Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 2 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Tough to say for certain but here is my best guess.
    1.Bridgestone Ecopia EP422
    2. Continental PureContact with EcoPlus Technology
    3.1 Michelin Defender
    3.2 Continental ProContact with EcoPlus Technology
    3.3 Bridgestone Turanza with Serenity Plus
    3.4 Michelin HydroEdge with Green X
    3.5 Michelin Primacy MXV4
    4. Michelin Primacy MXM4
    I left out the Acend because they are not good for wet traction at all.
    The Energy Saver A/S tops the EP422 but if you can't get them then the EP422 is your next best bet. I think the PureContact is a better choice from a mpg and wet traction standpoint. You should seriously consider the Turanza though.
  2. Grayson73
    Grayson73 Junior Member
    62
    Maryland
    Thanks, F8L! I ordered 4 of the EP422. Can't wait. The tires that I've been driving on the past 2 years is the Bridgestone Turanza EL400-02 and they've been terrible. You should see the reviews on tirerack.com :p
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The Turanza EL400 is pretty bad. :)
    Please post back once they are broken in. I would like to hear your opinion on highway speed feeling. Some claim to have wandering issue while mine were perfect. Also, these are fairly mushy tires so if you are unhappy with the handling, add pressure! ;)
  4. Grayson73
    62
    Maryland
    Yes, I will be putting in max pressure. Should I put 2 psi lower for the rear tires?
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yes, unless you regularly carry very heavy loads in the rear.
  6. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I know...I just put a review over there on Turanza EL400-02 OEM on my minvan. We did an epic 11-hr drive through the snow and ice the other day and the van handled quite well. So I decided to see what other people thought, I was a bit shocked to see no one else agreed with me (actually a few did like them). But something like the Serenity is where I want to go next.
  7. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Every few months I see someone say something like this and I go search to see how true it is
    Right now tirerack has in stock
    P185/65R15 851 RPM (Good for Gen II)
    P195/65R15 832 RPM (Good for Gen III, OK for Gen II)
    Are you using 16" or 17" rims?
    HaroldW likes this.
  8. dhanson865
    851
    188
    TN, USA
    So I'm looking at UK tire lists to see if I can find Fuel Efficiency / Rolling Resistance grades for tires that are sold in the US. Not looking promising so far but of the UK tires I see
    Yokohama BluEarth-1 gets a A
    Yokohama BluEarth AE01 gets a C
    Hankook Kinergy Eco K425 gets a B
    Continental Eco Contact 5 gets a B
    Continental Eco Contact 5 (XL) gets a C
    Michelin Energy Saver gets a C
    Michelin Energy Saver + gets a C
    Michelin Energy Saver S1 gets a C
    Bridgestone Ecopia EP25 gets a C
    Good luck getting any of those tires (other than the Michelen Energy saver) in north america. There might be a name change such that a very similar or even the same tire exists here with a different name but I don't have the secret decoder.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If you look at the tread design on the UK Energy Saver tires and the North American Energy Saver A/S they appear quite different. The UK versions look very much like the North American Energy Saver (summer tire) which we know is not as fuel efficient as its all-season brother.
  10. Grayson73
    62
    Maryland
    I have a Gen II Touring which comes with stock 195/55/16.
  11. dhanson865
    851
    188
    TN, USA
    In the Michelin Defender and Bridgstone Ecopia 422 you'd want to be using the 205/55/16 to get in the 830 to 840 RPM range.
    With the Ecopia 422 at 195/55/16 your speedometor will read a little over 2% fast and your displayed MPG calcs will be off by a little bit more than they would be otherwise (the displayed MPG isn't accurate vs actual anyway).
    Those differences are not enough to waste money exchanging but if you find that you need to exchange the tires for some other reason it is something to keep in mind.
    edit: that is assuming the speedometer/odometer on the touring edition is calibrated the same as the non touring addition. It is possible they calibrated it differently but I doubt it.
  12. dhanson865
    851
    188
    TN, USA
    So true and we don't know if there are compound differences as well.
    I can't wait until the US regulators get their act together and mandate some sort of published RR number or effeciency grade sidewall marking.
    F8L likes this.
  13. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Transferring tyre information from UK to US tyres does have some difficulties, but from my research it is clear that with tyre sizes relevant to the Prius:- 185/65/15, 195/55/16, 205/50/16, 205/55/16.
