Machine gun noise under dash, around 10Hz
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by OptimalPrime, Dec 4, 2024.
  1. OptimalPrime
    OptimalPrime Active Member
    169
    100
    Keene/Nashua
    A month or two ago, my 2017 Prime Plus (aka base/LE trim, purchased new, 132K miles now, never a problem worse than a stuck auto high beam dimmer switch) scared the crap out of me, with a sudden machine gun clicking noise coming from somewhere over toward the shifter or glove box. Pretty loud clicking, pretty fast, lasted a second or two. Then similar happened on some days, not on other days. Then every day, sometimes more than once.
    I got pretty good at counting the clicks, or at least thinking I did. The most common scenario is 18 clicks at about 10 per second. Playing the rock opera Tommy (London Symphony Orchestra version) at volume setting 45 does not drown it out.
    As time went on, it became less limited to 18 clicks, though seeming to be in bursts that long, maybe with a pause between them, maybe not. A few times now, it has done probably at least 10x or 20 clicks, meaning about 18 seconds of continuous madness happening in the car.
    Every Wednesday, I drive my 3.5 year old grandson to his home from another grandparent's house. So, today I will try to pay attention and log what happens, maybe remembering to record the whole ride on a "voice note" on a phone. Maybe then I can confirm the speed and duration of the clicking more accurately.
    The most common times for it to do it, are soon (maybe 30 seconds) after turning the car on or turning the car off. But just randomly idling or driving, it will do it.
    Based upon Googling and pondering, it seems very likely related to the climate control blend door servo motor or gear teeth. Yet, with the climate control purring along at steady state during an hour-long drive, not having changed anything in many minutes, it will suddenly do it.
    Has anyone had this same problem? I found a bunch of references to servo and blend door problems causing people to get blasted with unstoppable heat, but that is not a symptom in my case. The climate control seems to be doing what I set it to do, I'm just getting this machine gun sound from under the dash.
  2. Mendel Leisk
    42,271
    Have you checked the cabin air filter condition? Just in case it's clogged, or rodent infested or whatever.
  3. Trollbait
    12,806
    Is the HVAC set to auto operation? It can change the air intake and output settings without being readily noticed. The noise on start up and shut down aligns with the system going into and out of a parked mode.
  4. OptimalPrime
    169
    100
    Keene/Nashua
    I routinely change the cabin air filter, and permanently (I hope) won the battle with the rodents a couple of years ago. Mouseproofing the firewall rodent access highway was a fun project, a whole story of its own. My daughter and I each own a Prime, so we did both cars. Then, because a mouse found a way into the HV battery area under the hatch, we mouseproofed the access to that space also, they were getting in through cabin/battery air exhaust rubber flaps between the trim panels and fender quarter panels.
    This noise is MUCH louder than the blower wheel spinning against a stuck acorn, don't ask me how I know. But to answer your question, I haven't checked the cabin air filter since the new noise started.
    I've paid more attention to the noise. It is approximately 18 clicks at around 10 per second, then a very short break (missing 2 or 3 clicks maybe) and repeating. Most often, it repeats 14 times. So about 30 seconds of making a lot of noise.
    It was reliably doing the 14 bursts, but now sometimes does just one or two, or the last burst might be 3 clicks instead of 18ish. Many variations. I will enlist my able assistant (the Prime owning daughter) to help hunt down the sound while it is happening.
  5. OptimalPrime
    169
    100
    Keene/Nashua
    No, it is set the same way I've had it set for the whole 133K miles, I don't use any auto modes on the HVAC, the EV/HV mode, or the high beams. I like setting things myself. I am willing to break that general rule by setting the dome light on auto.
    I do agree that startup/shutdown procedures trigger the noise. But it will also randomly trigger itself while driving at complete steady state, having changed nothing.
  6. OptimalPrime
    169
    100
    Keene/Nashua
    My latest update is that it goes through phases of doing it several times per hour then maybe nothing (except at startup and shutdown) for an hour.
    Also, it sometimes clicks around 2x as fast, so let's say 36 clicks at 20 per second, versus 18 at 10 per second.
    Similarly, it sometimes clicks only about half as fast, say 9 clicks at 5 per second, but this is more rare.
    Also, it will do various combinations of that in a given burst, or differences between burst, changing during its set of 14 bursts. Sometimes it is like a fairly creative, syncopated drum solo for a burst or so, before returning to just rapid-fire clicks at constant intervals.
