Need help reading a spark plug, possibly running lean
Discussion in 'Gen 3 Prius Technical Discussion' started by whazzup, Oct 28, 2022.
  1. whazzup
    whazzup New Member
    16
    Attached is a picture of my #3 and #4 cylinder spark plugs. The worse one is the #4. Back story is that I replaced a head gasket 10,000 miles ago. I'm having a similar problem again with the start up shakes. Doesn't happen all the time but frequent enough. I'm not losing any coolant like I was last time so I'm not sure where to begin looking. All I know is the spark plugs are not burning correctly and it appears to be a lean condition. Any thoughts? sparkplug.jpg
  2. Mendel Leisk
    42,355
    Who did the head gasket? What’s the miles? Has the intake manifold and EGR components been thoroughly cleaned?
    Grit likes this.
  3. whazzup
    whazzup New Member
    16
    EGR and intake has been cleaned. I did the head gasket with OEM parts. The coolant was leaking into the #1 cylinder and washing the piston. The #1 spark plug came out clean this time with normal burn.
    It’s a 2013 Gen 3 with 143000 miles.
    Here is my old post when I did the head gasket:
    Multiple codes CEL after head gasket change 2013 | PriusChat
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    The spark plug on the right is from a cylinder that's using / burning some oil. The other plug is fairly white, possibly a bit lean. What are fuel trim numbers- at hot idle, at higher idle, and at cruise? Is there any knock retard going on?
  5. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    To plug in the left looks normal. The one on the right is covered with oil
  6. whazzup
    whazzup New Member
    16
    How do I get fuel trim numbers? I don’t have anything I can hook up to the ECU. As for the knock retard, I can’t be sure but I don’t believe so.
    I’m definitely burning a little oil for sure. Is there a way I can check compression?
  7. bisco
    52,863
  8. whazzup
    whazzup New Member
    16
    I don’t believe the engine will turn over without the ignition coils. Have you tried this method? I never heard of anyone successfully checking compression using maintenance mode.
  9. bisco
    52,863
    i haven't. there are other videos available
  10. Mendel Leisk
    42,355
    Attached shows how to do compression test with Techstream:
  11. whazzup
    whazzup New Member
    16
    Unfortunately, I don't have techstream.
