No takers so far
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, May 16, 2025.
Thread Status:
Not open for further replies.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't mind having my posts critiqued, but not by someone who hasn't bothered to read or comprehend them. I've had a new battery installed and all my software is up to date.
    52,876
    and you're the last one to have a problem, sorry to hear it. all the best finding a fix
  3. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I'm not repeating myself for someone who misunderstands the problem. Before you offer advice, I suggest you become familiar with the problem.
    • I carry a jump pack, not because I want to, but because I have to.
    • I also use a battery maintainer as a workaround.
    • I have had the 12V battery fall below threshold in as little as 2 hours.
    • The problem existed long before I installed the auxiliary battery. It is fully isolated from the system.
    • The dealer has tried to "fix my car;" installed a new battery, but they still seem stumped.
    All of these things have been spelled out in detail, if you had bothered to comprehend.
  4. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    If that's true, maybe you could cite one.
  5. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
  6. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I thought so...
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    What's it to me if others have or have not this problem?
    Is there some sort of consensus required?
  8. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    Neither one is OP’s current problem.
    I explained what is going on in detail in my previous post. His current battery-isolator setup with user-adjusted cut-in/cutoff voltages and the auxiliary 12-V LFP battery is confusing the Prius BMS and preventing it from charging the 12-V battery altogether. As a result, his warranty-replaced second battery is also damaged now due to sulfation from constant full drains and won’t hold charge.
    Back to the two issues that you pointed out:
    A replacement new battery was only needed in instances when the dealer failed to properly maintain the battery (by periodically connecting a battery charger) during long periods of storage, such as during recalls etc., which resulted in sulfation of the battery before the car was sold to the owner.
    The software update was only needed when the owner was leaving the car plugged in for many days, which you are not supposed to do anyway. The car is not normally meant to be plugged in for longer than overnight. If I did so in Canada to use the battery heater in frigid temperatures, I would also connect a 12-V battery maintainer.
    Other than that, third-party accessories, mods, and not driving the car for long distances regularly can drain the battery. You should use a battery maintainer if that is the case.
    It is always a good idea to use a battery monitor to diagnose any issues.
    #88 Gokhan, Aug 27, 2025
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    The problem was never the battery. You'd know that if you weren't stabbing in the dark.
  10. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I've lost track of the times I said the original battery tested fine, but a dealer replaced it anyway. The battery was still going dead just being parked, sometimes for only 2 hours.
    This was before any auxiliary battery was ever installed. If a software update should have fixed it, all of mine are up to date.
    I think the implication is that I don't know what I'm talking about. This conclusion was apparently reached without reference to the facts I posted.
  11. Hayslayer
    Hayslayer Active Member
    538
    331
    nailed it!!!!!!!!!!!!!!!!!
    rjparker, Brian1954 and Gokhan like this.
  12. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Which is wrong, and you can't prove with denial.
    Gokhan likes this. Why? Do you enjoy being wrong?
    You've chosen to ignore facts, so you can insult me.
    Are you really that bad a person?
    #92 Paul Gregory, Aug 28, 2025
  13. Mendel Leisk
    42,361
    Everybody take a breath, contemplate the waffle-bedecked bunny?
    Tideland Prius likes this.
  14. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Good advice Mendel. I let the idiots get to me.
    I should just ignore them.
  15. bisco
    52,876
    it's a shame ttoyota engineers dodn't foresee this problem and come up with a creative solution
  16. bisco
    52,876
  17. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It's not what you say about yourself
    that counts, it's how you treat others.
    #97 Paul Gregory, Aug 28, 2025
  18. Gokhan
    6,715
    2,672
    Paramount CA
    I am sure somewhere in the owner’s manual, Toyota engineers warned against redneck engineering. That is standard with any product you buy.
    In fact, I found it on page 6:
    A wide variety of non-genuine spare parts and accessories for Toyota vehicles are currently available in the market. You should know that Toyota does not warrant these products and is not responsible for their performance, repair, or replacement, or for any damage they may cause to, or adverse effect they may have on, your Toyota vehicle.
    This vehicle should not be modified with non-genuine Toyota products. Modification with non-genuine Toyota products could affect its performance, safety or durability, and may even violate governmental regulations. In addition, damage or performance problems resulting from the modification may not be covered under warranty. Also, remodeling like this will have an effect on advanced safety equipment such as Toyota Safety Sense 3.0 and there is a danger that it will not work properly or the danger that it may work in situations where it should not be working.
  19. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Two dealers looked over my setup with the auxiliary battery and found nothing wrong. Obviously they found nothing to be concerned over. It's just a spare battery that's isolated from the rest of the system by a battery isolator. It keeps my drinks cooler running without draining the main 12V battery.
  20. bisco
    52,876
    exactly my point
Thread Status:
