'predictive deceleration' anyone?
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jul 4, 2017.
  1. Mark57
    2,945
    2,740
    OK
    Toyota has an OK video on this with subtle details. It says it will accumulate up to 1,000 stops on your routes over about 1 week of time.
    Prius from Dad likes this.
  2. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Is there a description of the different icons that show up and what they mean?
  3. Mark57
    2,945
    2,740
    OK
    Yes, they are in the manual. I don't have my vehicle yet, but I've read the manuals about 3 times and watched all the videos. ;)
  4. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    Cool!!! What were the biggest factors that made you decide on the Prius?
  5. Mark57
    2,945
    2,740
    OK
    I bought my 2010 new and am still driving it. I've hypermiled the heck out of it so a plug-in just makes sense to me. I'm interested to see what I can achieve with it. The 2010 is getting a little long in the tooth so it's time to change.
  6. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Do you know where this setting is? Do you have to turn it on or is it a default?
  7. AltPwr
    AltPwr Junior Member
    Michigan
    2024 Prius Prime
    Wow! Have not seen this on my Prime, but have not been looking for it. I hypermille (starting with my 2010 Gen3), and like more direct control.
    As an Electrical Engineer doing control system design - sounds like quite a challenge to get right (and SAFE!).
    Will go looking for it...
  8. Mark57
    2,945
    2,740
    OK
    Check out this thread for the "predictive deceleration" discussion and video link.
  9. DavidA
    2,349
    1,825
    Chicago western burbs
    These green dealy doolies have been popping up on my screen for several days now as the car learns my common routes. The automatic predictive regen braking isn't as strong as I would like it to be, but is an encouraging tech to experience. If it were any stronger, it might be a safety problem, actually. I'm pretty sure they took that into account when dialing it in during development. I like how they're small green dots when you're a block away, and then get bigger as you almost approach the intersections. By the time the icon is large, the regen is already starting.
  10. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Not true at all.
    The icon seems to get large when the car decides you must be going to that intersection. For me, this can be as far as a couple blocks away or as near as a couple hundred yards depending on if there are other possible turn off locations between you and the cataloged intersection. The regen starts at different locations depending on your speed. It seems to target arriving at the intersection at about 20mph. This means it starts much earlier if you are going fast and much later if you are going slow.
  11. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I have yet to see a single leaf appear on my screen. I pretty much drive the same route everyday. What am I doing wrong?
  12. DavidA
    2,349
    1,825
    Is the function turned on in the settings menu?
  13. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I never found a setting for it.
  14. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    "Predictive efficient drive"?
  15. Lee Jay
    5,850
    4,036
    Yes.
  16. Tideland Prius
    16,680
    Number 3
  17. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I found that. But it was already on. I have noticed that at some of my frequent stops, the regen does increase slightly. But still no icon
  18. DavidA
    2,349
    1,825
    My green icons took over a week to begin showing. 10 days maybe?
  19. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I'll give it some time. I wonder if there is a way to turn off the icons in the nav
    iPhone ?
  20. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Just went out to double check. Is there any other setting?
    iPad ?
