Prime doesn't give me opportunity to select traction cooling
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by fneil, Jun 19, 2018.
  1. fneil
    fneil Member
    71
    52
    Carrboro, NC
    My Prime never offers me the chance to turn on the traction cooler when I park the car. Last summer it offered it to me whenever it was hot out.
    Today it was 85F in the garage when I pulled the car out into the 100F heat. I drove the car 8 miles in EV mode, and the outdoor temp reading on the MFD slowly climbed to 90F. I parked the car in the garage, and was not offered traction cooling. I have the option activated in the MFD settings.
    I have a hard time believing 90F readout and 100F outside temp are not enough to trigger the query.
    I have two questions -
    - Why is the car so slow to reflect the correct outdoor temp?
    - Why no chance to select traction cooling?
    One note: last summer, the car was kept outside. If it was 100F outside, the MFD usually displayed that temp when I got in.
    Is 90F not enough to trigger the cooling query? I could have sworn I was offered it last summer when it was reading upper 80's, but not absolutely certain...
  2. fneil
    fneil Member
    71
    52
    Carrboro, NC
    One subsequent thought is, I had the A/C on pretty aggressively during the drive, so the battery pack itself was likely at 85F or less at the end. Perhaps this was below the threshold for offering traction cooling?
  3. PCPrime
    PCPrime Member
    110
    103
    Tampa Florida
    The threshold is about 92F or 94F and above
  4. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    This prompt is very likely linked to the temperature in the battery pack. I sometimes see and sometimes not. Usually only if it was hot and I just laid into the throttle in electric mode.
    Nothing to worry about, as the car will always act with the traction batteries life in mind.
  5. Insighter
    Insighter Active Member
    409
    287
    SoCal
    What I really dislike is that, even when offered the option, if you screw up and open your door before you select "Yes" to allow cooling, you lose your chance to allow cooling. I'm not sure why you can't choose a default setting of "Yes," or at least have the chance to turn allow cooling if you mistakenly don't choose "Yes." The only way I've found to choose "Yes" after you fail to is get back in the Prime, drive a short distance, and then park again, when you often get the prompt again.
  6. Yankee3
    Yankee3 Junior Member
    17
    Bartlett TN
    I am outside of Memphis and I do get the option of using the air conditioner. I too wish their was a default on mode. Maybe I am just stupid but there is no confirmation of on when you choose it . Also, why is it that when you choose charge now you dont push the select button, you just right click to show it in the box but with the air conditioning cooler option you apparently push select. It doesn't make sense to me.
    Insighter likes this.
  7. bisco
    52,830
    toyota software engineers are out of touch.
    fneil and burnout8488 like this.
  8. Insighter
    409
    287
    SoCal
    When Toyota makes decisions like this to limit obvious functionality, it seems it's usually for safety reasons. Like you can roll your windows down remotely with the electronic key, but you can't roll them up. When I thought it out, I realized that that is likely because rolling them could hurt someone in the car or leaning in the car. Maybe there is a potential safety risk to having the A/C on when charging?
  9. bisco
    52,830
    they know people will forget it is default on, and that may waste energy or cause another negative when it is not needed.
  10. Insighter
    409
    287
    SoCal
    But, even when you select yes and allow it to use cooling, it only uses it as much as it needs to, right?
  11. bisco
    52,830
    ya got me there, do not know if that is the case, or if it is just a timer.
  12. Insighter
    409
    287
    SoCal
    I know that it often asks permission, and I say yes, but I rarely hear the AC running while charging, and, when it does run, it only runs for a while. I charge in my garage, and the temperature in there, even on a hot day, is usually no more than 80. So I presume it monitors when it needs to run and only runs then.
  13. Insighter
    409
    287
    SoCal
    I think I've figured out why Toyota doesn't let you choose a default option to allow the Prime to use the A/C to cool during charging of the traction battery. It was really hot here the other day, and I guess for the first time my Prime really used the A/C when it was charging. It created a veritable blast furnace in my garage. My garage is insulated, so I usually just leave the door between my house and garage open (which means I'm cooling the garage with my home's A/C). Anyway, the other day it was charging and using the A/C for quite a while during the charge, and it heated my garage and the front end of my house up very noticeably. I'm guessing the don't let you choose to use the A/C to cool the traction battery during charging as a default because they want you to think about it every time you do it. If you had a small one-car garage on a hot day and you had a dog or a child in there somehow, I think the heat could get to be enough to harm them.
    Vavaq likes this.
  14. MadMax003
    MadMax003 New Member
    Ukraine
    2011 Nissan LEAF
    I have a Nissan Leaf (2011), should I buy new Leaf or Prius?
  15. Insighter
    409
    287
    SoCal
    This thread probably isn't a good place to put that question. I think you'll get more responses if you post a new thread asking that in the title in the Prius Prime main forum.
  16. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Buy one of each and report back.
    J
