mud flaps with aero spoiler
Discussion in 'Prius v Accessories and Modifications' started by newcarsmell, Jul 21, 2015.
  1. newcarsmell
    newcarsmell Junior Member
    northern wisconsin- southern texas
    2015 Prius v wagon
    hi all,
    newbie here, we took delivery of our Prius v three yesterday. so far, 190 miles and loving it. it replaced a 2006 rave4.
    my question is has anybody put on mud flaps on the "v" that has the aero spoiler on it? the set I am looking at on eBay from a Toyota dealer says you have to trim the spoiler approx.. 2 inch's to make them fit.
    I consider myself handy, but don't feel comfortable to start cutting on it right away. any other solution's to this?
    also, I want to put a hitch on it to carry a lightweight cargo carrier. all I would carry in it is my surf fishing equipment, maybe 30lbs. tops. would the spoiler conflict with that?
    thanks in advance, I am really pleased that I found this forum.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,454
    6,556
    Texas Hill Country
    They fit without mod on my 2012 and probably do so through 2014 since there were no body changes. See pic. A 2015 does have some changes and might require trimming of the guard. If it were me, I would wait until someone had a mud guard that fit without trimming.
  3. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    Welcome to the forum newcarsmell
    I posted pictures of my mudguard with the cut piece.
    black 2015 prius v four | PriusChat
    Used blue tape to tape it up where u will cut, then use a marked to mark the line to cut. It better to cut it short and make the adjustment by sanding. If you cut too much then you are out of luck.
    I used a small hacksaw to cut it. A coping saw works too. Make sure u angle it so it look professional.
  4. sean v4
    Corona, CA
    2015 Prius v wagon
    Oh u will need to remove a few the plastic clips so that u can bend it to cut it.
    Here a picture of the clip. Just get a small flat head and pry the inner plastic round piece about 3mm then pull out the whole clip.
  5. sdiesel619
    sdiesel619 Junior Member
    Just an FYI to all. there is a new part number for the 15-17 Prius v. It fits without mods. PU060-47115-P1. Just bought mine today and will install this weekend.
  6. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Or you can 3D print your own mudflaps (front shown):
