PHEV Help: Prius Prime, Honda Clarity, or Volt
Discussion in 'Prime Main Forum (2017-2022)' started by rbrak29, Apr 25, 2018.
  1. rbrak29
    rbrak29 Junior Member
    25
    The Clarity does not have a transmission. The engine is used to charge the battery like the Volt.
  2. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    All 3 vehicles described uses CVT
  3. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Charge-Mode already delivers that.
  4. hill
    8,799
    according to his Avatar (if true) he's 106 years old. Statistically only 1 out of ~2 million+ lives that long in the N American content. Thus - the super old are entitled to say any thing they want about trannies / manufacturers etc, regardless of objective realities - & we should just say, 'ok'.
    Merkey and Since2002 like this.
  5. rbrak29
    25
    Automobile Magazine:
    The Clarity PHEV is anything but a traditional hybrid. For one, it makes do without the continuously variable transmission commonly found in hybrids. In fact, there’s no gear swapper period. Instead, the Clarity PHEV relies on its electric motor, which serves up 181 hp and 232 lb-ft of torque, for primary propulsion.
    Volt: a cutaway of the transaxle does not reveal a CVT belt just a chain belt
    BTW: I am not 106 yet
  6. hill
    8,799
    not YOU ... The old guy critical of your comment .... bb4srv in posts 60 & 62! Your avatar doesn't show your age so I don't know how that could yet misdirected.
    Yes I already know the goings-on in the various hybrid & phev's. But thank you anyways -
    sheesh
    #66 hill, Apr 26, 2018
  7. rbrak29
    25
    My error. Sorry.
    BTW: my avatar is my wife’s trike after electric assist installed.
    hill likes this.
  8. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    Voice commands can turn A/C on and off and set temperature.
  9. rbrak29
    25
    Time to put this thread to bed. Please vote for your favorite, Prime, Clarity, or Volt, reasons why or why not. Maybe I should just get a Tesla Model 3 and a good divorce lawyer . Thanks for all the input.
  10. Trollbait
    12,511
    The three's transmission, or transaxle, is referred to as an eCVT, which is just shorthand for saming the car's driving behavior is like that of a 'belt and cone' CVT. The Prime and Volt both have a planetary gear at its heart. The difference is in where the engine and motors connect to it.
    Honda says their dual motor hybrid system doesn't have a transmission because it is a simple one speed like what a BEV would use, except that the ICE can clutch in to help at highway speeds.
    Since you got the truck for hauling things, and are really just waiting for a suitable BEV, I'd go with the Volt. In addition to the longer EV range, you might be able to find a deal on a pre-owned one, and save some more for its BEV replacement.
  11. El Dobro
    El Dobro A Member
    7,088
    3,270
    If I had used what my dad went though with his Toyotas as a precedent, I never would have bought any Prii.
  12. Oniki
    Oniki Active Member
    652
    499
    Colorado
    As the Ferenghi like to say:
    "One for you, one hundred for me."
  13. a_gray_prius
    2,927
    783
    IL
    Never drove the Clarity or the Hyundai hybrids, but I will say that the Prius and Prius Prime have similarly inconsequential regeneration levels when letting go of the accelerator. One thing I really really liked about both the Volt and the Bolt - they have a paddle that you can press to enable aggressive electric regen (to me it feels a little stronger than what we get on our Model S). It's like having an on-demand electric handbrake. I really like driving "involving" cars, though so that kind of thing might be a turn off for some people.
    Why not just pick up a used Volt? I saw a bunch of them with like 25k miles, CPO for like $13k last year. From what I remember of my research, they don't tend to have a ton of serious issues.
    Trollbait and Merkey like this.
  14. bwilson4web
    16,201
    Better still, vote with your wallet. I've made mine
  15. john1701a
    12,817
    5,303
    58
    Predictive Efficient Drive hasn't been mentioned.
    Rather than needing to decelerate yourself, Prime does it for you. The system logs the most frequent 1,000 locations you routinely decelerate for, then automatically provides initial braking using regeneration when approaching them.
    In other words, the "inconsequential" statement above is false for models with that feature.
    heiwa likes this.
  16. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    But that's more efficient isn't it? Light regeneration allows you to coast longer. If a car has strong coasting regeneration then you have to stay on the throttle longer when approaching a stop sign or red light. Regeneration is inefficient. It is certainly better than friction braking, however minimizing either type of braking whenever possible is the most efficient. In fact in the Gen 2 you can even turn off regeneration by letting off the throttle then press it slightly, you effectively go into neutral and can glide up to the light braking only at the end depending on how well you judged it. Of course you can't always do this in traffic. I thought I have heard that later generations don't have this capability although I'm not sure why.
    When you do need regeneration or stronger regeneration the brake pedal awaits. And paddles for cars so equipped.
    heiwa likes this.
  17. Trollbait
    12,511
    Comments here haven't been impressed with this system; it isn't predictable on when it will operate.
    A well designed regen brake system will have that spot on the throttle where there is no regen for coasting like the gen2 did. This is true of most cars capable of one peddle driving. That spot id just further down than on the gen2 to allow more control over the amount of regen applied.
  18. john1701a
    12,817
    5,303
    58
    There is no reason to believe such an incredibly vague statement. Sounds more like you are just looking for an opportunity to debate.
    It doesn't even make sense anyway. You can clearly see the locations plotted on the map and there is an indicator when it is about to engage.
    #78 john1701a, Apr 28, 2018
  19. Trollbait
    12,511
    I was recalling this thread, Predictive Regenerative Braking | PriusChat
  20. john1701a
    12,817
    5,303
    58
    16 posts based on an early discover is exactly what I'm talking about. You like to debate... hence your "troll bait" name... which isn't a bad thing. In fact, that's perfectly fine for drawing interest. Just don't be surprised when detail brings the generalization to a close.
