LED vs. Xenon vs. Halogen
Discussion in 'Gen 3 Prius Main Forum' started by cozmisu, May 4, 2013.
  1. cozmisu
    cozmisu Junior Member
    24
    Romania
    hello everybody,
    which are the best headlights for Prius gen.III:
    LED - XENON - HALOGEN
    All the best!
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Your profile shows a 2008 GenII... In that case you get halogen or HID.
    HIDs are superior, but the OEM reflector HIDs are some of the worst.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Best for what? The halogen ones work fine. The HIDs were prone to problems, perhaps fixed by now. They produce more light than the halogen ones and draw less power. The LED ones are expensive, but drop the load on the 12V system a lot and produce more light. But if you burn one out, hope you have deep pockets!
    As with anything, there are tradeoffs.
  4. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    It depends on what's best for the driver. Very subjective. Others like just the way it is whether it be halogen, HID or LED. Based on having tried all 3, LED and HID would be the best. At first, I did not like the LED because of how the light was projected at a distance. But come to found out it was aimed a bit lower. Once aimed higher, it was amazing. Had my halogen converted to HID and liked it very much.
  5. cozmisu
    24
    Romania
    I'm considering replacing my 08' gen.II, with a gen.III and I'm a bit confused about these headlights options.
    I read that some owners are unhappy about the light of the LED's at night on wet roads.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    With a GenIII you only have two OEM options. LEDs are available on on the Model Five and PLug In Advanced. All other models use halogen projectors. The halogen projectors can handle an aftermarket HID kit which will improve light output but the OEM LEDs are still better. You can also go crazy and do an HID retrofit which is the best headlight option but that can get expensive.
    Soooo, purchase the model that makes the most sense to you without regards to headlight options. If you end up with LED headlights then great. If you don't then add an HID kit to them.
  7. Greg C
    Greg C Junior Member
    30
    Sydney, Australia
    I would not fit HIDs. Very few headlamp assemblies that are not designed for HID control the light output well enough and other road users suffer. I have been on the receiving end of plenty of theoretically illegal conversions especially when they follow you at night. The standard halogen lamps are fine, if you want to get more light you can fit a Plus 100% replacement. I have fitted those to my old Citroen and the difference is notable.
  8. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I've been running 55 W HIDs for 160,000Kms with no probs. never get flashed. The stock Prius projectors. Do a good job. HIDs in standard headlights are what cause probs.
    ptn and F8L like this.
  9. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Prius with OEM Halogens = poor/borderline unacceptable
    Prius with 4.3k quality aftermarket (not $50 ebay kit) HID's = average/acceptable
    Prius with OEM LED's = awesome!
  10. defrankond
    defrankond Member
    217
    23
    North Dakota
    image.jpg I like the LED lights honestly. Here is a pic of them at night
  11. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    I agree if you are referring to 2nd gen as the reflectors are terrible and will are quite blinding to other drivers. On the other hand, 3rd gen projectors performed very good with HID kits. The cut off is not as sharp as factory but it is very very good. Good enough where it does not blind other drivers. For my lamps, I even did a side by side comparison and Prius projectors with HID are not blinding.
    If Prius Chat search was not having all sorts of problems, I would link my photos.
    I would even go as far as to say better than some factory HID systems. For some reason, I've seen a lot of Audi factory HIDs that are blinding.
    #11 Sfcyclist, Dec 16, 2014
    xpcman likes this.
  12. Sfcyclist
    1,621
    376
    SF, CA
    If I would rate this the same way but on 1 to 10 scale, it would be;
    HID kit, 8-9
    OEM LED a 10. This is because it uses 4 LED's. This gives better spread.
    For the cost for the Digitial HID Kit, which is around $100. it's hard to beat. Just make sure your projector are aligned.
  13. Sfcyclist
    1,621
    376
    SF, CA
  14. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I am very interested in this thread because, as I age, my night vision seems to get worse. I am particularly concerned that I don't see the ground ahead of me as I drive at night. My car is a generation 3 with the standard headlights. It sounds from this thread that there's not much I can do about the lighting -- that a retrofit would not work well. Am I misunderstanding?
  15. Tideland Prius
    16,678
    A retrofit is actually the best way to get better lighting (best, as in cost-effective to get the result you want). An even cheaper route is a simple plug & play HID kit (get a good quality one and not a $50 one off ebay). The reason a plug and play isn't as good as a retrofit is because a plug and play puts an HID capsule into your exist projector lens designed for halogens. A retrofit will get you HID-designed projector lens to properly distribute the light. However, the benefit of a projector lens setup, in general, is a more focused light compared to a multi-reflector setup (HID or halogen). As a result, a plug and play kit placed into a projector halogen mostly works (as long as your headlights are not aimed too high) without annoying oncoming drivers like a plug and play into a multi-reflector would (Those look like trains at the end of the tunnel)
  16. Sfcyclist
    1,621
    376
    SF, CA
    In the thread I linked above, ataylor shot pics of the Prius Halogen projector and the TSX projector(known as a very good projector). It's on page 4 and 5. The main differences noted are;
    1. Lens, frosted vs clear
    2. Cut off lens, stamp steel us
    In the end, what are the results? The light output isn't substantially different. Yes the cutoff is better but the Prius lamps are far from blinding.
    A retrofit is nice but it really is as good as the installation. I understand the hate for glare as I experience it all the time. At the same time, I respect that, and made sure my system is aimed properly. What's stupid and sad to see now, is I see a lot of people in the Bay Area with halogen systems drive around with their high beams on. My guess is either due to ignorance or protest.. or both..
  17. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I drove my VW Bug for five years in Berkeley, and never had an occasion on which using high beams was legal or advisable. It's really too bad people are using high beams.
  18. Sfcyclist
    1,621
    376
    SF, CA
    or worse yet.. poorly aimed HID's.
  19. ilikethempgs
    ilikethempgs Junior Member
    42
    Northern, NY
    I like the halogen bulbs in my '11 Three. Plenty of illumination for me. High beams are also great. On the other hand- the OEM HID's in my girlfriends '07 prius are TERRIBLE.
  20. Sfcyclist
    1,621
    376
    SF, CA
    Gen 2 is no comparison as it's a reflector. Gen 3 halogen is a projector. Scary part was that the gen 2 was a factory system.
