More problem's with my new Prime - Leaking rear hatch window :( *update 1.30.17*
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by thatoneraccoon, Jan 23, 2017.
  1. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    I bought that deal for a new car and used it once over 10 years of ownership. It ended up not saving me money because Firestone will not work on rear alignment problems, and I buy long life treads ;-)
    #101 EV-ish, Jan 28, 2017
  2. bwilson4web
    16,217
    I understand and it is an individual decision:
    • At 5k (this time 2k) - change engine and transmission oil with samples sent for analysis. Toyota.
    • At 5k - change both with samples sent for analysis.
    • At 15k - change both with samples.
    • Thereafter, engine oil changes late Spring and late Fall. Alignment checks every Spring to deal with pothole effects.
    It is how I am because of previous Prius performance.
    thatoneraccoon likes this.
  3. Db17
    Db17 Member
    188
    92
    Visalia, CA
    And what has your previous oil analyses revealed?
  4. bwilson4web
    16,217
    I have only tested transmission oil since there is no filter, just a screen. I found at 5k, a remarkable population of early wear particles and sealant beads. The dissolved elements suggests a 20-30% carry forward. Some evidence of grinding down to smaller particles.
    At 15k miles, the oil was not bad but for the ground particles. The oil looked not bad.
    At 35k, it was pretty good without any significant particulates and excellent viscosity.
    So this time I am starting the changes early to get the early particulate materials out.
    Felt likes this.
  5. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Yeah, I am thinking I will even try a different toyota dealer. The service department where I bought at keeps letting me down.
  6. thatoneraccoon
    201
    146
    Ohio
    That's not too bad a price really
  7. thatoneraccoon
    201
    146
    Ohio
    Sometimes I feel I go overboard with my engine and transmission oil changes.
    I was thinking of doing 25k transmission fluid changes on mine and 5k Oil Changes
    and because of the particulates I think I will also do a 2k oil change maybe the transmission
    was there particulates on the transmission fluid at 5k when you sent that in for testing?
  8. Prodigyplace
    12,564
    11,779
    Central Virginia
    See post 104 for your answer.
  9. thatoneraccoon
    201
    146
    Ohio
    I totally missed it said transmission. I was thinking oil. lol
    Prodigyplace likes this.
  10. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Part of the problem might be that a lot of the mechanics at Toyota dealership have not caught up to the Prime yet in knowing what to look for when things go wrong.
  11. thatoneraccoon
    201
    146
    Ohio
    Yeah true, it is another drawback of getting a new model
  12. Trollbait
    12,543
    A con of the plastic panels on early Saturns was that they needed larger gaps than steel to allow for expansion. That's my first thought on hearing about your panel gap. It likely doesn't apply to carbon fiber, though. If it isn't normal, then it is probably related to the handles being reversed, and fixing them might fix the panel.
    I feel you do to:D
    Toyota's recommended 10k oil change could be excessive with a hybrid, let alone a PHEV. I go around 7500 miles on my ICE car following the oil monitor. A Volt can go up to 2 years between oil changes.
    There were reports of the transmission fluid having a burnt smell in gen2 Prius. So some adopted 30k change intervals. I believe the fluid used is Toyota's standard automatic transmission fluid. Those are susceptible to heat, because they have to work as an hydraulic fluid in addition to a lubricant. The HSD transaxle isn't an automatic though, and I suspect the heat stressed fluid wasn't an issue for it. Either way, the gen4 has improved cooling of the transmission fluid.
    If it helps your piece of mind, an early initial change on a new car won't hurt it, and only result in a little more oil used and cash spent.
  13. thatoneraccoon
    201
    146
    Ohio
    Thats awesome they have improved over the gen2 and the gen2 I thought did a decent job.
