Lock sensor not working
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by JEFF STEIN, Oct 1, 2020.
Tags:
  1. JEFF STEIN
    JEFF STEIN New Member
    NEW YORK
    2020 Prius Prime
    Just bought a 2020 Prius Prime Limited. The "touch" door locks mechanism worked fine for a few days, but now I'm getting a warning sound even though the all doors and windows are closed and the key fob has not been left in the car, and the doors aren't locking. I can, however, still lock the doors with the key fob. Any suggestions?
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Have you tried this? Although the fact you are getting a warning buzzer indicates the car is receiving the signal. Does the problem exist on both sides of the front doors, since you have 3 doors SKS?
    pghyndman likes this.
  3. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Off the top of my head:
    Make sure your second key fob is not n the car. My wife sometimes leaves her purse behind, with a fob inside (aaaargh!), but can be overridden by pressing "lock" on my fob outside the car. Also, if any doors or the hatch are not fully closed, or the car is not in the "off" condition (ie: is in accessory mode) the "touch lock" won't work.
  4. JEFF STEIN
    NEW YORK
    2020 Prius Prime
    None of those conditions were present. Today, it started working again correctly even though I didn't do anything different from the days before.
  5. Salamander_King
    11,024
    8,977
    New England
    Sounds like some type of computer bug. If the problem persists then a visit to a dealer may be required. But before doing that make sure you can demonstrate the problem at the dealer. They likely will not do anything unless they see the problem with their own eyes.
    pghyndman and jerrymildred like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Almost everyone will, at some point, forget to turn off their Prius when they get out of it. ;) I've done it a few times and I'm a bit of a perfectionist. First thing to do if you get that beep is to make sure it's off. I would just keep driving it and see if it happens again.
    Tips, Salamander_King and pghyndman like this.
