ONE GOOD WAY TO KEEP 12V BATTERY CHARGED UP
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by srivenkat, Jan 18, 2021.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    Actually the method you propose is not a really GOOD way to keep the battery charged either.
    Driving the car has more advantages.......but that has been covered in other threads too.
    I think this thread really accomplishes nothing useful.
    Sorry.
  2. Mendel Leisk
    41,445
    I seem to recall protracted idling can actually run the 12 volt DOWN (excuse cap lock, highlighting is a pain on phone). Maybe more so on conventional car.. And, idling a Prius is an exercise in futility, it’ll maybe shut down in 2~3 min. If a dedicated charger takes at least 3~4 hours, what does 5 minutes idling do...
    jerrymildred likes this.
  3. ChapmanF
    18,186
    The engine. 12 volt battery keeps charging though, as long as the READY light's on. Doesn't matter if the engine's running.
  4. srivenkat
    srivenkat Active Member
    596
    93
    IL
    If a Prime is being regularly driven so infrequently and for short distances, the ideal thing to do would be placing the 12V on a battery tender like Mendel suggests. The OP suggestion in this thread is for the once in a great while special circumstance where the 12V might be getting too low because of temporary changes in driving routines.
    #24 srivenkat, Jan 21, 2021
  5. AldoON
    AldoON Member
    108
    79
    Milton, ON
    2018 Prius Prime
    Upgrade
    I'm finding this thread useful since I don't have a convenient place to plug anything in at home.
    Unless it's a last resort I won't be leaving the car in ready at home. What I may do is leave the car in ready mode while I'm waiting or between errands such as curbside pickup. Typically I used to turn the car off when "idling." Habit from ICE only cars I guess.
  6. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Ooops... Disregard!
  7. srivenkat
    596
    93
    IL
    Yes, you could leave it in READY mode in between errands, but you would have to lock the doors using the metal key from the outside, if you are concerned about safety or some thug could drive it away, even when the keyfob might be with you.
    AldoON likes this.
  8. ChapmanF
    18,186
    If you stay in the car beween errands or while waiting for curbside delivery, then you only worry about the thugs who would drive off with you in it.
    AldoON likes this.
  9. srivenkat
    596
    93
    IL
    That would only be a concern if you are beautiful or rich (or both) :D
  10. Maggy Field
    Maggy Field Junior Member
    24
    Tennessee
    I believe this is one of the more important posts on this thread. It points out how difficult it can be for even well informed people to really grok the entirely different purpose of the 12V battery in the Prius/Prime. Of course precautions are necessary to prevent excessive discharging, but as said, if it starts the computer it has enough charge.
    I was following with interest another thread about low voltage on the accessory port while driving. I haven't done my testing under load yet, but here is a graph of the voltage directly on the 12 Volt battery terminals beginning after an overnight charge just before I took the car for an EV drive that never required the ICE to start. The X axis is seconds with measurements made every 2 seconds. It covers roughly 2 hours of running errands with the time I was parked evident as flat areas of no activity. Before READY the voltage was at about 12.45 volts. The voltage varies from about 14.3 to short spikes as low as 11.6 VDC during the drive. When I parked it had apparently charged to about 12.6 volts.
    So I hope you find it interesting. I will do this again with a substantial, 60 watt or so, load on the accessory port and will post that data on the other thread about low accessory port voltage.
    #30 Maggy Field, Apr 9, 2021
  11. bisco
    51,924
    'if it starts the computer, it has enough charge'
    this is no way to measure battery health
  12. Maggy Field
    24
    Tennessee
    True, that would require a load test, but that was not the point. The point was to relax and not obsess over the exact voltage. The battery can be perfectly healthy if the system has chosen to leave it a couple of tenths of a volt lower or higher. As long as it will start the computer it is functioning properly within the system. It's overall health is another issue.
