Major wind chill prediction, should I postpone trip?
Discussion in 'Gen 2 Prius Main Forum' started by Freedom, Jan 6, 2015.
  1. Freedom
    Freedom Active Member
    553
    73
    Northeastern MA
    Thursday, I am due to make a 96 mile drive north from RI to Mass. on the NH border. Typically takes me an hour and a half.
    I do have pipe insulation on the front grill of Carmine. Now we have this Wind Chill Watch in effect for my entire trip route. Anything special I should do? Should I put off the trip to the next day (or later than that even). Keep in mind that I'll be on the highway going 55 mph, so the wind chill will be even WORSE than what they are discussing in the post. Darn, think I just answered my own question, lol.
    Thanks all. Here is the National Weather Service posting:
    Jan 6, 1:05pm EST
    Weather In Motion®
    Issued by The National Weather Service Boston, MA
    Tue, Jan 6, 10:25 am EST
    • ... WIND CHILL WATCH REMAINS IN EFFECT FROM WEDNESDAY EVENING THROUGH THURSDAY MORNING...
    • * LOCATIONS... NORTHERN CONNECTICUT... NORTHWEST RHODE ISLAND... MASSACHUSETTS NORTH AND WEST OF 495.
    • * HAZARD TYPES... DANGEROUS WIND CHILLS.
    • * WIND CHILL READINGS... AS LOW AS 25 TO 30 BELOW ZERO.
    • * TIMING... WIND CHILLS DROP TO 15 BELOW ZERO AROUND RUSH HOUR WEDNESDAY EVENING... AND TO 25 BELOW ZERO BY LATE WEDNESDAY NIGHT. WIND CHILLS SHOULD RISE TO 15 BELOW ZERO BY NOON ON THURSDAY.
    • * IMPACTS... DANGEROUS WIND CHILLS MAY RESULT IN FROSTBITE OR HYPOTHERMIA.
    • * WINDS... NORTHWEST 10 TO 20 MPH WITH GUSTS UP TO 40 MPH.
    • * TEMPERATURES... 6 BELOW TO 19 ABOVE ZERO.
    • PRECAUTIONARY/PREPAREDNESS ACTIONS...
    • A WIND CHILL WATCH IS ISSUED WHEN THERE IS THE POTENTIAL FOR WIND CHILLS TO FALL TO -25 DEGREES OR COLDER FOR AT LEAST 3 HOURS. A WIND CHILL INDEX BELOW -30 CAN BRING ON FROSTBITE IN AS LITTLE AS 10 MINUTES. OUTDOOR EXPOSURE SHOULD BE LIMITED IN THESE CONDITIONS.
    More Information
    • ... DANGEROUSLY COLD WIND CHILLS EXPECTED WEDNESDAY NIGHT AND THURSDAY...
    Other Alerts in the Vicinity
  2. alekska
    alekska Active Member
    435
    138
    Atl
    I would postpone. If you get a flat, for example, it would turn the trip to disaster.
    - Alex
    52,888
    windchill does not effect cars. that being said, the possibility of breakdown doesn't sound pleasant. there will be a lot of people out that day and everyday. wait for posts from our midwest and canadian friends.:cool:
    take precautions if you're a senior or have any medical conditions. your car should have appropriate winter supplies including food, water and blankets.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Go. Stick to the main roads. If it gets icy, slow down. Everything works fine in the Prius in the cold. I'm a ski instructor who goes out in all kinds of cold weather. Never had a problem other than super deep, unplowed snow in muddy parking lots (my feet got wet and dirty, but the Prius still didn't get stuck).
    jackmccullough likes this.
  5. fuzzy1
    10,722
    Windchill is for your bare skin, not for the car. Unless you drive with the windows rolled open, or convertible top down, that highway speed doesn't matter.
    MPG will suffer, but otherwise the car will be fine. The kind of car you have, Prius or traditional guzzler, doesn't matter. The concerns are about your body in case circumstances force you to be out of the car for an extended period.
    kenoarto likes this.
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Lol, the car doesn't care. Actual temperatures of -6F? That's still shorts and T-Shirt weather here if you get up on the slopes. I remember skiing one year when it was -17F out but nice and sunny. Had my jacket open in just my tshirt and a pair of jeans and was still getting hot.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    There are large areas of the country that deal with temperatures in that range this time of year.
    Some of them even have counties as small as Rhode Island :)
    kenoarto and ijim2011 like this.
  8. alekska
    435
    138
    Atl
    Sorry, have to correct you here. The wind chill will make your engine temperature to rise slower (and possibly never reach proper working temp) if the wind is headwind. Think about something warm being exposed at cold ambient temperature with and without air motion. In which case it would loose heat faster?
