P2610 Engine code / Check engine light ECM
Discussion in 'Gen 2 Prius Main Forum' started by mwbrown25, Oct 18, 2022.
  1. mwbrown25
    mwbrown25 Junior Member
    So. Cal
    Tried to search for others getting a p2610 engine code "ECM/PCM Internal Engine Off Timer Performance" on a base model 2004 Prius. Ive reset the code several times and is coming right back. Anyone know the diagnostic tests that would condemn ECM replacement? If the ECM needs to be replaced can I just swap a used one in and drive? or will it need to be programmed by a dealer. What are the consequences of driving with the check engine light on? car runs/drives fine iv'e had the problem for about 350 miles
    51,155
    the only consequence will be the inability to get smog checked when the time comes
    51,155
    51,155
  5. mwbrown25
    So. Cal
    Cool i'll check 12v battery voltage and see if my scanner picks up an ECT reading. 12v battery is only 4 months old but ya never know
  6. mwbrown25
    So. Cal
    12.7v on newer battery seems good to me.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    You might want to test that proper 12V power and ground are present where they need to be at the correct circuits on the ECM connector. See the service manual wiring diagram.
    If so, then I would get a used ECM (match up the part number) and try it. The ECM is plug and play on a Gen 2 Prius.
    Also clean the throttle body as removing 12V power resets the ECM adaptives . These are learned adjustments to things like throttle opening that compensate for normal "goop buildup" in the intake that occurs over time. If it's reset with a dirty TB, then the throttle might not allow enough air through it to let the engine start.
