MPG ratings for PHVs are stupid
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mozdzen, Jan 21, 2013.
  1. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    I'm getting about 122.1 MPGe and 47.6 MPG. USB and I can now compare the true performance of our cars without the ever changing price of fuels clouding the issue. Now we can discuss the driving styles and route differences that allows his PiP to be more efficient than mine.
    usbseawolf2000 likes this.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
  3. John H
    John H Senior Member
    2,208
    558
    I would inject that your comparison should also include your differences in cost of fuels. USB pays out the nose for electric which influences his charging strategy, driving styles, routes, etc ... and thus his choice of vehicle.
  4. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    If I'm going to buy a new plug-in car, and I know I travel route #1 80% of the time and it is X miles, and I travel route #2 15% of the time and it is Y miles, (5% misc driving) then what numbers do I need to estimate my fuel usage? MPGe is useless to me, especially when X or Y may be less than the Electric range of the car.
    Then again too many people can't do math, so it is dumbed down for them into the MPGe number.
  5. lensovet
    2,615
    496
    Burlington, NJ
    if you go to fuel economy.gov, you can plug in your own numbers including costs and it will calculate this stuff fro you.
  6. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I think the MPGe rating is really useful to people who truly want to go green, meaning using as little energy as possible to accomplish something.
    If you have 2 cars, both having a 20mile range, but 1 car only requires a 3kWh battery, and the other requires a 6kWh, you can see where this is going. This would affect charging time, and people with solar panel installs would probably care about this # as well. MPGe basically tells you how efficient your EV is. This # doesn't matter to most of us (range is almost always the first # we want to know), but it can be useful, especially once EVs are more common.
    lensovet likes this.
  7. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    In fairness, it is a new and evolving technology and EPA and DOT metrics will evolve also as they have with the regular vehicle MPG.
    I would like to see EPA add an EV Range number so people can do the math for their situations.
    Comparing Prius to Volt to Energi where each has different EV ranges and MPG's as hybrid.
  8. Zythryn
    Zythryn Senior Member
    6,409
    4,409
    They already have the range listed. It is immediately underneath the fuel efficiency and above the estimated annual fuel cost. New Fuel Economy and Environment Label
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I must apologize for the long post.
    MPGe considers 33.7 kWh of electricity to be equivalent as a gallon of gasoline, derived from the energy content. Since gasoline combustion is inefficient (39% max in Prius), the miles you get out of 33.7 kWh of electricity is about twice more than you would get from a gallon of gas.
    Generating electricity from fossil fuel also require inefficient combustion at the power plant but that's ignored because EPA numbers are vehicle efficiency (nothing to do with fuel production). That's why I don't like MPGe. If you hook up a generator to Prius gas engine at the power plant and run Leaf with it, you'll get 99 MPGe, per EPA. However, a regular Prius is rated 50 MPG. That's how deceiving MPGe is.
    Another issue is combining both the MPGe (electricity) and MPG (gas). This composite figure will be higher the more you use electricity due to the nature of inflated MPGe number. However, the low gas MPG can also drag it down. Generally, the plugin with a bigger battery will be able to better inflate the number.
    That's why SAE recommended to separate both numbers and not combine them. You need the breakdown of both fuels to really see the efficiency of both. For my PiP, I am getting 128 MPGe (263 Wh/mi) on electric miles and 54 MPG on gas miles. No other plugin can match this efficiency breakdown nor the cargo space.
    Choosing a plugin comes down to two fundamental questions. How much gasoline do you want to displace with electricity? How much efficiency and cargo space are you willing to give up to do it?
    Looking at various plugin cars, we know the first 11 electric miles does not impact efficiency nor interior space. PiP is still rated 50 MPG on gas with no compromise in cargo space. It looks like the new Accord plugin (13 miles range) has 1 MPG lower in gas mileage and the trunk is smaller. Ford Energi plugins has 21 electric miles and 4 gas MPG lower (smaller trunk as well). Volt has 38 electric miles with 13 MPG lower than PiP and it gave up one rear seat with only a compact car interior.
    The more you want to use electricity, the more you'll have to compromise (price included). Where do you draw the line? It'll depend on your driving distance/pattern as well as the charging pattern. I have pointed out before that you can mitigate EV range with opportunity recharges but you are stuck with the interior and cargo space.