    - -Alex
  9. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Yes but it effects car by fraction of what it effects people. If actual temp is -6F and windchill is -30F it only means wind of 21MPH which isn’t fast compared to highway driving speeds. And having grill (partially) blocked will minimize effect even more.
    I don’t think that at highway driving that temp is even cold enough to effect fuel economy. Except on start or if you use heater to much.
    uart and kenoarto like this.
  10. alekska
    435
    138
    Atl
    I agree.Wind chill will effect metal objects, but less than it would effect people.
    - Alex
  11. kenoarto
    398
    Chicago, IL
    If we really want to get technical, the speed AND the direction of the car in to, or against the wind, makes all the difference. FWIW: Heater makes no MPG difference at highway speed (as AC does).
    #11 kenoarto, Jan 6, 2015
  12. fuzzy1
    10,722
    Wind chill will affect any heated object, regardless of material. The familiar index is computed for bare human skin, and isn't correct for other objects.
    The engine block is a heated object, due to the fuel burning inside. But it experiences its own 'wind chill' at highway speed all the time, even in what we consider warm weather. The wind speeds listed above are low compared to what is already entering the grill.
    Wind chill will not affect unheated objects at the same temperature as the local still air, unless evaporative cooling is also happening. The objects will stay at the air temperature, not chilling down to the 'wind chill index' figure.
    robert mencl likes this.
  13. valde3
    2,002
    751
    Finland
    I’m not sure what’s the limit of Prius but in my old Corolla and other cars too using heater at full blast even on highway driving will get engine temp dropped if outside temperature is -23c or -10F or colder.
  14. kenoarto
    398
    Chicago, IL
    "...in my old Corolla and other cars too using heater at full blast even on highway driving will get engine temp dropped if outside temperature is -23c or -10F or colder."
    1) Old Corolla is not a Prius.
    2) Heater used at full blast at highway speed? Really? That must been a helluva rust bucket! Sounds like the old VW Beetles!
    3) -10F real temp not to be confused with human skin based wind chill factors
    4) If the car can't get up to full temp THEN (and only then), should you take your dog sled...
    5) Exactly how did the cooler engine temp actually effect MPG? Please share data.
  15. valde3
    2,002
    751
    Finland
    1) I know but it was just an example. I haven’t tested Prius.
    2) If you stand outside in cold you want to get hot as fast as you can. And even at full heater blast inside of back windows were still frozen. And maybe we do have a bit of different idea of highway driving I did count driving about 80km/h or 50MPH. No rust holes.
    3) Yes actual temperature.
    5) Cooler engine temperatures will effect fuel economy maybe not much but they will. I did just mentioned it originally just to be on safe side.
  16. fuzzy1
    10,722
    Many hardcore hypermilers will strongly disagree, even in less efficient non-hybrids. This cold ambient temperature will cause some reduction in fuel economy, and turning on cabin heat will reduce it even more.
    One of the moderators here has even produced an MPG vs temperature plot from his own data.
  17. kenoarto
    398
    Chicago, IL
    "Many hardcore hypermilers will strongly disagree, even in less efficient non-hybrids. This cold ambient temperature will cause some reduction in fuel economy, and turning on cabin heat will reduce it even more...One of the moderators here has even produced an MPG vs temperature plot from his own data."
    Important detail: Hypermiling is not done at 55+MPH highway speeds. Hypermiling is slower than 41 MPH.
    BTW: Boston weather forecast calls for highs in the 20s and 30s and lows in the mid to high teens! THAT ain't cold!
    So again I ask, how did the cold weather effect your Corolla's MPG? Any actual data?
  18. valde3
    2,002
    751
    Finland
    Cold temperatures effect a lot at shorter trips. Or lower speeds. Especially speeds bellow 67km/h or 42MPH where ICE can stop. But at highway driving once it’s fully warmed only things that change are transaxle oil temp, bearing+axle grease temp, and air density (which shouldn’t reduce Prius engine efficiency).
  19. valde3
    2,002
    751
    Finland
    I don’t think any of us are talking about the original topic anymore.
  20. fuzzy1
    10,722
    Baloney. Plenty of folks at CleanMPG.com still hypermile at highway speeds.
    Here are numerous pointers discussing why mpg drops in winter. While many other factors are in play, simple ambient temperature is one of the factors:
    Why mileage gets worse in winter
    Why Don't I Get The EPA Mileage?
    And just posted to another thread, courtesy of miscrms: Help! My 2014 Prius v only 30 to 37 mpg
    "2) In this EPA test cycle data from Argonne National labs, the effect of dropping temperature from 72F to 20F on highway cycle mpg is:
    Jetta TDI: 52.4 -> 43.6 mpg
    Prius PHV (discharged battery): 67.9 -> 55.4 mpg
    Argonne TTRDC - D3 (Downloadable Dynamometer Database)"
