Prius 2004 with HYMOTION LITHIUM ION TRACTION BATTERY
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Mar 1, 2020.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Hi guys. I was called today to come diagnose a Prius 04 that could not start.
    On getting to where the car was parked, discovered the 12V battery was dead.
    The battery would be replaced this weak hopefully, before I continue my diagnosis.
    But what baffled me when I opened the rear, was something I have never seen on any Prius before.
    It was a kind of like the normal NIMH traction pack, in configurations and size. On reading the cover, it was written HYMOTIONG LITHIUM ION INSIDE.
    Some questions
    1. Has anyone here own a Prius with such a technology side by side with the original NIMH traction battery in the hatch?
    2. What does the hymotion lithium ack do? Does it support the main traction battery, or ....?
    3. Is the hymotion lithium pack in the rear as a range extender of some sort?
    Thanks for your responses.
    Dxta
    kenoarto likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Prodigyplace and Raytheeagle like this.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    It was one of the companies adding a plugin lit before the PiP. Look in this buried forum.
    Prius PHEV Plug-In Modifications | PriusChat
    Dxta and Raytheeagle like this.
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Pls does anyone have a hymotion manual, showing how to removed the hymotion pack from the car entirely, revert the system to using the stock hybrid battery?
    Thanks guys
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Willing to bet that @ericbecky would have such.
    hill, Prodigyplace and Raytheeagle like this.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    Here is a Trouble Code manual.
    A123/Hymotion L5 11 Blinks | PriusChat
    EDIT: More info
    EDIT2: Jackpot?? I think the Installation Manual is the closest you could get.
    Hymotion is dead. Do I have any hope for a fix? | PriusChat
    EDIT3: Another link (scroll down)
    Hymotion - My wiki
    #6 Prodigyplace, Mar 1, 2020
    Dxta, Raytheeagle and SFO like this.
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
  8. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I see that the L5 charges requiring 120VAC in North America, etc.
    Here's my question:
    Can a 220VAC power source, as is obtainable in Nigeria used to charge the hymotion pack? Would there be cable heating problems?
    Thanks for your replies.
  9. Prodigyplace
    12,712
    11,848
    Central Virginia
    I think @ericbecky has some Hymotion knowledge
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Those manuals should help you get what you need, but feel free to call me with any questions.
    608-729-4082
    Hymotion systems are orphaned/abandoned project. They will break down and there will not be a possibility of fixing it.
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks Eric, would have the 12V battery replaced first and see how things go.
  12. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    There should be a bypass plug to take the system out of the loop.
    Generally it is zip tied some the unit on the driver side.
