manufacture defect? steering wheel peeling
Discussion in 'Prime Main Forum (2017-2022)' started by aznkorboi, Mar 10, 2021.
  1. aznkorboi
    aznkorboi Junior Member
    51
    22
    california
    Is anyone else's Prius Prime steering wheel doing this?
    I have a Lexus as well with zero issues. Using hand sanitizer way before covid after filling up gas etc, but don't think that should cause this massive amount of peeling on the steering wheel.
    Is there a recall out I don't know about??
    Also, always use my heatshield sunshade in the sun.
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Lots and lots of peeling. Might be the most common complaint on the 4th gen Prius.
    I don't think it's hand sanitizer. My theory is that it happens in the place where drivers hang their hands. The spot where mine is starting to show a little skin sag, for lack of a better term, is at about 9:30. That's the spot I tend to apply pressure to with my right hand as I wait at an intersection to make a right turn with the steering wheel already partly cranked over. Normally I have my elbows taking the weight on the arm rests while lightly holding the wheel at 9:00 & 3:00 or a little below.
    The problem seems to me to be that the hide on the wheel is thin and not well secured to the material below it. Twisting forces tend to break it loose too easily. Most Toyota dealers have had a heart of stone when people complain from what I read here on PC.
    aznkorboi and ETC(SS) like this.
  3. Salamander_King
    Salamander_King Senior Member
    10,974
    8,860
    New England
    Here are a few examples. Very few people successfully argued to the dealer and Toyota to have the whole steering wheel replaced. In most cases, it was not covered by the warranty. It seems to happen more often on Advanced trims with the heated steering wheel. My 2017 Premium did not show any sign after 3 years, but I already traded in that vehicle. My thought is even if you are successful in replacing the steering wheel either by warranty or by out-of-your pocket cost, you will be facing the same problem again. Your best remedy maybe just to install a wheel cover as shown in the last thread in the list below.
    Steering wheel vinyl coming off | PriusChat
    Softex Steering Wheel Peeling | PriusChat
    steering wheel peeling not warranty covered | PriusChat
    Cheap Steering Wheel on Prime Advance? | PriusChat
    Steering Wheel peeling | PriusChat
    Steering wheel leather mod | PriusChat
    #3 Salamander_King, Mar 10, 2021
    aznkorboi likes this.
  4. ETC(SS)
    6,553
    California:
    Florida:
    New England:
    YMMV.....
    jrodz09 and aznkorboi like this.
  5. Db17
    Db17 Member
    188
    92
    Visalia, CA
    It happened on my 2017 Advanced. My local dealer wouldn’t cover it under warranty.
    My best guess is that everything on a Prime is as thin and lightweight as they could make it. I also ended up with what I though were too many chips in the paint job which I’m guessing is thinner than any of the other Toyotas I have owned.
    #5 Db17, Mar 10, 2021
  6. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    It's really not a manufacturing defect. It's an intentional inferior, low quality vinyl covering on the steering wheel. The cover on my 2017 Prime failed at 23,000 miles and it wasn't covered under warranty.
    The cost for parts and labor to replace it, was almost $1,000.
  7. Trollbait
    11,541
    Everybody is going with thinner, or weaker, paints. Mainly to reduce VOC emissions during manufacturing.
  8. aznkorboi
    51
    22
    california
    Sweet Mercy.. Yes.. It does seem SUPER thin now you guys mention it. And we do have the advanced version but used the heated steering wheel probably twice since we got the car 4 years ago.
    I thought Toyota's were supposed to be solid well built machines? First we had a 12v battery issue, then we were told to get a hybrid fan system cleaning, and now this... And of course, it all happens after the warranty.. SMH
    Thanks everyone for the input
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,166
    2,211
    Taylors, SC
    The element in the heated steering wheel doesn't help. It's called the KMT or Kinetic Molecular Theory. Heat places molecules and their molecular bonds in motion that stretches the bonds. The result of the broken bonds is cracking of the plastic covering>
    Leather would stand up to the heat better and have a longer life.
  10. ETC(SS)
    6,553
    They are, but all cars have their warts.
    The 12v battery issue is not really a Toyota thing. Most new cars these days have itty-bitty little engines and much larger and more complex electrical systems. OEMs are using smaller 12v batteries and really....4 years is about normal for most new cars to need a new one.
    YMMV.
    HOWEVER (comma!)
    Hybrid Fan System Cleaning?
    I would not expect this to be a major maintenance item on a four year old car.
    THAT is almost certainly your dealership over-charging you to clean the traction battery fan filter, unless you collect Persian cats as a hobby or otherwise have more than your share of fur-babies.
    I'd "circle back" on that and try to figure out exactly what they did and how much they charged for it before I decided to continue my relationship with your dealer.
    Good Luck!
    aznkorboi and jerrymildred like this.
  11. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Is that done by putting a vacuum cleaner hose into your pants pocket and sucking out your money?
    bisco, jrodz09 and aznkorboi like this.
  12. aznkorboi
    51
    22
    california
    hahaha we do have fur babies so maybe that's why
    I'm wondering how difficult it is to change. Haven't seen many prime people do it only regular prius.
    I know there are those two filters on the side of the rear passenger near the seat belt but that's it.
  13. jerrymildred
    11,508
    14,110
    Tampa, FL
    Easy enough to look up in the owners manual:
    Screen Shot 2021-03-11 at 8.02.11 PM.jpg Screen Shot 2021-03-11 at 8.03.36 PM.jpg
    jrodz09 and pghyndman like this.
  14. Georgina Rudkus
    3,166
    2,211
    Taylors, SC
  15. kmorosko
    kmorosko Junior Member
    Our 2017 Prius Prime did the same thing. At the time (a little over 18 months ago) the dealer claimed to have never seen one do this. After a brief discussion, the dealer replace the wheel assembly at no cost.
  16. HaiJinx
    HaiJinx Junior Member
    Los Angeles
    Hi All! I went to Toyota and they submitted a claim. I said I have 8 yr bumper to bumper warranty. The claim was approved and I am getting a new steering wheel on Saturday. It’s a manufacturing defect. I am surprised so many people are experiencing this problem.
    daisy555 likes this.
  17. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    My 2017 steering wheel is doing this and I don't use hand sanitizer and don't have a heated steering wheel.
    iPhone ? Pro
  18. Gokhan
    Gokhan Senior Member
    4,642
    1,863
    Paramount CA
    Hand sanitizer is detrimental for faux leather.
    I also suspect some hand lotions can also be a problem.
  19. jerrymildred
    11,508
    14,110
    Tampa, FL
    That's like making furniture that crumbles on contact with cotton.
  20. daisy555
    daisy555 Senior Member
    1,379
    579
    CT
    Do you have the specifics on the warranty that you purchased? I really wish 2023 steering wheel was leather.
