Now What-- Misfire to Egr to Check Hybrid System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DPZ, Jan 19, 2025.
  1. Mendel Leisk
    41,459
    Bone up on head gasket replacement, just in case.
    Doesn't seem to be possible to replace just that white plastic collar that broke. :(
    #21 Mendel Leisk, Jan 20, 2025
  2. DPZ
    DPZ Junior Member
    Arizona
    I am fine with the washer remedy as long as it will hold.
    For give me not sure whaht you ment by "Bone up"
    can you elaborate on your Bone up statement. Did you mean learn as much as I can about it ?
    Or did you mean that I should get it replaced just in case?
    Is repacing the Head Gasket myself in the driveway a bad idea?
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,153
    6,312
    Texas Hill Country
    Bone up is canadian for study the process before doing it if and when needed.
    Coolant does not normally go down even if not touched for years. So Mendel is preparing you if the worse happens and it rattles again.
    A borescope test is the right thing to do; an egr does not cause rattling. It can cause stumbling accompanied by an egr code caused by the egr sticking open at low rpm's and startup. A egr test is run almost every drive time and will code if the egr is either sticking open or clogged completely.
    Borescope test with quality dual view tool
    #23 rjparker, Jan 21, 2025
  4. DPZ
    DPZ Junior Member
    Arizona
    Is changing the head gasket in the driveway a bad idea
  5. rjparker
    10,153
    6,312
    Texas Hill Country
    It's ok and some mobile guys do exactly that. But if you don't have experience it can be several days worth of work. Usually a rebuilt of the head by a machine shop is recommended. Doing it in the car (instead of pulling the engine) makes experience even more valuable as doing the timing chain can be tricky and has caused redos by some. Knowing the scope of the problem is sometimes difficult. If it burns oil now it will burn oil later.
  6. Mendel Leisk
    41,459
    Do you have a garage? Even if it would mean some temporary removal of stored items, that'd be preferable for comfort, convenience.
  7. Mendel Leisk
    41,459
    Agreed on definition, but origin might be US:
    Partial quote:
    "Bone up" appears to have developed from the simpler verb form "bone," as J.E. Lighter, Random House Historical Dictionary of American Slang, reports. Several early instances of bone or boning in this sense are recorded from the U.S. Military Academy in West Point, New York, starting in 1859. The earliest match for "bone up" (or rather "boning up") is from 1877, from the University of Michigan.
    etymology - Origin of "to bone up on something". - English Language & Usage Stack Exchange
  8. DPZ
    DPZ Junior Member
    Arizona
    what would be considered a good price to have it repaired by someone?
  9. rjparker
    10,153
    6,312
    Texas Hill Country
    $2,000 if they guarantee and rebuild the head.
    $4,000 if they install a Hybridpit Gold rebuilt engine with new pistons and rings.
  10. DPZ
    DPZ Junior Member
    Arizona
    the saga continues.. After cleaning egr cooler, egr valve, intake manifold and installing the oil catch can. All codes were clear and car seemed to be operating normal...
    My daughter drove the car for a week probably 200 miles and today we she got a CEL and the code was P0441 and auto parts store recomended replacing the EVAP canister Purge control valve.
    Anyone think it could have something to do with the Oil Catch Can hose connections or something else before throwing parts at it?
    Thank you
    Garry
  11. Mendel Leisk
    41,459
    Maybe something disconnected at the item id'd in the linked diagram as 17650? It bolts to driver's side of intake manifold.
    Vacuum piping for Toyota Prius ZVW35L - Auto parts - Amayama
    Brian1954 likes this.
  12. Brian1954
    Brian1954 Senior Member
    2,204
    866
    South Central PA, USA
    Make sure the hose 23827A in the diagram linked in post #31 is connected correctly.
  13. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Sometimes people forget to put disconnected hoses back in place.
    P0441 after cleaning IM/EGR | PriusChat