    #32 Maggy Field, Apr 9, 2021
  13. Kevin Kellogg
    Kevin Kellogg New Member
    Prescott, AZ
    2020 Prius Prime
    I have a CTEK charger but wasn't sure how to hook the two permanent connections to the battery. The manual suggests that the negative be attached to a spot under the engine cover, which wouldn't work. Would the two red spots work? Or do you have another suggestion? Thank you.
  14. Mendel Leisk
    41,445
    With a 2020 I believe the battery is under the hood? Which greatly simplifies things (why am I disappointed...). You can connect at those points, and it'll be fine.
    The alternative I used, having a third gen with battery at back of car, and still wanting the wire to be in the engine bay, accessible by popping the hood, was to connect the positive CTEK quick-connect cable wire where the main 12 volt positive wire connects at the under-hood fuse box. The negative connection can be any convenient/safe/solid bare metal point on the car body.
    This video shows accessing 3rd gen under-hood fuse box positive connection:
    4th gen may be similar. One thing I found, with my install (at that fuse box point): the pig-tail on the CTEK quick-connect positive wire has a plastic shoulder that needed to be mostly trimmed off, because there's very little room where it connects, it needs to bend down 90 degrees immediately beyond the connection point.
    For negative connection, I first was considering loosening an existing bolt and sandwiching the CTEK neg pigtail connection. Then I noticed an unused threaded hole, quite close to the fuse box, and used that, with an extra metric bolt I had.
  15. BiomedO1
    BiomedO1 Senior Member
    3,604
    1,861
    SacTown, Ca
    I would connect at the nut behind the clamps and tie wrap them down to follow the harness - before bundling them back together to plug into the charger. IMHO, it'll look cleaner and doesn't interfere if and when you need to replace that battery.
    Kevin Kellogg likes this.
  16. Kevin Kellogg
    Prescott, AZ
    2020 Prius Prime
    Thank you Mendel for the quick and detailed response. You are correct that my battery is under the hood. I also agree that the CTEK connectors are problematic in many cases but they are nice little devices when you do get it connected.
    I'll take a look at the video and the videos in your signature area. I've only had the PP just under two months so I am certain I will find some very useful tips.
    I had one more question. When charging the 12 volt battery can you also charge the battery pack or should you just perform one or the other?
    The date code on my battery indicates that it is five years old. Yesterday my wife had an issue where the Prius would not start so I had to go and give her a jump. After charging with the CTEK it is at 13V now. Think I'll order the Solar BA9 you suggest and see if I need to replace it. Thanks again.
  17. Mendel Leisk
    41,445
    You're just charging the 12 volt battery battery. For the hybrid battery periodic charging is not really necessary, nor trivial.There are "chargers" for the hybrid battery, but they're more for battery balancing/restoring. The main thing that's really detrimental to the hybrid battery is a protracted idle time, like multiple months. I think Owner's Manual cautions, to not leave the car without use for more than "several months" IIRC.
    That said, our '10's build-date was August, 2009, and we bought it, with about 10 kms on the odometer, in November, 2010. So far no problems with the hybrid battery. Knock on wood...
    Good idea. (y)
    You're very welcome. :)
  18. BiomedO1
    3,604
    1,861
    SacTown, Ca
    You may charge both batteries at the same time. When the traction pack is charging, the DC-DC converter is active. It is a 'smart' unit, so seeing your CTEK will reduce it's output to near zero. Make sure whatever maintenance smart charger you go with can output at least 3-4 amps to overcome the Prius's interval self-diagnostic current draw.
    Also check and top-off the battery electrolyte levels. They're probably low, if nobody has been checking them. Use a nickle or quarter to gain access.
    Hope this helps.....
  19. Kevin Kellogg
    Prescott, AZ
    2020 Prius Prime
    I thought the MF code shown on my battery meant it was maintenance free. Would I still want to top off the battery in that case?
  20. BiomedO1
    3,604
    1,861
    SacTown, Ca
    If you want it to last past it's projected end-of-life, you can just leave it alone and buy another one. The maintenance charger isn't going to do you any good if the cells are dry. IMHO.
