they all take the same bulb, except the rear dome which takes a very small festoon bulb. The original was 29mm, but I couldn't get one that size at a sensible price with shipping so I got a 31mm, filed a bit of one of the tips and squeezed it in.
    The difference is amazing, brilliant crisp white instead of dull gloomy yellow (y)
    #3 Harters, Jun 28, 2017
    Fobbers likes this.
  4. Fobbers
    Fobbers Member
    30
    28
    Thanks guys! What two LED's will I need? I wasn't able to see the video for some reason.
    SM-G935P ?
  5. bobthejedi
    137
    154
    SF Bay Area
    Found this video that may help
    4GP2ECOBP likes this.
  6. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    It fits back in securely after taking the whole thing out? What about that little light that projects light onto the shifter? Can that be changed or no?
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  9. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
    Fits back in like nothing was ever touched. Also the little light is already led.
    RCO likes this.
  10. Southern_nj
    Southern_nj Junior Member
    New jersey
    I have a 2017 Prius and noticed this thread today. Did you ever change your interior lights on your Prius? If so, what package did you buy? Thanks
    Glenn
  11. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I stuck the oversized ones in and then hunted up the correct sized ones and bent the receivers back into place, the led's are a big improvement.
  12. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Beware that those cheap LEDs put out RF interference that you can hear on your radio. Buy quality LEDs or stick to the halogen bulbs. This problem was described in a car repair column in my local paper.
    RCO likes this.
  13. Diemaster
    Diemaster Active Member
    296
    263
    so. cal
  14. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
    I buy the cheapest I can find, and have for years.. Have them in 3 different cars.. Never had an issue yet.. Prius now has 20k on those bulbs..
  15. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
  16. wwwMarKc0m
    wwwMarKc0m New Member
    Newark, Ca.
    2018 Prius
    I have an issue on my 2018 Toyota Prius 4, I have a dome light that has the SOS Button I seem to have trouble trying to pry open the housing to swap out the halogen bulbs w/ LED’s. Can anyone suggest any form of help please?
  17. Diemaster
    296
    263
    so. cal
    i recomend these bulbs for replacements. warm white and a little brighter than stock.
    i bought a JDM light kit for the regular Prius (the prime is the same. the SOS has additional connectors obviously.) bonus points if you can read Japanese. i recommend getting a METAL wedge stick thing. something about 1/16 thick, 1/4 wide, and 3-4" long.
    follow the pictures slowly and carefully; Theres LOTS of clips. It took me over 2 hours to do the main dome light and i still ended up breaking one for the gray clips. i recommend getting a plastic spudger tool to help hold parts apart while you work on the remaining clips. you'll see what i mean when you do it.
  18. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
  19. albus
    albus New Member
    28
    San Jose, CA
    If you do not want to take out the whole of the fixture from the headliner (as per the video above), you can follow the steps in the following video. The relevant section starts at 2:25.
  20. priusG
    priusG Junior Member
    30
    Los Angeles
    Anybody has panel type LEDs? Long time ago I used to have ex something company and looking for exactly that type. The regular LEDs, I cannot see, (already installed ebay ones) especially trunk, it is too dim.
    Any recommendation?
