Navigation in my 2017 Prime Premium
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by iskoos, Nov 2, 2025.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    It seems doing its job but still not up to date. Streets/subdivisions built in the last 2 years or so aren't showing up.
    Is there a way to update the navigation database?
    Or better, is there a way to use the Google Maps via my phone?
    Thanks
    52,804
    dealer can update, or sometimes you can find bootleg on ebay.
  3. iskoos
    415
    254
    Orlando, FL
    Well, dealer will charge a minimum of one labor hour for it I imagine. It won't be worth.
    I would be willing to pay a bit but not in $150-$200 range.
  4. Blueness
    Blueness New Member
    Farmington, NM
    2018 Prius Prime
    Amazon has SD cards that work, I now have a 2024 map database in mine.
    https://a.co/d/8suABfy
    Assuming the 11 inch display uses the same microsd as the 7 inch anyway.
  5. bisco
    52,804
    dealers have always been a ripoff on updates
  6. BiomedO1
    BiomedO1 Senior Member
    4,547
    2,391
    Left Coast
    My cheap asset uses Waze through my phone. Simply reset/change your default navigator so your screen mirror's your phone.
    Not sure if that's going to work, since 2017 was the bridge years for Toyota phone interfaces. I know that will work on 2020 and beyond Toyota panels; just not sure if your panel has the capable hardware and software to do this.
  7. iskoos
    415
    254
    Orlando, FL
    Well, The Amazon link shows my car is compatible. I have no problem spending this amount to update my map, but I don't have a microsd slot on my panel. Or if I do, I don't know where it is.
    Where is it?
  8. iskoos
    415
    254
    Orlando, FL
    Where is it?
  9. iskoos
    415
    254
    Orlando, FL
    I found where the microSD slot is:). Thanks to Mark57 for his detailed explanation.
  10. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    What is the installation procedure for the 7" display?
    Is this card an OEM or a bootleg copy?
    #10 MikeDee, Nov 15, 2025
  11. MikeDee
    1,581
    597
    I got the Amazon card. It works great. What’s nice is the speed limit is shown for all the streets.
  12. Blueness
    Blueness New Member
    Farmington, NM
    2018 Prius Prime
    It looks OEM but is probably bootleg. Remove old card, put new card in, turn car on and switch to navigation and it should update.
    @iskoos sorry I got busy/sick and forgot about the forum for a bit!
