My Prime's first transmission fluid change :D
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by thatoneraccoon, Feb 9, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    A '58 Volkswagen only has 11 total parts.
    bruceha_2000 likes this.
  2. Mendel Leisk
    42,373
    And every one of them very well documented. :)
  3. Jasonheng15
    Jasonheng15 Lowered Prime
    65
    77
    2nd gen did. I did a drain and fill last yr before i sold it and i remember cleaning the metal scrapings off.
    thatoneraccoon and Mendel Leisk like this.
  4. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    what year was your 2nd gen?
    why would they get rid of that, its a great idea
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Is that count before or after the body rusts and falls off ??
  6. Mendel Leisk
    42,373
    thatoneraccoon likes this.
  7. thatoneraccoon
    201
    146
    Ohio
    Wow! That manual has everything in it! :D the transmission oil drain plug :) basically everything to work on it. also I like how it have a lever to switch to reserve gas when you ran out lol.
  8. thatoneraccoon
    201
    146
    Ohio
    The non-stop site database errors is starting to get very frustrating
    Prodigyplace likes this.
  9. Mendel Leisk
    42,373
    Yes, it's like spreading pelletized fertilizer in a hailstorm this morning.
  10. thatoneraccoon
    201
    146
    Ohio
  11. EspressoFueled
    EspressoFueled Junior Member
    23
    53
    Napa, CA
    I see what you did there.
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    How long did they have it ?
    The beetle that I had and one of the vans had large holes where the drivers feet normally rest.
    Reminded me of the "Fred Flintstone" brand of brakes.
    Both were over 10 years old though.
  13. Mendel Leisk
    42,373
    '58 through '67 I think. I was frequently the one washing it, can't recall rust problems. Low mileage, small town might be a factor.
  14. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Do you feel that Toyota is that devious?
  15. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I, personally, think that Toyota's recommendations should be sufficient enough. Why wouldn't it be sufficient enough for others?
    #1 in Easley,SC
    #55 dalcon95, Feb 11, 2017
  16. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    If you focus on budget and keep your car 3-5 year's without putting a lot of miles.....yes
    If you want to keep for 5+ and take best out of the car without a lot of expensive repair......aggressive oil maintenance will be your cheaper insurance to make the best of car you own
    I have RV that say change oil on 35000 and i do on 12000.....why
    Be cause i have see my oil samples and how much addative in oil is gone
    scona and thatoneraccoon like this.
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    Not devious but perhaps not optimal. My tire dealer says the pressure recommendations on my 2008 Corolla are for comfort, not best tire wear. I run them at a higher pressure.
    Andyprius1 and thatoneraccoon like this.
  18. Mendel Leisk
    42,373
    Maybe suspension and wheel bearing wear are a factor too? (n)
    I weighed everything, settled on slightly higher pressures.
  19. dalcon95
    512
    653
    I have had vehicles with over 250,000 miles on them and over 20 years old and somehow with recommended maintenance made it that far. Of course, there were no major problems that happened because of the recommended maintenance done. I also know people with over 350,000 miles with just recommended maintenance done like 10k oil changes and such. 3-5 years is not a valid point in my opinion because I don't see it.
    #1 in Easley,SC
  20. Mendel Leisk
    42,373
    In maybe 35 years with Honda, they've always recommended transmission fluid changes, every 2~3 years, maybe 20~30K miles. It's a trivial chore, fluids and washers $40 at most. I think the first change is the most important, just judging from the drained fluid appearance. So better sooner than later.
    If it's overkill: it's cheap overkill.
    Jasonheng15 and thatoneraccoon like this.
