MPGe
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jonny Zero, Sep 8, 2014.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I have a question about MPGe. Is the KWH measured at the meter, or coming out of the battery? In other words, does it account for the conversion loss when charging the battery?
  2. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    This topic has been covered, but most here are sure it's the latter. My [casual, non-scientifically verified] observation seems more consistent with the AC supply draw.
  3. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    EPA's MPGe calculations are based on electricity as measured at the wall socket or utility meter.
    CaliforniaBear likes this.
  4. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    What interests me more than MPGe is pence/mile travelled because that is what I pay for! It's ok for you transatlantic cousins who have fuel at $1.10/litre but over this side of the pond it costs the equivalent of more like $2+/litre so you can see what the incentives to drive electrically as much as possible are. For interest my fuel price last week was $2.10/litre and my marginal electricity cost is 17.7cents/kWh.
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I agree its kWh from the electric company. When you fill your car with gas and happen to spill some (naughty), or some is sucked back up because you try to over fill, you still have to pay for the undelivered gas.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...wow that's a fairly cheap electric cost for you considering everything is more expensive over there. My cost is 12 cents but some places like Ca and NY are closer to 25 cents which is closer to break even gaso/electrons.
  7. CaliforniaBear
    1,180
    289
    Northern California
    California can be as low as $0.10/kWh on the PG&E EV time of use rate. With solar panels to reduce your total kWh, other rate schedules can provide costs under $0.15/kWh.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I am paying 18.5 cents per kWh. Gas price around here is some of the lowest in the nation. Yesterday, I saw $3.09 for regular gas.
    Even then, electricity is 2/3 the cost of gas per mile.
  9. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...that's amazing low gaso cost considering NJ is the more expensive Reformulated Gasoline.
    Obvioulsy the NJ ban on self-serve stations does not seem to impact cost either.
    Good deal! I should not have implied everyone paying ~25 cents in Ca.
    #9 wjtracy, Sep 9, 2014
  10. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Hadn't seen this before, but could be useful for estimating costs:
    PHEV Fuel Economy
    usbseawolf2000 and Jonny Zero like this.
  11. CaliforniaBear
    1,180
    289
    Northern California
    It seems to be reasonably accurate. I used the detailed driving option.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I used the simple driving form.
    17 miles for typical day and 10,000 miles annual. 19 cents per kWh with 110V charging. $3.20 for regular gas and $3.5 for premium gas.
    BMW i3 REX = $624
    Accord PHEV = $629
    PiP = $630
    Regular Prius = $640 (100% gas @50 MPG)
    Volt = $730
    C-Max Energi = $762
  13. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Using 110 volt charging is not a valid assumption if you own a BMW i3. Using 220 volt changes the cost to $556/yr. I can't imagine anyone buying a car that takes 19 hrs to charge on 110 volts being too frugal not to get a 220 volt EVSE.
    I have a 2014 Prius pip and a i3 Rex and i pay 12 cents/kwh. My i3 cost is $352 for 10000 miles. Actually I am doing even better than that as I am getting closer to 4.4 miles /kwh as opposed to the 3.4 miles/kwh used by the calculator. Based on my data I am looking at $274 for 10000 miles in my i3.
  14. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Interesting MindMachine can you briefly say why 220 v is so much cheaper and how much time does it cut off on the 19-hrs benchmark?
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Good point. The calculator takes account of charging time and resulted in using less gas with L2 charger. That's why the difference is significant.
    BMW should bundle L2 charger with the car.
    If I use NJ fuel cost (18.5 cents / $3.2 gallon) with my first year of ownership data (in NY), PiP would cost me $528 to drive 10,000 miles. I got 75 MPGe in the first year with 44% EV ratio. I added 15% charging loss to the kWh reported by the car.
    Does your 12 cents/kWh includes both the supply and distribution, etc charges? Also, 4.4 miles / kWh includes charging loss?
  16. CharlesH
    2,798
    1,166
    Roseville, CA
    My electric cost varies from $0.05/kwh at tier 1 off peak to about $0.47/kwh at tier 3 peak (San Francisco Bay area, California). I don't charge during tier 3 peak.:)
  17. CaliforniaBear
    1,180
    289
    Northern California
    Yes. However, the kWh you use off-peak may add to your total kWh and "push" some number of kWh into tier 3 from tier 2 and into tier 2 from tier 1. If you stay within the baseline every month this effect doesn't happen. How does this happen? When your total exceeds the baseline (tier 1) amount all subsequent kWh are charged at the tier 2 rate, and the same for when your total exceeds tier 2. Now if that happens on the last day of the month it doesn't make much difference to the total but if it happens mid-month you could be effectively being charged higher tier rates for your off-peak charging due to the "push effect".
    If you have a solar installation there is a good chance you can stay within the baseline for most months. In 18 months I have only had a few kWh in tier 2 during the last 10 days of one month.
  18. CharlesH
    2,798
    1,166
    Roseville, CA
    My summer electric bills tend to be about $80/mo, even with charging my PiP every night. My understanding is that with an electric bill less than $100/month, that one cannot really justify solar. And the thought of installers stomping around on my clay tile roof is painful.
  19. CaliforniaBear
    1,180
    289
    Northern California
    We live in the Sacramento area so lots of A/C in the summer also lots of sun. Our annual total electric bill was $1200 before adding solar but without the PiP. The first full year with solar it was $232 including charging the PiP at average of 3.1 kWh per day (that is, sometimes charging more than once a day and not using all the charge every trip). The solar installation on our tile roof cost $12,000 so I see about an 8% return on investment. Of course there was more sun in the past year than would be normal so I expect the total bill will be higher some years.
  20. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Yes my total cost actually varies do to add on charges that are not proportional, but essentially my Total electric cost is about 12.5 cents per kwh.
