More than one fuse blown?
Discussion in 'Prime Technical Discussion' started by 17primesilver, Jan 5, 2018.
  1. 17primesilver
    17primesilver Junior Member
    17
    San Jose
    I am just about one month in owning my first Prius (prime). I tried to install an upgraded usb receptacle so that I can get quick charge. I was trying to tap the power source from qi plug using the dark blue wire, but I accidentally shorted it, so the fuse was blown. After replacing the ecudcc no2, I am still left with dark tv(?) and power mirrors don’t work either. Qi charger also doesn’t work. I checked all the fuses, and I must miss it or something else went bad, anyone has any tips? Thanks
  2. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    Disconnect the battery before play with wires maybe?
    iPhone ?
    muleman and priuscatprimeguy like this.
  3. 17primesilver
    17
    San Jose
    Yeh obviously, except that I had to run power anyways to use a voltmeter to see which wire does what and I shorted it during that time. So an accident is an accident. Thanks anyways I did find another fuse that was blown and now everything is fixed.
    Interesting enough I see this device with no marking and wonder what the hell is it
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    The wires are also identified in the Electrical Wiring Diagram, available by subscription to techinfo.toyota.com.
    See this previous thread.
