More problem's with my new Prime - Leaking rear hatch window :( *update 1.30.17*
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by thatoneraccoon, Jan 23, 2017.
  1. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    well glad you caught it, keep salt and water out from in there.
    cant imagin a little hole causing such a problem as ive had. Just got back from taking the Prime for a drive, it was great! and smooth and no problems.
  2. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Man, would not that be something if that was the problem the whole time...and an easy fix. I think I would stay with this new dealer. Also, gives the rest of us something to check on if and when we get our cars. Happy for you and your car.
    thatoneraccoon likes this.
  3. bwilson4web
    16,217
    Excellent! So where will your car be parked the day before April 1st?
  4. Prodigyplace
    12,564
    11,779
    Central Virginia
    Perhaps your car is not as "finely tuned". :LOL: :D
  5. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Picture ?
  6. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Another thing that can happen is that you can get water into there or into the wheel hubs and this can cause the car to be unbalanced. In the northeast this is always a fun time of year because you don't know if your car has gone crazy or the crazy weather has gone for your car. My truck would make a thunking sound on right turns after a really bad snowstorm because for some reason the right side hubs would collect ice but the left wouldn't. I bet if I backed into my yard once in a while it would reverse the effect since the left side gets morning sunlight in the winter which helps melt things.
    If your weather changed and they put in plugs it is possible that something had been up there that melted out and is now sealed properly. Lets hope that is all that was happening and everything is good now. But now that you mention plugs, I have to wonder if my car has them installed since I took 2 days after my vehicle was dropped off the truck and it had clearly not been prepped yet, they hadn't even plugged it in before I drove it home.
  7. Mendel Leisk
    41,463
    On 3rd gen they're here (just inboard of rear scissor jack position):
    Reinforced plate, good location for safety stand placement, btw.
    thatoneraccoon and I'mJp like this.
  8. Mendel Leisk
    41,463
    I wonder if these serve similar function, circled in blue? Next time I'm under I'll take a better look. If you pop out the rear caps, there's not a sharp edge, the corner is double layer, and the inside has a rounded, reinforced edge.
