Mileage drop with new tires
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by High Mileage, Oct 25, 2020.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Slightly off-topic, but IIRC, Michelin Energy Saver A/S was all the rage in Gen3 times as the most Eco. Is it still the gold standard or has it been supplanted by something else?
  2. srivenkat
    596
    93
    IL
    I see these aren't offered in 195/65R15 anymore. Only in 175/65R15 for 15" rims.
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    According to TireRack specs the Nanoenergy A29s I believe you had are 1 lb lighter than the Ecopia EP422 Plus 640 tires you got, 17 lbs vs 18 lbs.
    That's approx 5.88% more per tire. Enkei claims each lb of unsprung weight is equivalent to 20 lbs sprung weight and if accepted that's equivalent to you gaining 80 lbs overnight...
    moto g(7) power ?
    #23 jzchen, Oct 29, 2020
    High Mileage and cirruspete like this.
  4. cirruspete
    cirruspete Junior Member
    75
    23
    Sonora, CA
    I want extremely low rolling resistance AND the lowest noise possible. Today's new issue of Consumer reports surprised me with a Kumho tire (Kumho Solus TA11) with the highest ratings for both criteria. The Kumhos edged out the Ecopias...
    Mendel Leisk and MTN like this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Thank you.
    Exactly the information I need.
    Looks like either would be a good choice.
    cirruspete likes this.
  6. High Mileage
    High Mileage Active Member
    136
    238
    2018 Prius Prime
    JZCHEN, thank you for the information on the tire weight from Enkei.
    I am in the process of working out a time to swap tires with Cirruspete who lives close to me. I now have ~1000 miles on the new Bridgestones and mileage continues to show a consistent loss of ~8 miles of electric range on my commute to work, and a loss of ~4 miles on my way home which roughly calculates to a loss of ~15-20% for electric driving.
    I called Costco where I purchased the tires. I had read some articles that it might be possible to return the tires if less than 30 days. The technician informed me that Michelin has a 30 day try and buy guarantee, BF Goodrich does not.
    This loss of mileage is killing me, hopefully testing tires from Cirruspete will confirm what is happening.
  7. High Mileage
    136
    238
    2018 Prius Prime
    Well Cirruspete and I swapped tires yesterday, my Bridgestone Ecopia 422+ tires with ~1K miles on them for his Dunlop Enasave tires with ~29K miles on them.
    I took a trip this morning along my normal route to work and can confirm that my electric miles recovered back to 42 miles. Temperatures here have dropped from the low 50's to 36 degf this morning so my battery efficiency is decreased, but I still managed 42 miles compared to my normal 44 miles prior to replacing my older Toyo's.
    So now the question will be what to do. Live with the loss of mileage for the next 60-70K that these Ecopia's should last? I paid $400 for the tires including mount/balance/lifetime road hazard coverage from Costco. Best price I have seen so far for the Toyo's is ~$100 each not including M+B and with no road hazard.
    See about purchasing some new Toyo's?
    Hope that mileage recovers slightly more as the tires wear-in? Not sure how much improvement I will see if Jzchen is correct about the increased weight of the Bridgestone vs Toyo and its effect on mileage.
    I am going to try contacting Bridgestone for the heck of it and see if they have any comments or suggestions.
    Oh and Salamander_King, I verified these tires are made in the USA.
  8. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Well at least we can somewhat confirm the issue with your swap. I got the tire weights from TireRack.com, after sorting out which version you got. The Treadwear ratings are not the same so I was able to match up the Costco version treadwear with the correct version on the TireRack website then compared the weights. Toyota OEM wheels are very heavy so you can gain back some by finding the lightest wheels you can to purchase. I replaced the wheels on the Prius v with Enkei RPF01 which saved a decent amount of weight. (I could barely lift the original wheels to put them into the Enkei boxes).... There are even lighter wheels from Volk Racing, (I'm going to get some CE28 Club Racers for my iQ to counter some of the added weight of runflats). But these are even more pricey. If you can swap the tires with lighter ones that would be the best because the tire is the outermost portion of the wheel and the worst place to add weight, with respect to moment of inertia.
    moto g(7) power ?
  9. High Mileage
    136
    238
    2018 Prius Prime
    So far it seems like I am the owner of 4 Bridgestone Ecopia tires, that I am disappointed with based on my loss of electric miles, and assumed hit on gas miles as well.
    Costco is unable to do anything. Goodyear has a 30 day buy and try program, Bridgestone does not.