    EPA and SAE worked out a general number based on statistic so chances are that, you will be close to it but YMMV. PiP covers 29% of the miles with electricity. Ford Energi covers 48%. Volt covers 64%. The higher percentage you want to cover with electricity, the less interior space you'll have (and the lower gas engine efficiency).
    Emission is another consideration. EPA included production of both gasoline and electricity to compute and they came out with these figures. PiP is rated 210 gram of CO2 per mile. Both C-Max and Fusion Energi are rated 240 g/mi. Volt is rated 260 g/mi. Leaf is rated 230 g/mi. A regular Prius is rated 222 g/mi. Those numbers are based on the emission weighted by kWh generated in all states in the US. The data is a bit outdated and the latest data shows there is about 5% improvement in the grid mix.
    The reason I bought PiP is to accomplish two goals. Reduce emission and displace gasoline with electricity (40% of my miles so far). I am able to do both without compromising interior space and I still get a flat cargo floor. I just gave up a spare tire.
    Tracksyde and mmmodem like this.
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It shows both the electric and gasoline driving range. For blended plugins, EPA shows Electricity+Gasoline since both can be used as more power is needed. The breakdown of each fuel used is also shown.
    iClaudius and lensovet like this.
  11. John H
    2,208
    558
    Electricity comes from many other sources that fossil fuel.
    iClaudius likes this.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yes, it can come from many other sources. Currently, 2/3 of it is from fossil fuel.
  13. lensovet
    2,615
    496
    Burlington, NJ
    oh god not this argument again
  14. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    Right now, we are not importing fossil fuel. Reducing gasoline demand will reduce global tensions.
  15. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    I clicked on the link and didn't see the breakdown. I also looked in the other tabs. Wasn't obvious where they put it.
  16. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    Agreed. If you look at the fuelly.com stats for the PiP, you'll see numbers ranging from 48 mpg to 171 mpg. Their bar chart is too small to display this immense range.
    Now I'm going to get more particular and say I want more than two numbers (EV range and mpg in HV mode)
    I want a graph of EV range vs speed and an mpg graph vs speed.
    I'd like even more, like EV range when driving below 40 mph vs number of stops per hour, but I really want two graphs with an "effective" number for each graph.
    I'm not sure Toyota even publishes something like that. Why wouldn't they?
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Scroll down. It is below Annual Fuel Cost. You can simply search for "Driving Range" on that page.
    Oops, you were asking about the breakdown of the two fuels. It is in the Miles per Gallon Equivalent row.
    Below is for PiP.
    Electricity + Gasoline
    95
    Combined
    .2 gal/100 mi of gas plus
    29 kW-hrs/100 mi
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It is a valid point but when does it become diminishing return?
    A 25 MPG midsize would use 6,000 gallons. 50 MPG Prius cut that in half, saving 3,000 gallon. PiP (29% EV) will cut 870 gallon on top of Prius. Ford Energi (48% EV) will cut 1,186 gallons on top of Prius. Volt (64% EV) will cut 1,540 gallons on top of Prius.
    The gallon saving between these plugins are 354 to 670 gallons. That's it! Electricity usage (emission increase and charging time) between them are very noticeable.
    Looking at the big MPGe numbers, one would think the difference in gasoline displacement for plugins are much greater than a regular hybrid. In reality, regular hybrids have the best bang for the buck. Plugins are incremental improvement, if designed properly. If not, it can actually increase emission.
  19. Zythryn
    6,409
    4,409
    90% of your post is off topic, I do want to address this on topic part though.
    Do you find a screwdriver deceiving because is makes a rotten hammer?
    MPGe is a wonderful tool as long as you use it for the job it was designed for.
    It is there to give a comparison with gasoline based on energy content. Not a comparison of GHGs, or cost. Just simply how far you can go on the energy content of the electricity converted into gallons of gas.
    It gives a common yardstick to allow people to compare different vehicles, or the same vehicle at different times.
    If you want to compare GHG emissions MPGe is the wrong tool.
    If you want to estimate fuel costs, MPGe is the wrong too.
    If you want to compare the vehicle efficiency between different cars, MPGe is a good tool.
    iClaudius, lensovet and 34Hupp like this.
  20. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    still way too cryptic.
