My EV Driving ratio
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Oct 31, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Alright, anxiously waiting.
    52,858
    i hit 50/50 lifetime! 3230 ev and 3170 hv. you can see my stats (including the winter gas mpg's:( ) on the spreadsheet, as soon as ken converts them.
  3. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Update at 2,615 miles: EV 40% and HV 60%
    Electricity efficiency: 263 Wh/mi (128 MPGe)
    Gasoline efficiency: 54 MPG
    Jeff N likes this.
    52,858
    looking good, but you need to take some electric scenic tours in your free time!:D
  5. Clearwater Blue PIP
    Clearwater Blue PIP Junior Member
    36
    Arizona
    Hit 50/50 today (lifetime). Which is very good, considering my 55 mile commute includes some 75mph freeway driving. And, I can't charge at work.
    usbseawolf2000 likes this.
  6. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    135 MPGe on electric miles and 60 MPG on gas miles!
    How do you do 50:50 with only charging at home? 55 miles round trip?
  7. Clearwater Blue PIP
    36
    Arizona
    All of my weekend driving is EV and I make it a point to charge anywhere and everywhere I can find an outlet. But during the week, toggling yeilds the best results. EV for accelerating up to speed and HV for cruising. Oh, and 44 psi and lots of coasting. I am thrilled with this car.
  8. bisco
    52,858
    well done! i'm loving winter, less driving means a higher ev/hv ratio.
  9. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    Just had to fill the tank.
    What is the MPGe equation again?
    Also, do we have a PiP 1000 mile tank club? I know it is not too hard on the pip but is still a cool achievement.
    rogerv likes this.
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    MPGe = Electric miles / gallon equiv
    MPGe = 483 miles / [(120 kWh * 1.15) / 33.7 kWh] -- adding 15% charging loss and dividing by 33.7 kWh equivalent of a gallon
    MPGe = 118
    Your gas efficiency is 429 miles / 6 gallon = 71.5 MPG. PiP shows only the integer so it could be 6.9 gallon. In that worse case, you are getting 62.2 MPG
    Very good figures.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I would argue, based of the detailed measurements I did a couple of weeks ago, that the charging losses are closer to 10%. I've yet to see anyone do any actual measurements that show it is 15%.
    Charging efficiency of PIP | Page 2 | PriusChat
    Mike
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I agree that 10% loss is a good general number for 240v L2 charger per your measurement.
    Would you agree that 15% loss is a general number to use for 120v charger that bundled with the car?
  13. bisco
    52,858
    we should, it's very difficult for those who can't plug in a lot or drive long distances.:)
    rogerv likes this.
  14. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I'm just about to hit 1000 miles on one tank for the first time, with 11K miles on the car. Usually longer trips pop up to offset my in-town miles and I only get 700-850 per tank. I have never charged anywhere but in my garage. My lifetime ratio is now 29/71, so I am really impressed with you guys showing 40-50% and higher EV! (y)
  15. 3PriusMike
    3,101
    2,421
    Silicon Valley
    No. That is a 50% difference. At best 220v is 10-20% more efficient than 110v. When I was doing my measurements I found about 9% in losses in total. About 2/3rds of the kwh were from 220v L2 and about 1/3 from 110v at home. So maybe it is 8% losses with L2 and 10% losses with 110v -- too much noise in the data to get this precise.
    Mike
    usbseawolf2000 and lensovet like this.
  16. RBooker
    RBooker Member
    154
    56
    I think the attached graph is very interesting. Illustrates the effect of speed on battery consumption. The data is for a Tesla Roadster. I would imagine the shape of the data for the PIP would be similar.
    Here is the article.
    Tracksyde and JamesBurke like this.
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Is that with the EVSE plugged in overnight?
    The reason I am hesitant to use 10% is not because I question your data. The reason is because EPA said PiP charging loss is 17% (3.2 kWh needed to charge ~2.74 kWh usable). I am just trying to figure out the disparity.
  18. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Roadster has 0.35 Cd but PiP has 0.25 Cd so things will look different past 50-55 mph.
    Also, the Wh/mi on the graph is a measurement without the charging loss. EPA includes charging loss to calculate MPGe for the electric miles.
  19. RBooker
    RBooker Member
    154
    56
    I assume Cd= drag coefficient.
    I was hoping to use the graph to inform my driving style in order to boost my EV/HV ratio.
    Based on the graph:
    Avoid creeping (<3 mph)
    Keep in mind the difference in battery draw of 30 mph versus 65 mph
    Tire pressure has a bigger impact at low speeds
    Question: In a standard Prius I assume the most efficient traveling speed would be close to the trigger speed for the ICE (~42 mph). Given the the ICE trigger speed for a PIP is ~62 mph how should one go about estimating the optimal speeds. Given its relatively low Cd I assume the PIP's power curve is shallower allowing you to draw less than 150 wh/mile even at 35-40 mph.
  20. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Yes and no. Friday and Saturday nights I had the EVSE plugged in overnight, timer set to charge at 6am. But both days I charged a second time as well. But I've measured the power consumed while plugged in and waiting and it is only 1.4 watts. So even assuming 8 hours of "waiting time" for a ~3 kwh charge that is only an additional 11 watt hours or 0.4%.
    I have no idea how the EPA gets 3.2 kwh. I have never gotten anywhere near that.
    Mike
    lensovet likes this.
