Mini VCI , possible using without laptop?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusToo, Oct 19, 2014.
  1. PriusToo
    PriusToo Junior Member
    84
    Charleston, S. C.
    With the mini vci to read codes,what would I need as far as other components to read codes on my car. I have not bought the mini vci yet.
    The only thing I own is a iPhone and iPad.
    Any thoughts?
    #1 PriusToo, Oct 19, 2014
  2. Patrick Wong
    18,210
    6,526
    With Mini VCI, you need a Windows XP or Windows 7, 32 bit OS computer. Obviously a laptop is more practical for mobile use than a desktop.
    You could probably buy a suitable used laptop on eBay for ~$100 or thereabouts. Replace the laptop battery and you will be good to go.
  3. PriusToo
    84
    Charleston, S. C.
    Thanks,
    Would there be anything else I could purchase that would work, being I'm limited in my electronics?
  4. Patrick Wong
    18,210
    6,526
    The Mini VCI is the best available device for Toyota vehicle troubleshooting, it will retrieve any DTC logged by any of the ECUs, and the price is a bargain.
    You will likely pay more for other potential devices and they will do less.
    Since you are an Apple consumer, a MacBook Pro with BootCamp will run Windows 7, 32 bit OS. That is what I use with my Mini VCI.
    PriusToo likes this.
  5. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    If you know IT people, ask them if they have access to any old 32bit Windows laptops? You might be able to get a free one.
    If you go the Windows route, Read this from the Tundra folks. Techstream ABCs and 123s: Reference point for all new users
    EDIT ADDITION. The Tundra link above contains a link for those who want to use a 64bit Windows Operating System.
    #5 exstudent, Oct 20, 2014
    ftl likes this.
  6. PriusToo
    84
    Charleston, S. C.
    Great idea, Not for sure I can afford a laptop pro Apple, they are so expensive.
  7. bgr
    bgr Junior Member
    If all you want to do is read general error codes, you can do this with a cheap code reader, or use free EOBD-Facile on your iphone in conjunction with a $15 wifi (not bluetooth) ELM OBD adapter. I carry the latter in my car in case I get a CEL away from home.
    The mini VCI will obviously do lots more. It all depends on what you need.
  8. exstudent
    2,214
    906
    Torrance, CA
    Agreed, it all depends on what OP wants to do.
    General generic OBD2 code readers (ie Elm 327) will work, but has limitations. Many people have reported numerous times of junk codes from a generic OBD2 reader. Going to a dealer for any diagnosis/have codes read, costs $100 in my area.
    If OP wants to do some more "robust" DIY maintenance, mini VCI is a must! If he wants to bleed brakes, mini VCI is a must; otherwise its a PITA to attempt to do the traditional way.
    My post #2 may help OP to figure out which one to get. A comparison of ELM 327 vs BAFX OBD2 vs mini VCI. LINK
    OP is encouraged to hit up IT friends, craigslist, Tigerdirect for refurb and off lease laptops. BlackFriday and Cyber Monday sales coming soon too.
  9. JC91006
    16,937
    8,647
    I use a windows based netbook with windows 7 32bit OS. I believe the netbooks are so slow and outdated, you can get one really cheap. These netbooks are great because they are very compact and light......does everything you need it to do with a miniVCI cable and software.
    I also have an really old and heavy Dell with XP 32bit OS with the minivci software installed. If anybody needs one, I have it for sale.
  10. PriusToo
    84
    Charleston, S. C.
    I like all the ideas, JC yours might be the most simple.
    I just want to know things like if I'm on a long trip and I get a check eng light, I would like to know what it is.
    Mainly something like the inverter coolant pump not working.
    Can you have it all hooked up and in real time, pull off road and see the code?
    Thanks
  11. JC91006
    16,937
    8,647
    The Prius is really a very reliable car, you won't see many warning lights pop up. What you read on here is not exactly the normal case in an everyday Prius.
    Hanging out at these forums is not a good thing if you are paranoid about breakdowns. It'll just make you more paranoid.
    And yes, having a minivci in your car will give you real time information, including diagnostic codes.
  12. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    For the sake of curiosity I dug out an ancient Windows 98 SE laptop and loaded the VCI drivers, and Techstream. This has an 8gb hard drive and 125 mb RAM. This works perfectly if a little slow, so any Windows laptop later than this will work including XP,Vista, 2000, and Millennium.
    John (Britprius)
  13. PriusToo
    84
    Charleston, S. C.
    Not paranoid my friend, just being pro active, thanks for the mini vci tip.
    The paranoid may apply to some other people on here, but that I am not.
    #13 PriusToo, Oct 20, 2014
  14. exstudent
    2,214
    906
    Torrance, CA
    Link to Toyota Techstream minimum requirmenets. And as Briprius points out, even something far less than Techstream's minimum requirements still works. Plenty of "obsolete laptops," out there.
  15. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
