no battery & a/c info after lose power on 12volt battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fileaudio, Jan 28, 2015.
  1. fileaudio
    fileaudio Member
    109
    58
    El paso texas
    i was installing an aftermarket nav system on
    prius 08, bcuz 2 hours working with dome lights on I have to jumpstart, now battery doesnt show bars is blank no mpg status, a message appeared check a/c connections. any suggestions?
    i check connections and NOTHING avg mpg got stuck... enter to service menu shows 13.6 volts while running and the car is running fine! just the bars doesnt appear not even mpg avg
    #1 fileaudio, Jan 28, 2015
    51,155
    i think you need to replace your 12v battery.
  3. Mendel Leisk
    40,586
    Check your the voltage at the under hood jumpstart point, with a digital multimeter. Anything under 12.3 you've got problems. I think you know already though, lol.
    Jumpstart will not recharge it. You could try a charging session, or two, with a smart charger. May or may not work. May take a new battery.
    I'll try not to preach, but it's best to turn off all "convenience" lights possible: cabin ceiling, hatch. Also, minimize open doors. If possible, hooking up a smart charger when you're working on something like this would be good.
    fileaudio likes this.
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    And if the battery takes and holds a charge, it might be necessary to completely disconnect it for 5 minutes or so to get all of the electronics to reset.
  5. fileaudio
    fileaudio Member
    109
    58
    El paso texas
    ok, my car is running as always battery holds chsrge well . the only thing Thatd strange is that energy monitor doesnt show battery bars or status...
  6. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    Measure the voltage of the 12V battery to make sure it’s ok. You can measure it from jump start point under hood.
    If it’s ok then disconnect the 12V battery for 5min. If that fixes MFD then it just got confused from 12V getting down. If it still doesn’t work it’s problem with your MFD. Maybe something happened when you did the change stereo. MFD problems are pretty common and they are related to vibration so changing stereo may have finally broken it…
  7. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Early Gen2 Prii (2004 and 2005) commonly have MFD problems. See:
    Prius MFD
    For the most prominent one (a cracked solder joint) which is what your MFD symptoms seem to indicate.
    JeffD
  8. GregP507
    GregP507 Senior Member
    3,002
    481
    Check for burned spots on the printed circuit boards. Some components may need replacing or re-soldering. Failing that, a good electronic engineer could troubleshoot it and probably fix it, but those guys don't come cheap.
  9. jdenenberg
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
  10. fileaudio
    fileaudio Member
    109
    58
    El paso texas
  11. Mendel Leisk
    40,586
    Don't know much about it but hope that does the trick. ;)