    Bridgestone has a 90 buy and try program if you purchase through an authorized retailer, Costco is apparently not an authorized Bridgestone retailer.
    So if anyone who is not as mileage conscious as myself is interested I have a set of Ecopia's I would love to sell.
    Lesson learned for me is to stick with what came on the car if you were happy with them. If you were not completely happy with them I would say be careful of what you purchase.
    I know the Toyo tires performed well for me based on miles driven, and electric/gas miles. Cirruspete was kind enough to let me borrow his Dunlop tires and wheels for a few days to prove the issue is with the Bridgestones.
    I can only hope I recover some of what I lost as the tires wear in, or I may pull the trigger and buy a set of the Toyo's from Simpletire on the web if I can't stand the loss. For work I start a shutdown that will have me working everyday from now until Dec 23rd so I will have an opportunity to put 4K miles on the tires over the next month.
    Hopefully this thread helps someone not make the mistake I made.
    #29 High Mileage, Nov 18, 2020
    jzchen and Mendel Leisk like this.
  10. Mendel Leisk
    42,297
    These are Ecopia EP422 Plus? FWIW, I found Ecopia EP20 delivered excellent mpg, directly after install.
  11. High Mileage
    136
    238
    2018 Prius Prime
    Mendel, you are correct I am talking about the EP422+
    I see good reviews of the EP20, but if I do anything I will go back with Toyo's since I was happy with them, and I'm a little disappointed with BFGoodrich at the moment. Thank you for your comments as always.
  12. Mendel Leisk
    42,297
    If I'm ever shopping 15" all seasons for our 3rd gen, I might go with Michelin Defender (with whatever suffix it's currently lumbered with).
    I believe they're not leader of the pack for mpg, but they're not bad, they're very good for tread life and have decent road manners.
    But yeah if mpg is paramount, going with what served you well in past is a safe bet.
    Just be sure you are in fact getting the same tire. As an example, some Prius come from the factory with an Ecopia EP 422 Plus, that's made in Japan. If you look to replace with same in North America you'll typically find two offerings, one made in the States and one in Mexico. No problem there, except all 3 of these tire are distinct, with different tread patterns, wear index, dimensions.
    #32 Mendel Leisk, Nov 18, 2020
  13. High Mileage
    136
    238
    2018 Prius Prime
    Mendel, I had a set of those on our Honda Accord. My experience with them was meh. Costco did replace them for me as they did not last the 90K quoted, which I think has since been reduced. They seemed slightly loader and harder IMHO.
    So much of the tire comments are subjective to a certain degree.
    In this case I am just hyper focused on the loss of miles. Cirruspete commented he thought the Ecopia's were louder than the Dunlops he has.
  14. Mendel Leisk
    42,297
    I found EP20 DID get louder, as the miles accumulate.
  15. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    The funny thing is that PP also comes with Ecopia 422+ as OEM tires. My previous 2017 PP came with Dunlop Enasave. Now my 2020 PP has OEM Ecopia 422+. I do not see much difference in EV miles or gas mileage in those two cars.
  16. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    @High Mileage, I don’t know if Discount Tire/America’s Tire would take tires back after 1k miles, but they do have a pretty liberal return policy. Something to consider for next time I guess...
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    Your "sample" may be too small to draw any solid conclusions from.
    I hope so cause I just ordered a set.
    Consumer Reports rated them high for comfort AND mileage.
    A couple of more months should tell the story but other factors might be involved too.
    Colder weather might have an impact.
  18. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I went to TireRack.com to take a look at the Dunlop Enasave 01 A/S specs. Low and behold there are two versions! Was going to ask for more details BUT they both are listed at ONLY 16 lbs. From 17 to 18 is significant but 16 to 18 is huge!
    Did you get even better MPGs than with the Toyos?
    moto g(7) power ?
  19. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    How reliable are Consumer Reports' reviews? I'd go by TireRack's reviews over CR's.
    TireRack rates the Kumho TA31 (which were brand new on our used Prius Four) higher than the TA11 -- and both of them far down their list of recommendations for a 2015 Prius.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    In my opinion......at least as good as "reviews" posted by individuals in places like this. :)
    And since when does ANYBODY publish tire recommendations for a specific model and year of vehicle ??
    Except maybe off-road or "specialty" vehicles ?
    Then, the "best" tire for anyone on any vehicle depends a LOT or what your primary objective IS.
    Different strokes...........
