Point of oil catch can?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kehyler, May 1, 2019.
  1. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    He's a member here that wanted actual data, scientific data, real data & did I forget to mention- DATA? Data of the long term cleaning benefits of the EGR circuit. I referred him to the main oil catch can thread because he had questions that literally were covered many times but he only looked at the first few pages of photos and concluded there wasn't enough "data." Then proceeded with an Italian tune up to clear out the EGR and the removal cleaning method wasnt productive.
    Also see post #40 and see my signature.
    #41 Grit, May 6, 2019
    m.wynn, RMB and Raytheeagle like this.
  2. Mendel Leisk
    41,418
    Didn't he want the broomstick of the witch of the West, too?
    m.wynn and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Based in the KC area, he’s close to the fictitious Dorothy:p.
    #43 Raytheeagle, May 6, 2019
    m.wynn and Mendel Leisk like this.
  4. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    If exhaust were coming out of the cooler that hot, the EGR passages in the plastic manifold would melt, methinks.
  5. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    OOOOOOOH . HAHAHAHAHAHA. I'd be remiss if i said I didn't want/like data. But in this case it would be the opposite. I'm whole heartedly convinced the EGR clog is causing all this mayhem, and I jumped on board with both feet. My "jury is still out" is more in reference to the fact that we have a working theory, but no scientific procedure to prove it, even though I'm convinced the theory is correct. Anecdotal evidence is still evidence!
    When Lexus wrote up their report on our engine, they blamed our problems on "inferior" spark plugs, "inferior" ignition coils, and a leaking valve cover gasket. I was pissed as I didn't just buy the cheapest stuff from the store (though, I always do question how one determines "High quality" from "Low Quality"). They recommended using Platinum plugs and not Iridium. Really?? Platinum are BETTER than Iridiums??? My response..."If you are gonna say the product used is inferior, you had better have some solid research to back that up!" They rescinded their comments.
    The Critic likes this.
  6. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    Was that Lexus corporate, or a Lexus dealership?
  7. PriusII&C
    PriusII&C Active Member
    425
    142
    San Jose, California
    Trying to decide whether to add an OCC for my 2012 Prius, but I am still hesitate after reading so many discussions. Judging from NutzAboutBolts's video (
    ) and Mendel Leisk's report (Point of oil catch can? | Page 2 | PriusChat), an OCC collects about 2 oz oil between oil change for a properly maintained Prius. This is less than 0.1 quart of extra oil burning between OCI. Does this justify the effort to add an OCC? Please share your comments.
  8. tvpierce
    951
    882
    Maine
    2013 Prius v wagon
    Mine collects significantly more than that.
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    External factors like the environment also play a part in what the catch can collects;).
    Since you are in a similar geographic region, here's what the catch can caught on our 2019 Prime:):
    What did you do to your Prime today?
    Since our Prime is at 67%EV, that's the amount it caught for running ~3300 miles:cool:.
    I'd say add the catch can and avoid sending non-compressibles back around(y).
  10. PriusII&C
    425
    142
    Thank you, Raytheeagle. Looking at your photo, I estimate the OCC collected about 1.5 oz oil+water mixture. Considering your 67% EV (I assume your 3300 miles come from 10,000 / 3), an OCC will collect about 4.5 Oz oil+water for a 100% ICE drive in 10,000 miles. For a 5000 miles OCI, it probably will be about 2 oz, in line with NutzAboutBolts and Mendel Leisk's results. Does that sound about right?
    #50 PriusII&C, Jan 24, 2021
    Raytheeagle likes this.
  11. PriusII&C
    425
    142
    I wonder if you could share more information (amount, OCI, model, year, and mileage)?
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Sounds about right;).
    But as conditions change, more or less will get caught :).
    Key is to have the can in line so it prevents the spooge from traveling further(y).
    PriusII&C likes this.
  13. Mendel Leisk
    41,418
    Realistically, you'll reduce it. I've got a pair of moroso air-oil separators in-line, and the second one has caught more. Mostly water though, just a little oil; the first can was about half-and-half oil/water.
  14. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    By using 2 OCC, don't they adding more air resistance and more air pressure in the engine? PCV decide to release air pressure from crankcase, but for long term run, higher air pressure will do any good for engine?
  15. Mendel Leisk
    41,418
    It might, though I’ve not noticed any issues. I did actually switch to 1/2” ID hoses in one iteration (when I was still using single can iirc), with all 1/2” fittings. Nothing seemed to faze it though.
