Piston soak can fix this right
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bryanesk, Jul 15, 2024.
  1. Bryanesk
    Bryanesk Junior Member
    44
    San Bernardino
    Hi so did some maintenance in my engine today found some oil inside the intake manifold a good amount of carbon in the throttle housing and then found a ton of carbon in my cylinders. What’s the damage or even the future looking like for the car just hit 200k. Really want it to last atleast 3. Pictures go from 1 cylinder to 4
  2. pasadena_commut
    pasadena_commut Senior Member
    3,010
    933
    Southern California
    Oil inside the intake manifold is "normal".
    Pool of oil in throttle body | PriusChat
    If you're still worried take a picture of the oil in the manifold and post it here for comment.
    In theory you might have a bad PCV which would make it more oily than usual. Kind of a pain, as PCV replacements go, but if you really want to you could put in a new OEM one.
    What did the spark plugs look like? If things were really going wrong they would be filthy. If the plugs look normal I wouldn't worry about any of this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,001
    6,894
    Texas Hill Country
    Piston soaks fix nothing
    Tombukt2 likes this.
  4. Bryanesk
    44
    San Bernardino
    PCV valve just replaced the spark plugs the threads got some oil on them but nothing dripping was replaced couple months back
  5. Bryanesk
    44
    San Bernardino
    heard some people had some luck. Of course it’s not gonna fix it out right. But better the engine wouldnt you say
  6. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
    All i know soak will not have any effect but doesn't hurt to do that. Good luck
  7. pasadena_commut
    3,010
    933
    Southern California
    A few people have put oil catch cans on. Search this site for more info. I would guess that if there is no oil going into the cylinders (it isn't getting past the rings too) and everything else is normal that some of that carbon should burn off, eventually.
  8. pasadena_commut
    3,010
    933
    Southern California
    Only time I have had oily plug threads was on a car with a leaky valve cover gasket. Were the bottoms of the coil packs also oily?
  9. Bryanesk
    44
    San Bernardino
    No the coils were completely dry just the threads had oil
