Partial charge ok?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Amcrump, Mar 2, 2013.
  1. Amcrump
    Amcrump Junior Member
    Gaithersburg, Maryland
    I have a limited time that i can charge at work due to the outlet location.If it takes 3 hours to get a full charge but I only have 2 hours to charge is it ok to just unplug while the charging light is still on? Should I only charge when I know I have enough time to get a complete charge.
    Page N. likes this.
  2. Gaudete
    Gaudete Junior Member
    71
    I do this all the time - I was under the impression that it's perfectly all right. Looking forward to seeing what others might have to say.
    Page N. likes this.
  3. El Dobro
    El Dobro A Member
    6,978
    3,213
    I get what I can when I can get it. And the car, too. :p
  4. retired4999
    2,652
    625
    Eau Claire, Wi.
    Charge when you can and un-plug anytime. Enjoy! Maybe read this it might help.
    Read more: http://priuschat.com/threads/the-one-and-only-prius-plug-in-faq.118566/#ixzz2MPZV5j3L
    lensovet likes this.
  5. bisco
    49,402
    i do the same everyday at work. sometimes 15 minutes, sometimes an hour, rarely to full.
  6. 3PriusMike
    2,965
    2,316
    Silicon Valley
    It is actually better for the battery to get more shorter charges
    Mike
  7. lensovet
    2,614
    496
    Burlington, NJ
    yes, the only thing is, make sure you are unplugging from the blue handle end, not the outlet end. that is, disconnect the cord from the car first and from the wall outlet second (if using the supplied 110 V charger).
    Page N. likes this.
  8. Gaudete
    71
    On a related note, is there ever a reason to unplug the charging unit from the wall? I leave mine plugged in all the time, even when my PiP isn't charging.
  9. lensovet
    2,614
    496
    Burlington, NJ
    Sure, if you plug in a semi-public place, like an apartment building garage.
  10. Gaudete
    71
    I wasn't referring to reasons of etiquette....
  11. Gaudete
    71
    ....or security
  12. 3PriusMike
    2,965
    2,316
    Silicon Valley
    I unplug mine...I charge at work Mon-Fri. It uses 1.4 watts when plugged in...so 5 days is 168 watt-hours...almost one mile of electricity (I average ~190 wh/mile)
    Mike
    Page N. and Phausto like this.
  13. Page N.
    Page N. Junior Member
    Rancho Santa Margarita, CA
    2018 Prius Prime
    Picked up my Prime 2 weeks ago. Charged it (partially) for the first time yesterday. Pretty amazing - 57MPG :) Gonna TRY to charge it all the way tonight - see how it does on the way to work in the AM :)
  14. bisco
    49,402
    Congrats!(y)
  15. padroo
    padroo Senior Member
    2,763
    2,250
    Welcome to Prius Chat, enjoy your new ride.
