Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. VintageGold
    VintageGold Junior Member
    28
    Utah
    Does anyone have a reliable source for danlatu’s bracket in nylon? I've tried ordering it a couple times and keep having my order cancelled.
  2. Jon Watkins
    Jon Watkins Active Member
    131
    115
    Bluffton SC
    2024 Prius
    Download his file and send it to an online 3d printing company. That’s what I did. Printing in nylon with shipping was slightly less than $50.
  3. VintageGold
    28
    Utah
    Who'd you use? Like I said, I tried a couple and they got cancelled. Kinda lame, I know.
  4. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    kumbyall is really a stupid song, and not accurate.
    Fossil fuels are NOT the problem. Do you know how much pollution and by products making a battery produces?
    WAY worst than a gas engine.
  5. ASRDogman
    8,067
    4,089
    Perhaps if you put that filter after the catch can there would be less chance of clogging since the oil/water
    would stay in the can, or most of it.
  6. Jon Watkins
    131
    115
    Bluffton SC
    2024 Prius
  7. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    Finally got around to cleaning the EGR circuit, intake manifold, the IAT sensor, mass air flow sensor, throttle body and plate. I installed the OCC too. Thanks to danlatu and his bracket. I'm getting a 1.5 MPG improvement so far. I can't believe how much collected in just 2 tanks of gas! 20180728_150721.jpg 20180728_151203.jpg 20180728_150721.jpg 20180728_151203.jpg
    danlatu, Bay Stater, RMB and 3 others like this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Whats that clump near the middle bottom of can? Is the aroma like engine oil?
    Colm01 likes this.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Now that you ask, how much moreand provide actual research and factual documentation.
  10. ASRDogman
    8,067
    4,089
    Years and years ago there was a program on the Discover channel that went through building a battery.
    YOU can spend the time and do the research to find it if YOU want to, but I don't.
    There are lot's of by products from a battery.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    You asked the question so I thought you would have the answer to prove your point.
  12. ASRDogman
    8,067
    4,089
    Sorry, but I can't remember where I've learned everything. I don't even remember what the show was or if
    it was even the discovery channel, it could be something else. It was a show about by product of different things.
  13. qettyz
    qettyz Active Member
    181
    208
    Finland
    I just got same stuff on bottom of my OCC. 2800km driving on 20-30C temps on long summer holiday trip. Quantity was about almost one desilitre(google says 1dl is 3,3oz), maybe something like 0,7dl or so.
    I was expecting more. Driving was lots of hills, speeds around 50-60mph. On some roads up to 70+(130kmh).
    Whole family trip with 5 persons with fully packed car. Calculated consuption was around 5l/100km(some fillups 4,9 and some 5,1). 5l/100km equals to 47 us mpg.
    RMB likes this.
  14. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    Hi Grid, That clump was a piece of metal from the drillings in the catch can manufacturing. I suppose I should have opened it up and cleaned it before I installed it. This was the first time I emptied it. I would say it was almost pure oil.
  15. VintageGold
    28
    Utah
    Yes, that was the plan. It's the same concept as what danlatu did, just outside of the can instead of inside it. I'm actually leaning towards trying an Oil/Water Separator or Mini Air Line Filter from Harbor Freight. They're easy enough to adapt from 1/4" threaded connectors to 3/8" hose barbs.
  16. TheChip
    TheChip Senior Member
    388
    1,211
    Misissippi
    Has anyone vented the valve cover ventilation to atmosphere?
    I have an OCC installed, but I'm about to 3d print a new intake with no inlet for the valve cover vent. I don't think there will be an issue but I wanted to check here to see if it had been done before or if anyone has input.
    This picture explains what I'm going to do.
    danlatu and PlugmeInplz like this.
  17. evilchargerfan
    evilchargerfan Junior Member
    24
    42
    San Diego
    hey everyone! thought I'd share some fun tid bits on my pos honda fit. after 400 miles of driving around town, 5ml of oil collected
    I wonder if other makes/models out there, other than Toyota, will suffer the same fate as 3rd gen prius owners do with excessive oil collecting in the intake manifolds and on the intake valves
  18. Mendel Leisk
    42,354
    I have an odd phenomena: every so often I'll catch a whiff when looking at a visual. For example, the smell of ale while watching a pub scene on Coronation Street.
    I swear I smelled used motor oil just now...
  19. PlugmeInplz
    PlugmeInplz New Member
    22
    24
    LA
    2013 Prius Plug-in
    @evilchargerfan How do you like your OCC. I saw a similar model on ebay and wanted to see how you liked yours.
    Is it easy to drain while mounted. I could tell from the image if it would be easy to turn the drain valve at the bottom. I like that it has a brass media that should strain out the oil and water vapor.
    How is the inlet and outlet plumbed. I am assuming the outlet is inside of the brass media with the black rubber gasket.
    Also is the clear part glass or plastic.
    Thanks
  20. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    Thanks to danlatu and nutzaboutbolts for your great posts and videos, I just completed my priuschat 120000 miles maintenance, or trying not to blow a head gasket, I installed the same OCC, changed spark plugs, changed pcv valve (because your right there) cleaned intake manifold, removed and cleaned egr cooler (75% clogged) cleaned egr pipe and valve, plus changed the coolant unplanned but I drained it for the egr cooler work. That leaves you enough to do the inverter coolant too. I wish I could of cleaned the intake by the fuel injectors better but I was afraid of knocking to much back into the engine.
    thanks again guys!
    patw
    m.wynn, Colm01, Bay Stater and 6 others like this.
