None ABM or Flood battery on Prius?
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, May 23, 2021.
  1. Tekken
    Tekken Member
    259
    77
    Los Angeles, California
    Hello,
    Is anyone using None AGM 12v Battery or Flood battery in Prius and why not? I believe i've read somewhere there're converter so we can use None AGM battery from any Auto shop as long as it fit in battery space behind. Still, why it needs a converter for none AGM 12v Battery?
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    I never heard of a "converter". FYI, Gen4 and Prius Prime use a regular flooded lead-acid 12v battery under the hood, not in the cargo area inside the car. I thought the only reason, Gen3 and earlier Prius used AGM is due to the safety issue of having a flooded battery in the cabin in case of the acid leak.
  3. ASRDogman
    ASRDogman Senior Member
    7,960
    4,045
    You "can" use any 12v battery. But a lead acid is not a good idea.
    Leaks, and it gives off toxic gases as it charges, inside the cabin. So, not a good idea.
  4. Tekken
    Tekken Member
    259
    77
    Driving in SoCal that I always window open, plus during the pandemic period, we always mask up LOL
    What model or size of 12v Battery on Gen4 using? Does it had the Vent hold connector? Maybe I can battery flooded Gen4 12v battery on my Gen3
    bisco and Salamander_King like this.
  5. Salamander_King
    11,024
    8,976
    New England
    I don't know the physical size of the AGM 12v battery in the Gen3. Even though I have owned Gen3 for three years, I never had to replace it. I did not even know where the battery was back then when I had Gen3. Gen4 and PP use the size is called LN 1, H4, or 140R. The physical spec was commented by @Elektroingenieur. Gen 4 12 Volt battery. | Page 4 | PriusChat
    The OEM 12v battery for Gen4 and PP from Toyota is ~$180, but you can find aftermarket 12v battery in this size group at less cost around $120-$130. With a core exchange and sales coupon, you can find one at around $100.
  6. bisco
    52,657
    what are you trying to accomplish? just pick up a 200 dollar oem and move on
    Mendel Leisk and Grit like this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,825
    6,795
    Texas Hill Country
    I am sure he wants to buy a low priced battery to save money.
    There are concerns about terminal diameter and placement. The proper agm has smaller diameter terminals than standard and are often switched between the plus and minus. The switched polarities have sometimes resulted in blown electrical parts.
  8. bisco
    52,657
    maybe. won't save anything with gen 4
  9. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
  10. hoffeck
    hoffeck Member
    Germany
  11. Tekken
    Tekken Member
    259
    77
    Just got a Lead Acid Group 51 Battery from local Walmart and is half price less than all OEM AGM Group 51 that fix Gen3 out there. My concern, is any report by using None AGM battery can damage Prius Hybrid Battery?
  12. rjparker
    10,825
    6,795
    Texas Hill Country
    A bad installation can ruin lots of electrical components in your car. The number one issue is reversing the plus and minus terminals. Group 46B24R is the battery that fits properly.
  13. Tekken
    Tekken Member
    259
    77
    Group 51 fit perfectly, I got AGM 1yrs ago amazon item below from amazon and it's working fine.. but turn out I gave to my sister's Prius. I'm projecting for this Lead Acid one if it work. Installation, it shouldn't have problem.
    Amazon item # B010GKJ8F6 or
    ACDelco ACDB24R
  14. fuzzy1
    10,648
    It shouldn't hurt the hybrid battery. The only known risk, quite low but non-zero, is to the humans inside the car. And a mask won't help at all.
    jerrymildred and ASRDogman like this.
  15. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    the science says it won’t protect you?!
  16. ASRDogman
    7,960
    4,045
    If you play with fire, you're going to get burnt! Hopefully, you won't burn innocent people...
  17. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Well, the flooded have similar vent holes right? Then just plug one side and connect the drain. Accident where the battery is impacted would be the question mark. I've read of a few smart fortwo owners smelling the rotten egg of a dying 12 V and surviving, but I guess those who didn't couldn't post that they died?....
    SAE to JIS adapter? Care to share how you got it to fit?
    (I switched to LiFePO4. Since they should have fixed the fitment. No drain holes...)
    moto g(7) power ?
  18. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. Not similar at all.......usually.
  19. sam spade 2
    7,035
    2,804
    2017 Prius c
    What exactly is a "none" AGM battery ?
    The converter performs the function of an alternator in a conventional car to keep the 12 V battery charged.
  20. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Not sure @Tekken presented the question clearly.
    The posts (as you probably already know) of a Group 51 battery (I have/had one in my Scion iQ) have SAE (thick/standard posts) and the S46B24R has JIS (thin posts).
    May be referring to SAE to JIS post adapters?
    Or the concern that the two battery types have slightly different charge profiles?
    moto g(7) power ?