    There have been several times when there is no pause between the 14 bursts, just continuous clicking, but this is unusual.
    After turning the car off one time, plugging the car in to charge, then opening the car door to hit a steering wheel to do the charge now vs later, it did its clicking routine, but because I was leaning in the passenger door, I heard a little better triangulation on where it is behind the dash, plus heard an additional, much fainter whirring sound as if a blend door was being moved.
    One other symptom is that while driving and not hearing it for many minutes, upping the fan speed (manually pushing up the fan speed button) has maybe a 25% chance of instantly triggering it.
    I don't relish disassembling stuff under the dash to be able to feel around for it, using my fingers as a stethoscope. When the weather gets reasonable, I guess I'll have to do so. I'll see what I can get at with the glove box removed, first.
    Personally, I've adapted to the sound, and am no longer startled or annoyed by it, despite it being VERY loud. Fixing it will be so that I can carry a front seat passenger without needing to apologize in advance for it being sure to scare the crap out of them.
  7. BiomedO1
    BiomedO1 Senior Member
    4,527
    2,381
    Left Coast
    You can remove the glove box and disconnect power to the blower motor to see if that resolves it. I have a bad feeling it's a broken plastic gear to one or more of your blend doors. Even though you've got the HVAC set to manual, the system will activate the blend doors for calibrations and diagnostics purposes.
    Hint: use a hair dryer to warm-up and soften the plastic while removing the glove box. That'll lower you chances of breaking something.
    Good Luck....
    OptimalPrime likes this.
  8. ChapmanF
    18,959
    Mind the assumptions there. It could as easily be the blend door servo or any of the other door servos. There are at least three: one for blend, one for inlet select (fresh / recirc), one for outlet select.
    I don't remember if your model is supposed to have "S-flow" or some such—independent selections for driver / passenger. More door servos.
    Could be any one of 'em.
  9. OptimalPrime
    169
    100
    Keene/Nashua
    Good point about the HVAC having more moving parts than just for blending. In my mind, I was actually thinking more of the input and output selection change mechanisms than heat/AC blending (if that even happens in a Prius Prime, considering the heat pump) but just called all of them the blend doors, because people rarely call them anything else, regardless of which function they are serving. It's also unclear without checking, whether a car maker has a separate motor for each function, or has one motor do double or triple duty by using clutches or solenoids to independently engage multiple shafts driven by the same motor.
  10. OptimalPrime
    169
    100
    Keene/Nashua
    Well, time has marched on without my figuring out or fixing this. The good news is that it typically now happens one time in the first minute after startup, and one time in the first minute after turning the car off. It has become less frequent while driving. I often can do my hour plus commute without it happening while driving.
    Whether due to the current weather and time of year, or something vibrating back into place, a wire becoming less intermittent, some adaptive algorithm deciding to try less often due to lack of success on an ever-increasing number of unsuccessful tries to do whatever it is attempting, or something like that, I don't know. I guess I should take careful notes about when it happens, and see if there is any correlation with weather, EV/hybrid modes, HVAC settings and changes, etc.
  11. ChapmanF
    18,959
    Toyota's using separate motors, at least in all the Prius generations I know about. You're right that checking in the repair manual is the best way to be sure.
    Diagnosis can be pretty easy for these kinds of things if you are able to get your head down there where your feet go and watch the linkages. If that kind of contortionism doesn't appeal to you, USB inspection cameras on long flexible stalks have become quite cheap.
  12. Gianmarco
    Gianmarco Junior Member
    Italia
    2018 Prius PHV
    I think it's a worn out electric motor of the heating deflectors or an electric motor of the heating hot/cold air mixing
    If my theory was right, by changing the temperature or diverting the air in the vents, you should hear the abnormal noise you describe.
  13. OptimalPrime
    169
    100
    Keene/Nashua
    July 21, 2025 update. I've found what can trigger it 100% of the time, and that is when recirc is on, and I turn recirc off. So, it's got to be related to the inlet blend door movement. Except that turning recirc ON, does not trigger it. Just turning it OFF. It still also very often (but not always) does it after starting the car up, without much regard to how the HVAC controls were set when the car had been turned off, or what they immediately set themselves to when the car is turned on. The car always does its clicking routine a while after turning the car off, regardless of whether HVAC was on or off, or what it was set to.
    Personally, I wish the car had no recirc setting at all. I never use it, except that sometimes now, I use it when the car starts up and decides to have recirc on. If I'm not going far, and the temp in the car is not oppressive, I just leave it on recirc now for a few-minute trip. For longer than that, I turn recirc off at some moment when I don't mind 30ish seconds of loud clicking.
    I'm pretty sure that the inlet blend door does get moved correctly, because there seems to be a really significant delay in cooling the car off when I start it up with the car interior boiling hot, it's in recirc, and I leave it in recirc. But when I change it to fresh air in, it quickly cools off.
    I still have to try removing the glove box (which I do routinely for the cabin air filter changes) and sticking my head under there while it's doing it, to see if I can feel around to see where it's clicking. It seems to be way buried behind the dash, but until I reach it, I can't be sure.
    If I had a way to kill the entire inlet-door function while it's set to draw in fresh air, I'd do that. Maybe my scan tool can just turn it off completely, that would be perfect. Time to do some experiments, but I've been lazy and gotten used to the sound attacks.
  14. ChapmanF
    18,959
    Well, that depends on the people. It's true enough there are frequent posts by people being careless with the names, or who never quite learned them, but that's partly a situation that's perpetuated by ... being careless with the names.
    Or just the inlet door movement. :)
  15. OptimalPrime
    169
    100
    Keene/Nashua
    I suppose you got me on that, with it only having 2 positions, so no "blending".
    I guess inlet air selector door might be the best term for it.
    On second thought, there is always some outdoor air let in, to prevent suffocation.
    Likely via a parallel path, rather than the inlet door, to not suffocate if the door fails completely shut.
    So, if it's selecting between 10% and 100% fresh air, I guess it COULD be called a blend door, just not a continuously variable one.
    #15 OptimalPrime, Jul 21, 2025
  16. ChapmanF
    18,959
    Sure, it COULD be ... but at the cost of clarity, because "blend door" (or "air mix door", which I think Toyota's repair manual uses more often) names the door that's used to control temperature by splitting airflow through and around the heater core.
    Some cars can have driver and passenger temperature settings, and so might have more than one blend door, but still they'll be the ones blending air for temperature control.
  17. OptimalPrime
    169
    100
    Keene/Nashua
    Annual update July 9, 2026. Car has 155K miles. Some progress has been made on the inlet-air door servo motor clicking problem.
    I got a bi-directional scan tool for the car with around 30 "reset" functions. Creader Elite Toyota-specific (and Lexus) edition, often $140 on Amazon, sometimes on sale $120. Better yet, an ex paid for it and just lets me keep it in my car, because I'm the only person using it on her cars. Anyway, I used it to configure an internal HVAC parameter, to NOT automatically change the inlet air door at car shutdown. So, that helped, and for many months would just keep it in fresh-air mode continuously. The clicking happened maybe only 10-20% as often: sometimes at startup and shutdown; sometimes only at shutdown. The random occurrences while driving were greatly reduced, plus the occurrences triggered by switching from recirc to fresh air, were almost eliminated, because it rarely started up the AC in recirc.
    Now, however, it has gone back to starting up the AC always in recirc/max mode, and when I turn that off, it does its clicking routine. I haven't yet checked if the internal parameter changed back, or if I just have to again keep fiddling with what my HVAC settings are when I turn the car off, to trick it into not defaulting either car startup or AC startup to recirc.
    Some good news is that the clicking is often quite muted rather than extremely loud. Probably 2/3 to 3/4 of the time, now, it is not loud. And when it's loud, only around half the time is it extremely loud, like it used to always be.
    I have not become inspired enough to tear the dash out and deal with this problem physically. With it not being as loud or as often, that's just not going to happen unless someone finds a sure-fire way of fixing the problem without too much labor. I am tempted to get a snake camera to see if I can get a visual on what's going on, without tearing the dash apart. It would be nice to know if just killing power to the inlet air door servo would keep it in that position securely, or whether it would end up migrating to recirc vs fresh vs a mix. If I could just kill power to the servo and ziptie the door in the fresh-air position, I would do so. I would be happy for it to never be in recirc mode. In the few cases where recirc might be good (passing through a cloud of smoke/dust) I am fine with just turning the blower completely off (plus going into EV mode to save the engine air filter).
