PIP does not charge the plug in battery while driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by benalexe, Sep 22, 2012.
  1. hill
    9,041
    kind loving sweet thoughtfully written words of grace and peacefulness approaching ... fyi, on the web, 'troll' references one who writes in order to INITIATE negativity. NOW ... if a newbie or anyone else truly has an inquiry, one will read (for example):
    "...here's an article stating the PiP can't regen its traction pack. Is that true?? Gee, that seems odd".
    But if one writes as fact, that PiP's can't regen, and reference an atricle as proof ... the latter will typically be construed , by any objective standard, to be trolling for a response .... not the folks who respond. So in the present matter, responding (in so many words) with, "that's not a production PiP" - is not trolling ... and in fact, it's the reason some thought you were labeling the OP a troll. That said, very sorry someone was tough on you for a miss-posted topic. Here's to hoping that imperfectly worded blogs/responses are the toughest part of our life. Just wanted to clearly articulate that, in the meekest softest gentlest way possible. How'd I do.
    SGH-I717R ? 2
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    52,877
    ever the peacemaker, well said.:)
  4. benalexe
    benalexe Member
    198
    30
    Commack, New York
    So here was my thought on this. The way I understand how the regular NON Plug in prius works is that the battery gets charged from braking, as well as cruising downhill. So I was thinking on the PIP if I went on a road trip. Left my house with a full battery- after 11 miles the charge would be depleted- but at the same time On the road trip I was surprised that that initial charge could not get re-generated while cruising on my trip. Make sense?​
  5. lensovet
    2,615
    496
    Burlington, NJ
    Yes and it's wrong. That article is outdated. If you search my post history you can see I wrote a report how on a trip I started with an empty battery and came back with 5 miles of range despite never plugging into an outlet.
  6. bisco
    52,877
    no. but here's the rub. if you live in a flat area, you can drive farther on a charge. even though you don't recharge much, you don't lose much to uphills either. if you live in hilly territory, you will eat up more charge going uphill than you gain downhill. so it's great that pip recharges, but us flatlanders are better off.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Once the plug-capacity is depleted, the system reverts to ordinary 50 MPG Prius operation.
    Not doing that would cancel out the benefit of having a plug.
  8. lensovet
    2,615
    496
    Burlington, NJ
    John this is wrong. After battery is depleted you are able to recharge the battery under specific conditions, such as significant elevation changes. The PiP doesn't just become a regular Prius after full battery depletion.
  9. bisco
    52,877
    sure it does. they both recharge the battery when gliding and braking, the pip just has more capacity where the non pip might fill up the battery under the circumstances you speak of. pretty unusual circumstances though...
  10. lensovet
    2,615
    496
    Burlington, NJ
    Andyprius # 1 likes this.
  11. bisco
    52,877
    the terrain is unusual, at least for us flatlanders.:p but you guys have to go up as many hills as you go down. i think.
  12. Adverness, Isn't that in Scotland. Oh that's right, Inverness , that's to be a contrarian.
  13. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
  14. lensovet
    2,615
    496
    Burlington, NJ
    Yeah I mean the net elevation change is zero, we came back to where we started — our house, lol.
  15. john1701a
    12,840
    5,312
    58
    A regular Prius will do the same thing.
    When you drive down an elevation change, it will continue to recharge until the maximum battery-capacity is reached.
  16. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The Prius doesn't use gasoline to charge it's battery, it uses kinetic energy. If you roll down a big enough hill/mountain, you will recharge the battery.
  17. lensovet
    2,615
    496
    Burlington, NJ
    of course, but because the maximum battery capacity in the PiP is higher, you can charge more, and thus deplete more later, and actually get better fuel economy.
    Rebound's mileage numbers seem to show this pretty well.
  18. hill
    9,041
    sure it uses gas - it's just that it also uses regen - just like a regular Prius regen's.
    SGH-I717R ? 2
  19. Rebound
    3,996
    2,645
    Portland, OR
    No, I think this should be cleared up -- the gasoline engine in a Prius does not charge the battery, in any Prius model. It is the car's forward rolling motion which charges the battery. This is a direct result of using gasoline to propel the car forward, of course, but gasoline isn't burned to charge the battery.
  20. hill
    9,041
    maybe I can help you understand by example, how the ICE does in fact - all on its own, can regen. Imagine your traction pack shows empty, as it sometimes can. In fact, you can help run the pack down just sitting there in ready mode ... and if the AC is on pack depletion will happen even quicker. You're sitting there in park. What happens once the pack is depleted. That's right, the ice comes on ... and guess why - and guess what it's beginning to do ... even though you're just sitting there.
    SGH-I717R ? 2
    lensovet likes this.
