1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Prius 2004 aftermarket audio JBL amp bypass?
Discussion in 'Gen 2 Prius Audio and Electronics' started by jackmilas, Jul 21, 2019.
  1. jackmilas
    jackmilas Junior Member
    60
    Wrocław, Poland
    I've found a bypass cable that according to crunchfield website will work in my 2004 Prius with JBL audio system.
    Metra 70-8117
    Has anyone used this solution? It seems like a reasonable way to use better quality amps in aftermarket audio systems.
    I read about TYTO-01 but I'd rather bypass factory amp.
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Yes, Several people have used this harness.
  3. jackmilas
    60
    Wrocław, Poland
    What about crossovers for 9 speakers? Aftermarket radios usually have 4 speaker outs with full frequency bandwidth.
    This harness is not dividing the frequencies to all 9 speakers, is it?
  4. egg_salad
    545
    426
    Las Vegas, NV
    the door speakers are passively crossed over. If the 9th speaker is the one in the dash, yeah, you're gonna lose that.
  5. jackmilas
    60
    Wrocław, Poland
    I wouldn't mind loosing the middle speaker.
    The wiring diagram from this thread: JBL amp wiring in Prius 2005, 86280-0W240 | PriusChat
    shows that there are separate outputs for front tweeters and front woofers.
Loading...
