O2 code after stolen cat conv replacement has mechanic stumped
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by andrewe2, Dec 18, 2020.
  1. andrewe2
    andrewe2 Junior Member
    24
    I joined the growing club of victims the other day. Fortunately my insurance covered most of the cost. My garage said thieves damaged the O2 sensor while stealing the catalytic converter and it had to be replaced. I picked up the car drove it about 4 miles and the check engine light came on with code P0136 (O2 sensor). Next day garage replaced the O2 sensor they had installed the day before (which checked out good). Picked the car up today and everything looked good for about 15 minutes on the highway and the light fired again (P0136). The car runs fine. I'm beginning to suspect that my garage may be out of their league on this one. It goes back to them in a couple of days but I'm concerned they're going to start shot-gunning the problem, replacing other parts. Any suggestions on what I should do or ideas on how to troubleshoot and fix the cause?
    Thanks
    Andrew
    2004 Prius with 215k miles
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    • The oxygen sensor might be counterfeit or the wrong part. The Toyota part number is 89465-47070, and it would be best to buy one from a Toyota dealer, not from an online seller whose inventory may have been commingled with similar parts from less reliable sources. I expect the Denso equivalent (234-4623) would be OK, too, if bought from a reliable source.
    • See the troubleshooting procedure for P0136, P0137, and P0138 in the Repair Manual (more info).
  3. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Had a similar problem with Mom's Cadillac. A mechanic unplugged the sensor in order to get to a rear spark plug. Shortly after picking it up the CEL came on. She took it back and they pulled the code. Bad O2 sensor. They fed her a line of bull about having to drive it for an hour to reset the computer.
    I took a look. The shop manual gave instructions for checking the sensor with a volt/ohm meter. As I poked around to check the voltages I found that one of the connector blades was bent over and smashed, not making contact. I straightened it out with a pair of needlenose pliers and was able to get it back together. It worked again and the CEL cleared.
    I suggest that you check both the plug AND the socket.
    Dan
  4. andrewe2
    24
    Interesting service bulletin specific to my year and problem. Thanks for pointing that out. I'll keep you posted.
  5. andrewe2
    24
    I'm sorry to expose my ignorance but the bulletin says it applies to "2004 model year Prius vehicles produced BEFORE the Production Change Effective VIN shown below" JTDKB2#U#40028134 and my VIN is JTDKB20U440038208. Does it mean my Prius was produced after they fixed it?
  6. Elektroingenieur
    2,515
    3,288
    Three Touring
    Yes, that’s correct.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    Don't know what to say. It's a basic 4 wire oxygen sensor. 2 wires for the heater, 2 for the sensor signal. The connector is actually inside the passenger area so any damage would have been to the sensor pigtail/wiring. About the only bad thing that could happen is the heater wires shorting together and damaging the ecu.
    For diagnostics, once the sensor reaches operating temperature (that's why it has a heater) it puts out a voltage signal that varies with the amount of oxygen present in the exhaust gases. When there is lots of oxygen (aka "lean") it is near 0V, with very little oxygen it is near 1V ("rich"). The actual voltage at the sensor connector should match what the ecu displays on a scantool. That reading should change as you drive the car.
    One thing to watch for is if there is an exhaust leak that can allow outside air to be sucked in- that can skew the sensor reading.
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
  9. andrewe2
    24
    That's too bad, however, I erased the code and took it out for a "strenuous" 30 mile ride and no light, which would lead me to suspect there is some connection with the notion of an O2 sensor being effected by a new converter/exhaust as it "breaks-in" as described in the bulletin (only for my year) you pointed out, for which I'm impressed and grateful. I guess I'll just have to wait and see if the error occurs. Thanks again.
    SFO likes this.
  10. andrewe2
    24
    Here's an update; looks like it was cat converter breaking in. CEL for sensor hasn't been on since.
    Jeff606 and SFO like this.
  11. andrewe2
    24
    You were right on the catalytic converter break in. I wonder if you might have some insight into another mystery. My CEL has been coming up with a misfire on cylinder one (PO301) for almost three years. The garage replaced the plugs and some other component related to the injectors but not the injectors. It seems to come on more frequently in cold rainy (Bay Area) weather and possibly when I'm parked on a hill (nose down). Any thoughts? Does it sound like an injector?
  12. Elektroingenieur
    2,515
    3,288
    Three Touring
    It could be the water leakage problem described in Toyota service bulletin EG063-05, “M.I.L. ‘ON’ DTC P0300, P0301, P0302, P0303, OR P0304,” December 16, 2005, discussed in this previous thread and several others.
    If not, there is a comprehensive diagnostic procedure for P0301 in the Repair Manual (more info).
    SFO likes this.
  13. andrewe2
    24
    Once again you may have solved my problem. Water leakage is a likely culprit due to fact that it happens more frequently in rainy weather and when the car is pointed downhill. I don't understand why independent garages don't seem to be aware of these TSBs. I'll keep you posted. Thanks again.
