P0401 Prius 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mike 777, Mar 24, 2016.
  1. Mike 777
    Mike 777 Junior Member
    16
    Los Angeles
    I've read many threads in here, but I didn't find problem of my car.
    It's Toyota Prius-3 2010, check engine light on and code is P0401. EGR Valve works well, I cleaned pipe, gasket, cleaned throttle plate and everything but nothing helps.
    I have (light on) it maybe 1 year or more, the light goes away and come back,I'm in Los Angeles and all they time is sunny day and weather is nice, I've seen 3 times, when i drove in rain evening and morning I didn't see light on.. then, couple days and comes again. I think maybe EGR cooler has to be replace? or I do not know why in cold weather time light goes away..
    Prius_Angie likes this.
  2. JC91006
    16,482
    8,400
    How many miles are on your car? There is a 150k miles emissions warranty in California
    SM-N900P ?
  3. Mike 777
    16
    Los Angeles
    now 170 000, but when first came on was 130 000 miles
    49,482
    did the dealer note the problem at 130?
  5. Mike 777
    16
    Los Angeles
    nope, at that time I changed battery, dealer didn't say anything.. I buy now "CRC Guaranteed To Pass Emissions Test Formula, 12 Ounces " (Powerful detergent additives super-clean your entire fuel system, reducing emissions and improving performance
    • Lowers CO, HC, and NOx emissions to guarantee a passing emissions test) I'll try that, if not i'm thinking to change EGR Culler Sub Accembly that will my last chance to fix it because it has a electrical connection and should be problem in there, but EGR Valve stick works great I do not need to change it.
  6. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    There are many threads here from people who had that problem.
    One guy tried everything, to no avail. Then he disconnected his 12V battery for a few minutes, which let the code clear. The light went off and stayed off.
    Another Engine Light (P0401) question | PriusChat
    ZeroM8 likes this.
  7. Mike 777
    16
    Los Angeles
    I've read all, disconnect 11 V didn't help. The problem is, I need to pass Smog Check in here Los Angeles and that's the problem
  8. Rebound
    3,964
    2,613
    Portland, OR
    Using an OBD-II tool, you can reset the error and clear the light. If it takes two or three days to show up after it clears, you can try taking it in for smog right after you clear the error. Prius cars are super-low emission, even with this error. So there's a very good chance you'll pass.
    An OBD-II tool costs about $50. You might have a friend who has one.
  9. Mike 777
    16
    Los Angeles
    I know that way to reset, but that guy from smog check station told me don't reset, just fix it in regular way ...anyway, anyone has an experience how to replace EGR cooler assembly? It need to be in specific position or angle, any video or recommendation I will appreciate.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Have you checked the Manifold Absolute Pressure sensor? That is is one of the possible causes for the DTC.
  11. Mike 777
    16
    Los Angeles
    If you mean MAF sensor it also changed, I think my Prius 3 generation does not have MAP sensor.
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I meant MAP. I have the same car and it does have a MAP sensor.
  13. Mike 777
    16
    Los Angeles
    Where is that located? I'll just replace it, if it has connection with EGR. Cold weather has impact to some parts, and light comes off.
  14. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    It's on the intake manifold right next to the throttle body. Pull the air box and you should be able to get at it. Held on by a single bolt, I believe.
  15. Mike 777
    16
    Los Angeles
    Does MAP has connection to EGR? because if error P0401 identify as an EGR problem
  16. jdcollins5
    5,131
    1,338
    Wilmington, NC
    The DTC for P0401 lists the MAP as a possible cause.
  17. Mike 777
    16
    Los Angeles
    I went to dealership, asked MAP sensor, they said there is NO on Toyota Prius MAP, it has just MAF sensor.
    Is your car Toyota Prius evropean or usa?
  18. jdcollins5
    5,131
    1,338
    Wilmington, NC
    US. You need to find another dealer. You can monitor MAP with SGII, Torque, Engine Link, Tecstream, etc so it does exist.
  19. m.wynn
    684
    1,226
    Queensbury, NY
    There is very much a MAP (manifold absolute pressure) sensor in the U.S. gen 3 Prius. It is where I describe and I've had mine in my hands and cleaned it with MAF cleaner while completing an intake manifold, EGR port de-sludging. Whether or not it has anything to do with P0401 is another matter altogether.
    https://techinfo.toyota.com/t3Portal/document/rm/RM1290U/xhtml/RM0000040YG000X.html?sisuffix=ff&locale=en&siid=1459037083094#RM0000040YG000X
    Your dealer probably only shows it as sensor assy, vacuum (for EFI) part #8942147010
    2010 Toyota Prius Base 1.8L ELECTRIC/GAS Automatic CVT. #8942147010: Manifold Absolute Pressure Sensor
    Rebound likes this.
  20. Rebound
    3,964
    2,613
    Portland, OR
    It's already been said, but there's a specific Toyota cleaner for the MAP sensor. Luckily, the MAP sensor is really easy to get to.
