Locking Home Charging Station?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PhilBlank, Jun 16, 2014.
  1. PhilBlank
    PhilBlank Junior Member
    86
    2014 Prius Plug-in
    I do not have a garage in which I can park my 2014 PIP. I would like to purchase a level two charger and mount it on the side of the house so that when I get home at night, I can just take the cable and plug in the car.
    Although I live in a reasonable neighborhood, I really don't want to leave the plug available for anyone who might be inclined to pull up in their Tesla, Leaf etc. and help themselves while I am at work.
    So, what I am looking for an outdoor charger that will allow me to lock the plug into the charger while I am not there. Anyone have any thoughts?
    Thanks,
    Phil
  2. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Run the wiring through a switch inside the house and use it to turn off the power to the plug. Alternately, you can turn off the circuit breaker that feeds the charger, although breakers are not designed to be used as switches.
    KK6PD likes this.
  3. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  4. srl99
    srl99 Member
    113
    23
    2014 Prius Plug-in
    Other options - an OpenEVSE which is programmed to only charge off-peak (maybe a custom forward build to ensure this). Timer on the circuit. An EVSE which has a disable input (ex: Siemens Versi-Charge, there are others) - wired to a switch inside, or a timer. I presume you will use a hard wired connection to the EVSE.
    You can buy security screws and the proper bit at your local full service hardware store.
  5. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
  6. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I agree with Squirt.. unless you have reason to believe this may actually happen.. like if you came home from work before and found someone washing their car using your hose in your driveway.
    My EVSE is inside the garage, but my J-plug is outside. Its "hidden" when not in use. FWIW, I have a neighbor with a PiP and they've never tried to charge in my driveway.
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I would worry more about someone cutting the cable for the copper (which is very unlikely too).
    It's not going to happen....
  8. Astolat
    Astolat Member
    229
    73
    Guildford UK
    If you really want to pay out for something top of the line, the charger here
    Electric Vehicle Charging Offers - Save Energy - British Gas
    which I got fitted free as part of the UK government funded package has a very nifty cylindrical key, each one unique. It's branded Polar over here but it's part of Chargemaster.
    rxlawdude likes this.
  9. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    That's an amazing deal. EVSE, new dedicated circuit put in by an electrician, all free.
    Wish that level of EV enlightenment existed on this side of the Pond.
  10. srl99
    srl99 Member
    113
    23
    2014 Prius Plug-in
    Wow - this is great. And when you've got your car plugged in, this would have other uses ...
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Tad off topic, but I actually came home one day a saw my new neighbor using my hose and faucet to wash his car! I approached him nicely, commented what a nice ride, but why was he washing his car with my water? He looked at me and called me an idiot, and stated emphatically that this was his hose and hose faucet, so piss off!
    OK I thought, I dropped my stuff off in the house, went to the garage and got the Street Shutoff Valve Key that I had made, walked up the driveway to the water meter, ours are on the street, next to the Shut-off Valve. I popped the vault open, and turned the water to my home off! At that point I was watching the new rude neighbor pick up the hose to rinse off the car, and not a drop of water came out of the nozzle. He stood there for a second, shook the nozzle, like that will help, and squeezes it again, nothing!
    He then unscrews the nozzle, and much to my disbelief, he started to look into the hose to see where the water was ....
    So I turned it on, all 170 PSI of it, this particular faucet was not on the regulated line!!
    Water shot him in the face, he held on, dumb, and by the time he dropped the snakelike hose he was soaked.
    I turned the water off, walked down the driveway, looked at him, and simply said, "See, I told you it was my water faucet and hose"! and went into the house!
    He actually figured it out!
    I put a lock on that faucet!
    I love messing with rude bastards!:)
  12. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Remind me not to piss you off. :)
    KK6PD likes this.
  13. Astolat
    Astolat Member
    229
    73
    Guildford UK
    I know. If anything, a bit over the top, but it means my OEM EVSE gets very little wear and tear. Any Brit PiP driver that hasn't had one fitted should do, while they're still available.
  14. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    My son is a sergeant in the sheriffs dept. He went on a call recently to a condo complex where a resident in one unit had attached a hose to the outside faucet of a neighbor's unit, and then hooked it up to his outside faucet in order to steal water to supply his house. The offender wasn't at home, so no arrest, but a deputy made the victim's hose bib inoperable at their request. :cautious: Case referred to Code Enforcement for investigation and possible civil action.
  15. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    Amazing what people will do nowadays to save a few bucks...
