Misfiring mystery
Discussion in 'Generation 1 Prius Discussion' started by mo_, Apr 24, 2015.
  1. Jeff F
    Jeff F Member
    111
    38
    London, Ontario
    2001 Prius
    See Tech is stumped. What causes this misfire? | Page 3 | PriusChat
    This was my experience exactly, and it turned out to be a rotten fuel filler neck that was allowing rain water thrown off the rear wheel to contaminate the fuel tank.
  2. Kstoner
    Kstoner New Member
    Utah
    Anyone know what the fix was to this issue? I have a seemilgly bad cylinder in a 2008 with 180k miles. Getting a P0301 and a flashing CEL. I’ve swapped every sensor that is related to ignition or fuel. I haven’t checked the fuel pressure yet. Suspecting a bad valve or rings.
  3. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    Kstoner, this thread is going on 4 years old, and if all you have is a single cylinder misfire, then there isn't a "this issue" as if you have the same one. In addition, this is the Gen 1 forum, while you have a Gen 2.
    You should start your own thread in the Gen 2 forum and provide as much detail as you can - stuff like mileage, maintenance history, etc.
    Note that the P30xx codes are called "misfire" but should be named "miscombustion." They are just sent when the a/f mixture doesn't explode. This basically happens for 4 reasons: no spark, fuel amount is off (none, too little, or too much), air amount is off (too little / too much), not enough compression. I don't know what "swapped every sensor that is related to ignition or fuel" means, but often the best thing to start with for any single cylinder misfire code is a compression check. That will tell you about rings and valves.
  4. ronlewis
    ronlewis Active Member
    986
    196
    texas
    2001 Prius
    So far, I think you've been their MO. Look in the valley around your injectors for gas. It's easy to not get the injectors in correctly and cause a leaky o-ring, which would give you the gas smell. Take off the air cleaner to see in there.