    Whoever bought my Volt got a well maintained car :D I did oil and tire rotation at 5k with it as well. I was going to do a transmission flush at 35k but I ended up trading it in on the Prime *lol* :D so maybe I can revise these numbers. it will be interesting too see what how the test results look like when Bob's sends them in and how bad a shape the fluid will be in.
    also buckeye Toyota still has their Prime, so I drove down and took a look and mine is definitely not right sadly. The trim and panel is flush and nice to the window, no way could I get my finger or hand behind it.
    #113 thatoneraccoon, Jan 28, 2017
  14. bwilson4web
    16,217
    I don't know about the Gen-2 as I've only owned a Gen-1 and Gen-3:
    To me, it smelled of paraffin and was dark and opaque. Here is a photo of the oil sample, the dark bottle:
    The full description including oil testing results are found here: 2003 Prius - Cold Weather and Transaxle Originally, I was interested in the cold weather performance of the Gen-1.
    Based on the Gen-1 experience, we front-end loaded the transmission oil changes to get the early wear debris out early and then relaxed the interval because subsequent tests showed it was an effective technique (see attached oil analysis.)
    Not my recommended practice. It looks like two early changes effectively flush the initial wear debris which appears to be the root cause. Without material to crush and grind into a fine, smoke-like material, the oil does not suffer the local heating and shear-down (loss of viscosity from mechanical action. There after, it becomes a +100k oil because it only has to deal with the distributed stresses of the excellent gear surfaces.
    The type WS transmission oil has more in common with aircraft turbine oil than anything else I've found. It may have similar characteristics to hydraulic oils but this is not something I've studied. Just I've not found any hydraulic pumps or motors in the Prius eCVT transmissions. I really see it as a low viscosity lubricant.
    IMHO it was the early manufacturing and wear debris that was the problem. One clue being the silicon-based sealant that was revealed in abnormally high silicon content in the used oil tests. Initially the relatively large particles, each time they pass through the gear surfaces, are crushed to smaller and smaller pieces and these fine particles cause local heating of the oil and stresses fracture the oil into a lower viscosity material (i.e., shear down.)
    The methodology I followed was pretty important:
    • Canadian fleet studies of hybrids quantified the effect of cold on hybrid performance.
    • Testing Amsol claims (**EXCESSIVE YELLOW METAL WEAR**) led to an early change.
    • Based on cold temperature roll-down metrics, I found a measurable reduction in rolling drag.
    • Soliciting more samples from the "Prius Technical Stuff" community increased the sample size.
    • This led to understanding the wear characteristics
      • A pivotal test revealed the silicon leaching into the oil.
    I do not claim perfect knowledge and we've moved beyond our Gen-1 and Gen-3 Prius. We have a Prius Prime and BMW i3-REx on the driveway and limited windows for cold weather testing. But a sunny day, it has warmed up nicely and our doggies are interested in visiting the dog park.
    #114 bwilson4web, Jan 28, 2017
    Mendel Leisk and thatoneraccoon like this.
  15. thatoneraccoon
    201
    146
    Ohio
    Bob, I am curious, what is going to be your fluid change intervals on the Prime?
  16. bwilson4web
    16,217
    I am planning:
    • 2k
    • 7k = 2k + 5k service
    • 17k = 7k + 10k service
    • 37k = 17k + 20k service (optional)
    This is a log scale with oil testing. The accelerated rate is based upon what I saw in our Gen-3 oil changes with the goal of achieving a steady-state, low wear rate, earlier in the Prime life.
  17. Trollbait
    12,543
    In the Prius it is a low viscosity lubricant, but it is also the fluid used in Toyota's automatic transmissions.
  18. Mendel Leisk
    41,463
    Interesting. I looked up 2010 Corolla Owner's Manual, and indeed: GENUINE TOYOTA ATF WS is the spec'd fluid for the automatic, and there's the caution that using anything else could damage the transmission.
  19. Trollbait
    12,543
    I was just looking to see what other transmission fluids Toyota used, and it appears all their current models have been transitioned to WS. At least the automatics.
  20. thatoneraccoon
    201
    146
    Ohio
    I think I will do this as well
