part number for front abs sensor wire retention clip
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by hox, May 15, 2026.
  1. hox
    hox Junior Member
    33
    Portland, OR
    Was doing a front strut change on my 2020 prius prime limited. The small black plastic clip that retains the abs sensor wire to the strut broke on both sides. The clip has a serrated post that inserts into a hole and has the clip mechanism on top.
    If anyone knows the part number, I would really appreciate it.
    Edit: I did check with the dealership and they said these clips only come with a complete speed sensor cable.
    If that is the case, has anyone fond a generic one that will work?
    #1 hox, May 15, 2026
  2. Hayslayer
    Hayslayer Active Member
    539
    331
    Toyota part #ziptie
