Plastic charge port cover issue
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by GT4Prius, Sep 23, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    YES MA-AM! or sir!:eek:
    52,863
    i have used it, but it is kind of pointless, since it's soft rubber and can't damage the paint.
    priuscatprimeguy likes this.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Mine didn't come with a hook. Looked all over.
  4. priuscatprimeguy
    2,730
    2,640
    it's hiding in the cover:D:p:LOL::ROFLMAO:
  5. DavidA
    2,349
    1,825
    Chicago western burbs
    As of last night following charging, my cover no longer adheres firmly into the charge port (not the holding port thing). In fact, it doesn't hold in there at all; the outside metal door, when closed, is the only thing that holds the cover on the port. Not very well designed.
  6. Tideland Prius
    16,681
    I know but I've never seen anyone do it.
  7. Tideland Prius
    16,681
    Sigh, you're gonna pick apart my sentence word-by-word. You know what I mean - look at the attached photo of the manual on the first page. The cover for the L1 cable charging head has a u-shaped cavity that allows it to be attached to the cord (there, I didn't use the word, hook).
    priuscatprimeguy and bisco like this.
  8. bisco
    52,863
    engineers, can't live with them, can't live without them.:cool:
  9. Lee Jay
    5,850
    4,036
    I don't see an attachment. This was the hook I thought you were talking about (mine didn't come with one).
    You appear to actually be talking about this:
    That little thing has two problems. First, it requires you to over stretch the lanyard. Second, it doesn't hold worth beans.
  10. Tideland Prius
    16,681
    Yeah it's the second photo I am speaking.
    Ahh so it doesn't hold too well? That's too bad.
  11. Lee Jay
    5,850
    4,036
    Okay, so you got me thinking about this.
    This is how Toyota claims this is supposed to work:
    The problem is, it doesn't work like that. If you attach just one side, it looks like this:
    Kind of looks like the picture, but it doesn't hold well.
    If you attach both sides, like the picture, it stretches the heck out of the lanyard:
    So I'm going to try this instead:
    Tideland Prius likes this.
  12. Tideland Prius
    16,681
    Thanks for checking it out for us.
    That is weird that it would either not hold well or stretch the lanyard. Either way, I like your solution!
  13. bisco
    52,863
    that's too bad, it works fine in my pip evse. but still unnecessary.
  14. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    The original PIP(2012-2015) charge port/door works just fine. All the added instructions, locking mechanism and parts/ports just complicate the simple charging effort. KISS. I understand the locking feature, but it's not necessary.
  15. Lee Jay
    5,850
    4,036
    So, after some weeks of doing the above, it turns out that it works really well, even in strong wind.
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I have not had issue with the cap popping out of it's "charging position".
    I purposely leave the cap that's attached to the car dangling when parked in a shared charging area to make it more visible.
    My employer supplies 2 charging cables at two adjacent buildings (4 total) for about 10-12 cars. So we gotta share.
    If your not a prius owner, it's hard to notice the cap at all (if the cap is "parked"), I I found a leaf owner trying to force the charging door shut with the cap in the parked position. (I didn't make it out to unplug my car quick enough, for the next guy). He didn't see the cap. No damage to the prius, because I was there just in time.
    With the cap dangling, everybody sees it and figures out how to put it back.
  17. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
    Smart move - I think I’ll start doing that. Same thing happened to me (coworker with a Leaf who was trying to do a nice thing when moving the cable from my car to his). Unlike you, though, I didn’t get there in time. Got back to my car to find the door stuck in semi-closed position. I forced it open and was lucky nothing got bent/damaged.
  18. rverwij
    rverwij Junior Member
    Does this dust cover/lanyard have any purpose if you use the supplied charger mounted in the garage. I can see the use of it when it is stored in the trunk to keep the dust out. My lanyard is already broken in half and using hot glue did not work.
  19. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    You can order a replacement cap. Our caps in the US go in very tight and there is no way they would pop out.
    I am not sure if this one is the correct one for your model.
    2021 Toyota Prius Prime Drive Motor Battery Pack Charging Port Cover. Electrical, FCV, CONVERTER - 8282147561 - Genuine Toyota Part
    #39 Gokhan, Apr 8, 2021
  20. Gokhan
    6,715
    2,672
    Paramount CA
    I wrap the cord cap half a turn counterclockwise over the cord plug and it stays there. The socket cap is pushed into the dummy socket on the right.
