P CON MAIN wiring
Discussion in 'Gen 2 Prius Technical Discussion' started by Jimlarge, May 4, 2024.
  1. Jimlarge
    Jimlarge Junior Member
    28
    MN
    My 2007 has a damaged corroded wire in the fuse box under the hood.
    It is causing the screen to have a park lock error.
    I have attached the photos of the problem.
    Does anyone know where this wire goes and comes from? I will have to tie into the wire somewhere else because the big group of wires going into/out of the fuse box seems very difficult to work with. I'm also concerned about damaging more wires if I start taking that big bunch of wires apart so I'd like to"hook up with thewire somewhere else.
    I really appreciate any help!
    Thanks!
  2. ChapmanF
    19,020
  3. Tombukt2
    Tombukt2 Senior Member
    13,858
    2,517
    Durham NC
    You can jumper that out The blue wire in the bottom picture in that plug You pick up the 7.5 amp fuse down in the fuse box for p con. And that livens that circuit back up You should clean the crap out of that hole and see what you really have once cleaned with some good contact cleaner It may be okay and then you need to lube it up when you put it back together
