Need Some New Tire Help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kmkremer, Jan 21, 2013.
  1. kmkremer
    kmkremer Member
    227
    30
    San Diego
    It's time to replace the tires on my 2010 Prius model V. While there seems to be a number of options for the 15" wheels, there aren't nearly as many for the 17" wheels on my car. The OEM tires are Michelin Pilot's. I called Discount Tire and to replace with the same tires are $200+ per tire. They recommended a set of Yokohama YK580's. They are $133/tire and rated for 45K miles. Does anyone have any expererience to share with these tires or recommendations on others? Any help would be greatly appreciated.
  2. TsKarma
    TsKarma Junior Member
    82
  3. kmkremer
    kmkremer Member
    227
    30
    San Diego
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Two recommendations for 17" wheels, I have used both: Michelin Pilot Sport A/S Plus and Michelin Primacy MXM4. The Pilot Sport tires are noisier and probably ride a bit harsher but have better traction under most conditions, the Primacys (what I have now) are more civilized but still perform very well.
  5. kmkremer
    kmkremer Member
    227
    30
    San Diego
    I'm stuck between the Primacy MSM4's and the Bridgestone Ecopia EP422. The Bridgestone's are an LRR tire and rated for 65K miles. They will likely not ride as well as the Michelin's.
  6. tumbleweed
    4,067
    692
    Eastern Oregon
    I have no experience with the Ecopia but I am very happy with the Primacy. I will probably buy another set when these wear out.
  7. Mendel Leisk
    42,247
    I also have the 215/45R17 Pilots as OEM (Canadian "Touring" model). They've a lot of tread left, but it's never to soon to start researching. I'm pretty much settled on Michelin Primacy MXM4. I was thinking of the Bridgestone Ecopia EP422, but have been reading some negative reviews on TireRack, both for road handling and RR...
    The Primacy actually shows as being LRR on TireRack, but maybe not as good as EP422's as far as RR? If it would at least match the OEM Pilot's that would be fine by me.
  8. tumbleweed
    4,067
    692
    Eastern Oregon
    I stand corrected, they certainly are LRR rated.
  9. kmkremer
    kmkremer Member
    227
    30
    San Diego
    I
    I noticed that as well. I'm leaning toward the Primacy.
  10. Mendel Leisk
    42,247
    Well, I think there's a gamut within LRR. Regardless of them having the LRR tag, I've got mixed expectations regarding just how LRR they are. I just wish Michelin Energy Savers came in 215/45R17. Or 205/50R17.
    All in: if I was shopping today, I'd likely go for the Primacy, in 215/45R17, weighing all the factors, not just RR.
