Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. TacoPapi
    TacoPapi Junior Member
    60
    United States
    Yes. It was at car level.
  2. TacoPapi
    60
    United States
    Well. I did also have a fender bender on the right side a month or two ago so it might be lingering symptoms/issues with the tire/frame. I did also add Dynamat to the doors so I have no idea, I’ll finish up putting Dynamat in the next few days.
  3. TacoPapi
    60
    United States
    Guys. Is this normal throttle position? I reset the battery again and I’m thinking about going to the dealership to get it reset. Seems to be sitting a little lower than what it used to
    Picture #1: letting go fully
    Picture #2: pressing the opposite side that the throttle opens from
    Picture #3: normal position BFF686BA-BE70-4287-AC0D-0809121A066C.jpeg 3FBD5655-0523-4D83-9FA2-30AA20A3FD83.jpeg 4C3D9A72-1894-4D90-971D-E14CA6591140.jpeg
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  5. TacoPapi
    60
    United States
    Ok what about this? Seems the foam was dried off and came off the intake part. Could this be my vacuum leak?
    I also had a K&N air intake which I took off to test. I feel some air around the throttle/intake area
  6. Mendel Leisk
    42,355
    ^ Is that the joint between the engine air intake snorkel and filter box? It's no big deal if that's a bit loose; it's just trying to source air from the (possibly cooler?) corner of the engine bay. And it's upstream of the air filter. Significant vacuum leaks would be downstream of the throttle plate.
  7. TacoPapi
    60
    United States
    I have looked and looked and cannot pin point what the issue is at all. It’s still riding loud and the exhaust gets loud only when the gas engine is on.
  8. xliderider
    8,140
    3,280
    Honolulu, HI
    Is the throttle body to intake gasket sealed? Some have had an issue with that area leaking vacuum. Probably hear a hissing sound when the ICE comes on and is revved.
  9. TacoPapi
    60
    United States
    Yeah I had it and even flipped it upside down. Nothing.
  10. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    @TacoPapi Did you replace the intake manifold gasket, throttle body gasket, and egr pipe gasket?
  11. TacoPapi
    60
    United States
    What does it mean when more oil keeps leaking off the engine after air intake was cleaned and OCC installed?
  12. TacoPapi
    60
    United States
    Yes to all
  13. TacoPapi
    60
    United States
    ASRDogman likes this.
  14. TacoPapi
    60
    United States
    Another reaso why i think is because I experienced this when testing with Car Scanner app. I have no lights and my engine runs kinda stupid reving high when slowing down, etc.
    EVAPORATIVE SYSTEM NOT PASSED was flagged at least 3 times.
    Another reason would be because I posted on here that I did not connect one of my hoses correctly, but I remember triple checking every single connection when doing OCC, I checked like crazy. Turns out that hose could have POPPED off instead. I checked the hose again and it seemed kinda lose, like it was coming off.
  15. TacoPapi
    60
    United States
    DEB0AF18-A4DE-4722-BEC4-191DD0CE5C1E.png 39070FDF-AF88-4D93-B6B4-5DC0E2383162.png Nothing changed but I just noticed the following after doing emissions test:
    evap system not passed
    EGR system not passed after unplugging the switch and plugging it back in.
    Misfire cylinder 1 and cylinder 4. Do you guys have any ideas? I still have no codes
  16. TacoPapi
    60
    United States
    41EBFDE1-1595-4E79-8E09-F1625C74BF8A.png I might just get rid of the car at this point.
  17. TacoPapi
    60
    United States
    Can anybody guide me? I just checked this through another app. O2 sensor has 0.00v is that normal? 72144775-7265-4257-920E-23E56F156800.png
  18. xliderider
    8,140
    3,280
    Honolulu, HI
  19. TacoPapi
    60
    United States
    Time to take it to the shop then
  20. TacoPapi
    60
    United States
    Out of curiosity, can anybody help me. When doing catch can, the oil line going to the OCC is supposed to go on the OUT area instead of the IN? Basically OIL OUT?
