Having p0a80 p3000 pop up mostly randomly (often with acceleration) and sometimes infrequently with various other C codes but not the same ones. Often it drives fine with no codes for long times. Want to see the conditions in place when code triggers. Searching it seems that Hybrid Assistant (HA) might be good for that and that Techstream (TS) may possibly be used. HA doesn't aways re-connect well after getting back in the car and frustratingly it seems that the codes come up while I'm trying to reconnect. Thoughts on how to approach this?
Electrons are weird... Back in my NiMH rebuilding days when doing diagnostics I could get a P3000 several times in a day then go several weeks with no warning lights at all. You can watch Dr. Prius app data as you drive if you're curious. And you can clear codes as much as you want as long as battery temperature doesn't get too hot. Beyond that, rebuilding or replacing your pack is the correct answer to all your questions.
The P0A80 code triggering algorithms are considered proprietary intellectual property of Toyota. However if still under warranty (10 years 150,000 for all newer models and for older models in CARB states) that code is enough for Toyota to replace the hv battery free.
Your Prius keeps a record of many parameters when the P0A80 code is triggered. To retrieve the data, you need a scanner that can read the freeze frame data for the P0A80 code. As long as the P0A80 code is active, use Techstream or other scanner to look at the freeze frame data for the code.
I have Techstream = what's the process for checking the freeze frame data? 2007 Prius is what I am driving and though this battery was new from Toyota last year, I got it forma totaled Prius so I doubt they would honor the warranty I read some of your posts from back then! very helpful! what is too hot?
Too hot is when the white plastic end caps of the pack get so hot the overheated pack pushes on them and warps them and then shortly after that the tops of the modules start popping off and blowing electrolyte everywhere. I'd guess 130' or hotter... And congratulations! If the battery pack has serial numbers that indicate a date of manufacture of a year ago you don't have a problem with the pack at all, you have a problem with corrosion inside your battery ECU that needs to be cleaned and you also have corrosion in your voltage sensor wires. Use my link in my signature to get a 10% discount on higher that OEM quality voltage sensor harness.
Open Techstream. Run a Health Check. If the results of the health check scan show a current P0A80 code, there will be "snow flake" just to the left of the P0A80 code. Double-clicking on the "snow flake" will open the freeze frame data. It will look similar to the link I posted below. Once you have the freeze frame data, create screenshots or take pictures of the screen and upload them in a post. Here is an example of the freeze frame data for the P0A80 code,https://attachments.priuschat.com/attachment-files/2024/08/253941_Freeze_Frame_Data_08-03-24.pdf If you open the linked PDF and scroll down to page #3, you will see that battery block #2 has a much lower voltage than the other battery blocks. In this case, one of the battery modules that make up block #2 is bad. FYI, the columns labeled "-3, -2, -1" are before the trouble code was triggered. Column "0" is when the trouble code triggered. Column "1" was after the trouble code triggered.
Dr Prius has shown the center hotter than 130 sometimes :-/ Guess I'll see if I ever have to pull it apart I'll have to check the serial numbers. (if I am correct that the ECU is in the battery pack) I would have thought they would have provided a whole battery assembled rather than just the cells inside and use the old ECU Any help on which link discuss batt ECU corrosion resolution it would be appreciated. I do have a parts Prius from which I could swap the ECU
ECU and Relays and sensors and mounts bolt to the side of the battery pack. It's a different part/assembly than the battery pack. No need for more help on ECU Corrosion just open it up and clean it if you go it...
Battery ECU secrets and teardown (warning: geek content) | Page 2 | PriusChat I've been replacing these connectors for 8 years now. If the circuit board is good the connector can be de-soldered and new one soldered in it's place.