    The 205/55/16 clearly comes out across most makes as having the lowest rolling resistance. This is not conjecture but fact born out by the UK/EU tyre testing figures available for anyone to check.
    I have not checked out 17 inch sizes to any degree, but I did find 1 tyre rated (B) in the 205/50/17 the Hankook Ventis Prime 2 K115, and the same tyre at the 215 width with the same rating.
    F8L likes this.
  14. Britprius
    5,194
    1,921
    Just check 245/45/17 tyres for RR and again found only one tyre rated (B) and again it's a Hankook Ventis S1 Evo 2 K117.
  15. Grayson73
    62
    Maryland
    Yes, I have the Ecopia 422 205/55/16.
  16. dhanson865
    851
    188
    TN, USA
    Can you give me a URL with a proper list or a better way to search. I used www.blackcircles.com mostly but checked a couple of other sites that google gave me and I didn't see any tires in the 205/55/16 with better fuel grades than the P185/65R15.
    Also you mention 185/60/15 which is NOT a standard tire size for the Prius here. I'm assuming you meant 185/65/15 instead.
  17. Britprius
    5,194
    1,921
    Sorry yes my type error I will amend.
    My post does state "most makes have lower RR at the 205/55/16 size" not one particular tyre manufacturer the Yokohama Blue earth 1 with an (A) rating that they do not make in the 205/55/16 or 195/55/16 sizes so cannot be compared.
  18. Britprius
    5,194
    1,921
    Bridgestone also make an (A) rated tyre that is only made in one 15 inch size at the moment. This also has a wet grip rated (A)
  19. talonts
    talonts VFAQman
    468
    76
    Warning, long-winded...
    So it's finally time to start watching for tires on my 04, 2 of the 4 185/65R15 HydroEdge are getting close to dead. Thanks to Michelin being completely braindead, I can't just replace those 2. I have OEM take-off rims/tires I can toss on the front or back or both, as needed while we wait for the best tire deal (I'd prefer to continue using the 2 newer HEs (replaced from road hazards before they disappeared nationwide) on F or R over the Integritys).
    I've generally gotten 75k or more out of the HEs while not losing too much in mpg. To us, priorities are:
    1. long life - the longer the treadwear warranty, the better. $/mile is often better on more expensive tires.
    2. Wet traction - I live in FL. 6+ months of rain
    3. LRR
    4. Dry traction
    5. Noise
    The HEs were ideal, nearly silent, and my wife is pulling down 50+ in her commute. A better LRR for even higher mpg would be great, but not at the expense of noise, life, or traction.
    Looking at this and other threads, the Michelin Defender seems to be a good choice, as it has the 90k warranty that the HEs did. I don't know how it would stack up to the HEs, but it seems close. We would wait for the next Michelin rebate on these from either Discount Tire or more likely Sam's Club (far cheaper than DT after including road hazard).
    Any others we should consider? Most of the ones with slightly better mpg have, to me, dismal treadwear life of 60k or far less, while costing nearly the same, which keeps the $/mile higher over the life of the tires. The
    Continental ProContact EcoPlus are interesting, but are up to $95 at Walmart (much higher after install costs and warranty), and aren't at Discount Tire or Sam's (I think it's moronic that Sam's doesn't have the same tires as Walmart), and it seems that 80k life might not be close to attainable. Tire Rack is out, I used to buy from there and get local shops to install them, it's a hassle, and by the time all is done, it's nearly the cost of Sam's Club with the road hazard warranty included. Costco is a possibility, BUT I'd have to add in the cost of re-upping my membership, and the gas and time for a 400 mile round trip.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Hi Tom,
    Sometimes long tread life can be a false economy. If the fuel economy is much less than another set of tires that have a decent tread life then the cost/mile argument will favor the more fuel efficient tire. Even if the costs are even, assuming extra mounting and balancing charges for the lower tread wear tire, you have newer tires on the car more often. Old tires wear out chemically and are less safe than a tire under a few year old.
    See this thread for similar math.
    Total lifetime cost for fuel and tires over 150,000 miles | PriusChat
    I think the Energy Saver A/S will still come out ahead vs. the longer lived Defender because of its superior fuel economy but it could be close in terms of total cost/mile. Just make sure you get the $70 rebate when it comes around. I bet Discount Tire will have their $100 rebate on any 4 tires soon too.
    The ProContact with EcoPlus is a great tire for rain but reports are saying it doesn't last very long. :(
