oversized oil filter ?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by lextoy, Feb 14, 2019.
  1. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    has anyone put an oversized filter on the PRIME yet ?
    i am running oversized filters for years on my 08 prius.
    purolator pure one PL20195
    i see the PRIME still uses mobil1 m1-103, same as the 08 cross compatible with the PL20195
    so the oversized purolator or similar should still be compatible.
    only unknowns would be:
    is the mating surface on the PRIME for the filter gasket large enough for the oversize filter?
    is there enough clearance for the longer filter?
    anyone using any ?
    extra large filter adds more oil capacity, and filtration, and helps me feel safer exceeding the 10k oil changes if i have to.
    after the free maintenance, i might push to 15k oil changes, as the PRIME runs much less than the 08 does.
    as long as the oil is properly heated up once in a while, (i would do an HV run weekly on my 30 min 15 mile commute), the normal EV functioning to reduce the engine run time to near zero, would be justification to extended to 15k oil changes.
    if the engine runs for 25% of the 15k miles thats only 3750 miles !!!! why dump good oil?
    douglasjre likes this.
  2. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Take a look at John Kelley's video where he explains the Prius Prime trans-axle which links the two motor-generators and the internal combustion engine. Particularly, see his discussion about 37 minutes into the video where he discussed the electric oil pump which circulates oil through the trans-axle for both lubrication and cooling.
    While the internal combustion engine may run very rarely on the Prime, the oil is still being circulated and subject to heat and contamination from the metal particles which are the result of normal wear of gears, bearing and other moving parts.
    As for running the Prime in HV mode weekly, the Prime is designed to run its internal combustion engine periodically, but at much less frequent intervals.
    I am not sure that there is any real benefit to your strategy -- but that is purely my opinion.
    Moreover, I hope that you don't "dump good oil" or any oil; it should be disposed of and appropriately recycled. According to Mobil, used motor oil "can be cleaned and fully reused as a fuel oil. One gallon of used oil provides one gallon of fuel oil. With higher-intensity processing, it can be re-refined back into lubricants at about a 60 percent yield – 1 gallon of used motor oil provides about 2.5 quarts of lubricating base oil."
    Fern1461 and Mendel Leisk like this.
  3. schja01
    schja01 Senior Member
    1,858
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    When I use to hang out at my cousin’s service station “dump” was synonymous with “drain”. Weekly a truck come by to pick up all the drained oil. I asked what he did with it and he said he took it back to the storage depot and it was just added to the gas in those huge storage containers at X parts per million. Not sure if they still do it.
  4. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    Having already done one oil change so far (0-30W Mobil 1 synthetic), I can tell you that there is probably only about 0.3" clearance between the edge of the very small oil filter and a metal flange. If you put anything with a larger diameter on, it will either just barely fit (which leaves no room to use an oil filter removal tool) or it will hit the flange.
  5. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    Ha! Sorry, dump is my slang for drain and recycle ;)
    Thx bear, I'll have to watch the video, I'm thinking just based on what you said, perhaps it's the transaxle fluid that is continuously circulating.I know it serves double duty as transmission and hybrid drive fluid.cooling insulating lubricating...but that's not actually the engine oil...I can't believe that if the engine isn't running that the engine oil is circulating.why pump around cold oil? But let me watch the video.
    Pdog, Thx.as I recall on the 08, there is a pipe/flange too close to the oil filter as well, but maybe on the prime it's worse, how was the clearance between the end of the filter and the plastic cover? The larger filters are larger diameter, and a lot longer!!
  6. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    Pdog, why the 0w30? Any loss of mileage?
  7. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    @lextoy - Sorry, not sure what you mean. The oil filter was mounted parallel to the ground (it unscrewed towards the left front wheel if that makes sense). There was a right angle flange where the filter was mounted and the limited clearance appeared to be due to the oil pan sub assembly.
    I think there was a decent amount of clearance from the plastic panel that you needed to unscrew to the oil filter. The biggest issue is that the space available will be even more limited by the small clearance between the flange and the side of the oil filter. It could be up to 0.5", though. Too small for me to get my hand around to unscrew by hand, thus requiring the Motivx oil filter cap plus a breaker bar because it appeared to have been put on by a professional weightlifter.
  8. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    I changed the oil early at about 2.5k miles (just an old school habit of mine, I guess). Have not noticed any mileage drop-off due to 0-30W.
    Still averaging about 100 mpg combined HV and EV. I charge about 3-4 times per week.
  9. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    ok good to know, i was envisioning the filter in a vertical orientation, its horizontal! i found a picture on youtube... i see the flange you are referring too. obviously the plastic oil pan cover isnt an issue. i'll just have to test fit one time to try...
    benagi and Pdog808 like this.
  10. Fern1461
    Fern1461 Junior Member
    Houston, Texas
    Moreover, I hope that you don't "dump good oil" or any oil; it should be disposed of and appropriately recycled. According to Mobil, used motor oil "can be cleaned and fully reused as a and other moving parts.
    Proper disposal of used motor oil/ Automatic Transmission fluid / power steering fluid / brake fluid : you can collect used motor oil , ATF, power steering fluid in the same container. Take old oil to any auto parts store ( not on Mondays, my goto usually has their drum full ). Brake fluid needs to collected in it's own container for hazardous waste collection. If not, many recyclers tend to discard mixed/contaminated oils.
  11. douglasjre
    douglasjre Senior Member
    2,224
    743
    Null, NL
    I'm confused. I didn't know the engine oil circulated thru the cvt
  12. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    It isn't engine oil.
    The non prime models have an engine driven oil pump in the transmission which does not run when in EV mode (short distances anyway, so that fine and you still have the effect of gears slinging oil around).
    The prime models use an electric oil pump because the EV range is a lot bigger so you need better cooling and lubrication to keep the transaxle from overheating.
  13. DOHCtor
    DOHCtor Active Member
    170
    102
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Personally, i use a Toyota 90915-YZZF1 filter that is about an inch longer then the 90915-YZZN1 the Prius uses. Same bypass valve setting, same size, just longer. Works wonder.
