Obd speedometer compatiblity
Discussion in 'Gen 4 Prius Technical Discussion' started by Ali Khalayleh, Jan 28, 2020.
  1. Ali Khalayleh
    Ali Khalayleh New Member
    JORDAN
    Hello,
    I've just got a second hand 2016 prius, I can't not change the however I cannot change the speedometer to kph.
    So I was thinking of getting a external OBD speedometer that I can place on the dashboard. I'm worried and don't know how to check the device I want to get will work with my car.
    Any suggestions?
  2. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Welcome! If all you want is the speed, you can get that from your smart phone without an OBDII device. There are lots of apps that will do that including some of the map apps like Google maps, if I remember right.
    One possible problem with using an OBDII device routinely like you're thinking about is that they keep using power after you shut off the car. So if you forget to unplug it, you could run down the 12V battery.
    alanclarkeau likes this.
  3. Ali Khalayleh
    JORDAN
    Thanks Jerry, I already use my phone, I was thinking more everyone else that drives my car, as my parents sometimes use my car and tech savy they are not.
    But thank you I didn't think about the battery.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    You could use a dashcam if it has GPS.
  5. jerrymildred
    11,511
    14,113
    Tampa, FL
    That's a good idea if the display is big enough. I keep my dash cam display off but it's right there if I turn it on.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Or a cheap SatNav/GPS.
    kithmo and jerrymildred like this.
  7. jerrymildred
    11,511
    14,113
    Tampa, FL
    And it's pretty easy to just do a mental conversion by rounding it off. Such as 60 mph = 40 kph, etc. Oops. Did it backwards. LOL! 60 mph = 100 kph, 30 mph = 50 kph. Maybe it's not super-easy. But I've done that a lot in both directions.
    #7 jerrymildred, Jan 29, 2020
  8. alanclarkeau
    7,044
    7,584
    Do you know where your car came from?
  9. jerrymildred
    11,511
    14,113
    Tampa, FL
    AFAIK, none of the 2016s could switch units.
  10. Ali Khalayleh
    JORDAN
    Yes, I do believe it was originally from the US, brought second hand and imported here. I had it looked at, its only been 35 thousand miles, bieng a company car, it had been hit from the front. But nothing else is wrong with it.
    I do believe 2016 models can't be changed yes.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    UK ones can :p:LOL:
    alanclarkeau and jerrymildred like this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    My dashcam display goes off a few seconds after powering up, reverting to a black screen with just the (GPS) speed showing, ideal for the OP.
    jerrymildred likes this.
  13. fuzzy1
    10,170
    I thought is was just the first 2016 Liftbacks that could not, and that this was fixed at some point during that same production year.
    P.S. Here is the official Transport Canada list of which Prius models cannot be imported from the U.S. to Canada specifically because of this speedometer issue:
    "Notes 3, 4 and 5: The following vehicles models series do not have the functionality to program the digital speedometer units from miles per hour (mph) to kilometers per hour (km/h):
    -Certain 2016 model year Prius (estimated production period: start of production through March 2016) , and
    -Certain 2016-2017 model year Prius v (estimated production period: Avril 2016 through end of production), and
    -2017 model year Prius c (estimated production period: Dec 2016 through May 2017"
    #13 fuzzy1, Jan 29, 2020
  14. alanclarkeau
    7,044
    7,584
    Aussie ones are only km/hr.
  15. Elektroingenieur
    2,515
    3,259
    Three Touring
    Mine can. From the parts catalog data, I believe the change to the meter circuit plate with support for dual units may have been made in March 2016, and my car was made after that.
    See also the PriusChat thread about this, in which @Greatmouse kindly reported that replacing the instrument cluster (combination meter, in Toyota’s terms) provided the km/h readout required in Canada.
    Mendel Leisk and jerrymildred like this.
  16. jerrymildred
    11,511
    14,113
    Tampa, FL
    That mid year change does sound familiar now that you mention it, @Elektroingenieur. Thanks for looking it up.
    Pretty sure that's right. I didn't specify because I was thinking liftback was the object of the question. (y)
  17. fuzzy1
    10,170
    Well that is what I remembered, but that Transport Canada shows some 'c' and 'v' units also having the same problem. And curiously, they don't have overlapping production periods, but rather sequential periods. o_O:confused:
  18. Gator6
    Gator6 Junior Member
    Central KY
    Can it be changed using the Techstream Software?
  19. Elektroingenieur
    2,515
    3,259
    Three Touring
    Not as far as I know. There is an Active Test function, “Speed Meter Operation,” that lets you force the reading to 0, 40, 80, 120, or 160 of the currently selected units—more useful on vehicles with mechanical speedometer movements—but not a way to change the units, nor to enable a unit selection capability for the user.
  20. fuzzy1
    10,170
    No. If it could, that would have fixed the problem for a very disgruntled PC member living near the US-Canadian border and frequently crossing. He was upset enough at the lack of a fix (other than trading in for a later unit) to make noises about getting a safety recall.
    Gator6 likes this.
