My Rosen Nav Install Pics w/Dash Kit & Hardwired Valentine One
Discussion in 'Gen 3 Prius Audio and Electronics' started by dopey423, Feb 8, 2011.
  1. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    installed the rosen nav this weekend w/the grey "wood" dash kit. i was going to get the flyaudio unit, but they are backordered, and i really like the ability to have built in bluetooth+mic in the head unit
    car: prius II, no nav, no jbl
    observations:
    1. oem texture and with dash kit - i could not tell the slight color difference of the rosen unit
    2. AUX port does work out of the box, no additional connections required - used by "aux in" within rosen menu
    3. button lights are much dimmer at night than stock radio, about half of the dimmer brightness control... something to be noted but not a deal breaker
    4. ipod interface and cable totally worth it. $200 for toyota ipod cable vs rosen = no contest
    5. dvd's play easily
    6. nav is a bit quirky compared to my garmin, but it's not the worst
    7. bluetooth pairs up with my motorola droid and verizon iphone 4
    8. as other's previously mentioned, stock speakers sounds much better. the treble/mid/bass are all tunable and easily accessible
    9. steering wheel controls all work, and so does changing tracks when on an ipod
    10. navigation sounds all come through stock speakers.. nice
    unit came with the ipod cable, backup camera cable, and all necessary hardware. i mounted the gps antenna above the rear view mirror where my hardwired valentine 1 is located.
    overall i am pretty happy with the amount of money i spent for an oem looking piece, ipod integration, built-in bluetooth+mic, dvd player, and navigation
  2. hatighora
    hatighora New Member
    new york
    Where did you get the wood dash kit from?
  3. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
  4. ghust
    ghust New Member
    NW
    Where did you buy your navigation? I'll buy one pretty soon.
  5. ct89
    ct89 Active Member
    323
    263
    New England
    I purchased mine at TrailDuty.com. The $799 sale price appears to be available again and they now explicitly state that the iPOD cable is included.
    I posted some additional information about the install in the Update of Rosen Unit thread.
  6. spiff72
    spiff72 Member
    184
    37
    West Michigan
    dopey423,
    Just curious about your V1 mounting position...
    Do you find that the suction cups stick the that area of the windshield? I have tried mounting radar detectors in that area before, but I could never get suction cups to stick to that painted dot pattern.
    Thanks
    Jeff
  7. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    i also got mine from trailduty.com and got it very quickly. took a pic of the modded igo and toyota background today
  8. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    You are correct that with the dots there the suction cups do not work. I had some leftover clear bra material, so i cut a 3"x1.5" rectangular piece, and placed it where i wanted the V1 mounted. Now the suction cups work like a charm. I believe any other material should work too like screen protectors and what not.
  9. Papagoose
    Papagoose New Member
    29
    Cedartown, GA
    Are you able to stream audio from your Droid X or is it only compatible with Bluetooth for phone calls?
  10. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    yes, bluetooth streaming from my motodroid or the iphone 4 works well. i can change tracks from the phone or with the headunit, but it does not give a playlist like the ipod does.
  11. us_matrix
    us_matrix Member
    110
    Hi dopey,
    How did you change the boot logo to Toyota? I like to do that if possible.
    Thanks.
  12. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    i used the website below to figure out where the files were within the SD card, then just created the file within photoshop. it didn't work well when using my mac and ran into some errors with apple's automatic file creation of hidden files, so i used windows and it was much better.
    i mainly changed the loading file and added the new skin to the skin folder. i also used a 800x480 image since i think that was what the rosen was using.
    iGO8 navigation startup images. see here. - E46Fanatics
  13. greybear
    greybear New Member
    florida
    Hi \
    I just bought the rosen from trail duty and getting ready to install it..where did you pick up the plus 12 volts and the acc 12 voilts and also the color or wire for the reverse for the back up camera ...sure appreciate it ..
    thanks
    greybear
  14. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    i actually haven't had a chance to get the rear cam wired up yet. i am planning to use the existing acc wire from the head unit for the cam power, along with the video rca cable. there is a reverse wire that i am wiring up beneath the drivers side parking brake which can be referenced at the link below.
    let me know how it goes.. my cam just got shipped out from china today
    http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/88850-help-camry-09-cam-wires.html
    i dont know if my method above is the correct one, but i won't know until the cam gets here and i can test it out. if you find different, please post =)
  15. us_matrix
    us_matrix Member
    110
    You did a great job by mounting the GPS antenna above the windshield. Did you have to remove the dashboard or just run the antenna through compartment and A piller then through the roof liner?
  16. us_matrix
    us_matrix Member
    110
    I don't have the Rosen instruction with me. If I remember correctly, the Rosen ACC wire connect to the cam power wire and the Rosen Brake (Rev) wire connecto to my rear driver lamp (rev wire). The Rosen supplied rear cam harness connect to the cam RCA (Video).
  17. dopey423
    dopey423 New Member
    77
    Silicon Valley, CA
    pretty much.. and i ran the wire with the weather stripping up the a-pillar until i had to tuck it into the top of the a-pillar panel and across the headliner. when you look at the drivers side a-pillar, weather stripping, and everything, you could never tell that there are actually wires underneath
    luckily i didnt have to pop off the a-pillar or the headliner to do any of this. i did see a post in the forum a while back where someone put the gps antenna into the tweeter area, but i didnt want to deal with popping more panels than i needed. i also tried to mount the gps on top of the radio, but that was a complete fail as i couldnt get any gps sat's to connect to the head unit
  18. xxxx ne0 xxxx
    xxxx ne0 xxxx Junior Member
    Las Vegas
    Nice but what head unit has the best gps with lane assist, fast boot time, and good sound quality. How is the gps, can you rate it, how many stars, quick review.
  19. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The chinese head units are flexible for the navigation software. My favorite is iGo/Primo. The GPS quality depends on GPS chipset. My HU has SIRf IV inside with the excellent GPS fix time and very good sensitivity. The Rosen is using the previous generation (III), AFAIK.
  20. sfadchi
    sfadchi Junior Member
    17
    Boynton Beach, FL
    Do the bluetooth steering wheel controls still work?
Loading...
